跳转到主内容
加入维修社区 - 创建账户
PowerBook G4 Titanium Onyx Upper Case Replacement
你所需要的
    1. PowerBook G4 Titanium Onyx Upper Case Replacement, Keyboard: 步骤 1 中的图像 1,1
      • Remove the battery.
      • Turn the keyboard locking screw so that it is parallel to the space bar.
      • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
      询问修复机器人
      添加评论
    2. PowerBook G4 Titanium Onyx Upper Case Replacement: 步骤 2 中的图像 1,1
      • Rest the keyboard face down on the trackpad area.
      • Disconnect the keyboard connector from the logic board.
      询问修复机器人
      添加评论
    3. PowerBook G4 Titanium Onyx Upper Case Replacement: 步骤 3 中的图像 1,1
      • Your laptop should look approximately like this.
      询问修复机器人
      添加评论
    1. PowerBook G4 Titanium Onyx Upper Case Replacement, RAM: 步骤 4 中的图像 1,1
      • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to ÒpopÓ up.
      • Pull the RAM chip out.
      • Repeat this process if a second RAM chip is installed.
      添加评论
      • Turn the G4 over.
      • Remove the eight T8 Torx screws from the lower case.
      询问修复机器人
      添加评论
    1. PowerBook G4 Titanium Onyx Upper Case Replacement: 步骤 6 中的图像 1,1
      • Using your thumbs, slide the lower case away from you.
      • The lower case may stick in the front on a tab just above the center of the DVD drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
      • Lift the lower case off.
      询问修复机器人
      添加评论
    2. PowerBook G4 Titanium Onyx Upper Case Replacement: 步骤 7 中的图像 1,1
      询问修复机器人
      添加评论
    1. PowerBook G4 Titanium Onyx Upper Case Replacement, Airport Card: 步骤 8 中的图像 1,1
      • Skip this step if your computer does not have an Airport card.
      • Firmly grasp the plastic tab attached to the Airport card and pull up and to the left.
      • Disconnect the antenna cable from the left side of the Airport card.
      添加评论
    1. PowerBook G4 Titanium Onyx Upper Case Replacement, Hard Drive: 步骤 9 中的图像 1,1
      • Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger, removing tape as necessary.
      询问修复机器人
      添加评论
    2. PowerBook G4 Titanium Onyx Upper Case Replacement: 步骤 10 中的图像 1,1
      • To free the hard drive, remove the two T8 Torx screws from the right wall of the battery housing.
      询问修复机器人
      添加评论
    3. PowerBook G4 Titanium Onyx Upper Case Replacement: 步骤 11 中的图像 1,1
      • Remove the hard drive by gently grasping the orange ribbon cable and lifting the left edge up and out of the computer.
      • There are four rubber bumpers that fit over the hard drive screws. Ensure that these bumpers come out when you remove the hard drive.
      询问修复机器人
      添加评论
    4. PowerBook G4 Titanium Onyx Upper Case Replacement: 步骤 12 中的图像 1,1
      询问修复机器人
      添加评论
    1. PowerBook G4 Titanium Onyx Upper Case Replacement, DVD Drive: 步骤 13 中的图像 1,1
      • If your G4 has a CD-RW or Combo drive, the pictures in the following steps will not exactly match your computer.
      • Before continuing, place a soft cloth on your work surface to rest the computer on. Turn the G4 over, making sure the DVD drive doesn't fall out. Place the computer on the cloth.
      询问修复机器人
      添加评论
    2. PowerBook G4 Titanium Onyx Upper Case Replacement: 步骤 14 中的图像 1,1
      • Bend the silver metal EMI clip so that it is vertical. This part may fall out after removing the DVD drive.
      • The EMI clip is not essential for reassembling the computer. If the clip falls out, don't worry about putting it back in.
      添加评论
    3. PowerBook G4 Titanium Onyx Upper Case Replacement: 步骤 15 中的图像 1,1
      • Turn the G4 over.
      • Disconnect the orange DVD ribbon cable from the logic board using a spudger or the tip of your finger
      询问修复机器人
      添加评论
    4. PowerBook G4 Titanium Onyx Upper Case Replacement: 步骤 16 中的图像 1,1
      • Remove the DVD drive by lifting the right edge up and out of the computer.
      • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
      询问修复机器人
      添加评论
    1. PowerBook G4 Titanium Onyx Upper Case Replacement, Modem: 步骤 17 中的图像 1,1
      • Turn the G4 over.
      • Using a 5 mm nut driver or needle-nose pliers, remove the hex nut from the modem.
      询问修复机器人
      添加评论
    2. PowerBook G4 Titanium Onyx Upper Case Replacement: 步骤 18 中的图像 1,1
      • Lift the modem out by pulling up and to the right.
      • The plastic shielding on the modem may catch on the computer's case. Rocking the modem from side to side will help free the modem.
      询问修复机器人
      添加评论
    3. PowerBook G4 Titanium Onyx Upper Case Replacement: 步骤 19 中的图像 1,1
      • Disconnect the connector cable from the modem.
      询问修复机器人
      添加评论
    1. PowerBook G4 Titanium Onyx Upper Case Replacement, Logic Board: 步骤 20 中的图像 1,1
      • Remove the single T8 Torx screw located near the silver heat pipe.
      添加评论
    2. PowerBook G4 Titanium Onyx Upper Case Replacement: 步骤 21 中的图像 1,1
      • Disconnect the three indicated connectors from the logic board.
