跳转到主内容
加入维修社区 - 创建账户
本指南有最近更改,您可查看未经巡查的最新版本
PowerBook G4 Titanium Onyx DVD Drive Replacement
你所需要的
    1. PowerBook G4 Titanium Onyx DVD Drive Replacement, Keyboard: 步骤 1 中的图像 1,1
      • Remove the battery.
      • Turn the keyboard locking screw so that it is parallel to the space bar.
      • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
      询问修复机器人
      添加评论
    2. PowerBook G4 Titanium Onyx DVD Drive Replacement: 步骤 2 中的图像 1,1
      • Rest the keyboard face down on the trackpad area.
      • Disconnect the keyboard connector from the logic board.
      询问修复机器人
      添加评论
    3. PowerBook G4 Titanium Onyx DVD Drive Replacement: 步骤 3 中的图像 1,1
      • Your laptop should look approximately like this.
      询问修复机器人
      添加评论
    1. PowerBook G4 Titanium Onyx DVD Drive Replacement, RAM: 步骤 4 中的图像 1,1
      • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to ÒpopÓ up.
      • Pull the RAM chip out.
      • Repeat this process if a second RAM chip is installed.
      添加评论
      • Turn the G4 over.
      • Remove the eight T8 Torx screws from the lower case.
      询问修复机器人
      添加评论
    1. PowerBook G4 Titanium Onyx DVD Drive Replacement: 步骤 6 中的图像 1,1
      • Using your thumbs, slide the lower case away from you.
      • The lower case may stick in the front on a tab just above the center of the DVD drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
      • Lift the lower case off.
      询问修复机器人
      添加评论
    2. PowerBook G4 Titanium Onyx DVD Drive Replacement: 步骤 7 中的图像 1,1
      询问修复机器人
      添加评论
    1. PowerBook G4 Titanium Onyx DVD Drive Replacement, Airport Card: 步骤 8 中的图像 1,1
      • Skip this step if your computer does not have an Airport card.
      • Firmly grasp the plastic tab attached to the Airport card and pull up and to the left.
      • Disconnect the antenna cable from the left side of the Airport card.
      添加评论
    1. PowerBook G4 Titanium Onyx DVD Drive Replacement, Hard Drive: 步骤 9 中的图像 1,1
      • Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger, removing tape as necessary.
      询问修复机器人
      添加评论
    2. PowerBook G4 Titanium Onyx DVD Drive Replacement: 步骤 10 中的图像 1,1
      • To free the hard drive, remove the two T8 Torx screws from the right wall of the battery housing.
      询问修复机器人
      添加评论
    3. PowerBook G4 Titanium Onyx DVD Drive Replacement: 步骤 11 中的图像 1,1
      • Remove the hard drive by gently grasping the orange ribbon cable and lifting the left edge up and out of the computer.
      • There are four rubber bumpers that fit over the hard drive screws. Ensure that these bumpers come out when you remove the hard drive.
      询问修复机器人
      添加评论
    4. PowerBook G4 Titanium Onyx DVD Drive Replacement: 步骤 12 中的图像 1,1
      询问修复机器人
      添加评论
    1. PowerBook G4 Titanium Onyx DVD Drive Replacement, DVD Drive: 步骤 13 中的图像 1,1
      • If your G4 has a CD-RW or Combo drive, the pictures in the following steps will not exactly match your computer.
      • Before continuing, place a soft cloth on your work surface to rest the computer on. Turn the G4 over, making sure the DVD drive doesn't fall out. Place the computer on the cloth.
      询问修复机器人
      添加评论
    2. PowerBook G4 Titanium Onyx DVD Drive Replacement: 步骤 14 中的图像 1,1
      • Bend the silver metal EMI clip so that it is vertical. This part may fall out after removing the DVD drive.
      • The EMI clip is not essential for reassembling the computer. If the clip falls out, don't worry about putting it back in.
      添加评论
    3. PowerBook G4 Titanium Onyx DVD Drive Replacement: 步骤 15 中的图像 1,1
      • Turn the G4 over.
      • Disconnect the orange DVD ribbon cable from the logic board using a spudger or the tip of your finger
      询问修复机器人
      添加评论
    4. PowerBook G4 Titanium Onyx DVD Drive Replacement: 步骤 16 中的图像 1,1
      • Remove the DVD drive by lifting the right edge up and out of the computer.
      • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
7等其他人完成本指南。
附加文件
iRobot
于09/24/09注册
1 声望
创作了633篇指南
1指南评论
I need the connector 4 this ... Can't find it anywhere
PeNn N RoMe - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 13
过去 30 天: 52
总计 10,102