      • Disconnect the orange PC card cage connector from the logic board.
      • The large multicolor cable may be difficult to free.
      添加评论
    3. PowerBook G4 Titanium Onyx Upper Case Replacement: 步骤 22 中的图像 1,1
      • Turn the G4 over.
      • Remove the three T8 Torx screws from the logic board.
      • Be sure not to lose the rubber washers protecting the logic board from the lower two screws.
      询问修复机器人
      添加评论
    4. PowerBook G4 Titanium Onyx Upper Case Replacement: 步骤 23 中的图像 1,1
      • Disconnect the indicated connectors from the logic board, removing tape as necessary.
      添加评论
    5. PowerBook G4 Titanium Onyx Upper Case Replacement: 步骤 24 中的图像 1,1
      • Carefully lift the logic board up and pull it away from you.
      • This step requires some force, but if the logic board will not come up, make sure you have removed all screws and connectors necessary.
      • Remove the logic board from the computer.
      询问修复机器人
      添加评论
    6. PowerBook G4 Titanium Onyx Upper Case Replacement: 步骤 25 中的图像 1,1
      询问修复机器人
      添加评论
    1. PowerBook G4 Titanium Onyx Upper Case Replacement, PC Card Cage: 步骤 26 中的图像 1,1
      • Remove the two T8 Torx screws that secure the PC Card cage.
      添加评论
    2. PowerBook G4 Titanium Onyx Upper Case Replacement: 步骤 27 中的图像 1,1
      • Remove the PC Card cage by pulling it to the right and twisting slightly toward you.
      添加评论
    1. PowerBook G4 Titanium Onyx Upper Case Replacement, Display: 步骤 28 中的图像 1,1
      • Performing the following steps incorrectly can easily damage the display and render it inoperable. The multicolored display data cable is especially fragile.
      • Remove the four black T8 Torx screws from the plastic framework.
      询问修复机器人
      添加评论
    2. PowerBook G4 Titanium Onyx Upper Case Replacement: 步骤 29 中的图像 1,1
      • Remove the five silver T8 Torx screws from the metal framework.
      询问修复机器人
      添加评论
    3. PowerBook G4 Titanium Onyx Upper Case Replacement: 步骤 30 中的图像 1,1
      • Turn the G4 over.
      • Grasp the plastic framework and pull directly up.
      询问修复机器人
      添加评论
    4. PowerBook G4 Titanium Onyx Upper Case Replacement: 步骤 31 中的图像 1,1
      • Position the display at a 45 degree angle and rest the computer on a soft cloth with the back panel ports facing up.
      • Remove the two T8 Torx screws from each clutch cover.
      询问修复机器人
      添加评论
    5. PowerBook G4 Titanium Onyx Upper Case Replacement: 步骤 32 中的图像 1,1
      • Close the display and pull off both clutch covers. You can use a non-metal flathead screwdriver if the clutch covers do not come off easily.
      询问修复机器人
      添加评论
    6. PowerBook G4 Titanium Onyx Upper Case Replacement: 步骤 33 中的图像 1,1
      • Open the back panel port cover and remove the four T6 Torx screws.
      • The upper screw on each side fastens a small metal mount in place. Be sure to put this part back in when reassembling the computer.
      询问修复机器人
      添加评论
    7. PowerBook G4 Titanium Onyx Upper Case Replacement: 步骤 34 中的图像 1,1
      • Disconnect the audio cable at the right side of the computer, removing tape as necessary.
      询问修复机器人
      添加评论
    8. PowerBook G4 Titanium Onyx Upper Case Replacement: 步骤 35 中的图像 1,1
      • Open the display to a 90 degree angle. Rest the trackpad face down on the work surface and allow the display to hang over the edge. If possible, adjust your chair or work surface height so the display will rest on your legs and the trackpad will lie flat on the work surface.
      • Remove the four T8 Torx screws that fasten the display to the trackpad. The screw closest to the display data cable has a tapered head.
      添加评论
    9. PowerBook G4 Titanium Onyx Upper Case Replacement: 步骤 36 中的图像 1,1
      • Grasp the metal heat exchanger and pull up and away from you. You may need to move the inverter cable on the right side of the computer in order to rotate the heat exchanger.
      询问修复机器人
      添加评论
    10. PowerBook G4 Titanium Onyx Upper Case Replacement: 步骤 37 中的图像 1,1
      • Lift up the metal brackets on either side of the upper case.
      询问修复机器人
      添加评论
    11. PowerBook G4 Titanium Onyx Upper Case Replacement: 步骤 38 中的图像 1,1
      • Disconnect the inverter cable and carefully thread it through the slot in the upper case.
      • Carefully thread the display and backlight cables individually through the slot in the upper case. Be very careful with the display cable as it is easily damaged.
      • Remove the display assembly.
      询问修复机器人
      添加评论
    1. PowerBook G4 Titanium Onyx Upper Case Replacement, Inverter Board: 步骤 39 中的图像 1,1
      • Lift the inverter board out of the computer.
      询问修复机器人
      添加评论
    1. PowerBook G4 Titanium Onyx Upper Case Replacement, Upper Case: 步骤 40 中的图像 1,1
      • Upper case remains.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
附加文件
iRobot
于09/24/09注册
1 声望
创作了636篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 47
总计 8,372
