跳转到主内容
加入维修社区 - 创建账户
PowerBook G4 Titanium DVI RAM Replacement
你所需要的
    1. PowerBook G4 Titanium DVI RAM Replacement, Battery: 步骤 1 中的图像 1,2 PowerBook G4 Titanium DVI RAM Replacement, Battery: 步骤 1 中的图像 2,2
      • Locate the battery release tab on the underside of the G4.
      • Slide the battery release tab to the left and lift the battery out of the computer.
      询问修复机器人
      添加评论
    1. PowerBook G4 Titanium DVI RAM Replacement, Keyboard: 步骤 2 中的图像 1,1
      • Turn the keyboard locking screw located in the middle of the keyboard so that it is parallel to the space bar. A half turn from parallel to parallel will unlock it. Another half turn will lock it again.
      • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
      添加评论
    2. PowerBook G4 Titanium DVI RAM Replacement: 步骤 3 中的图像 1,1
      • Rest the keyboard face down on the trackpad area.
      • Disconnect the keyboard connector from the logic board.
      添加评论
    3. PowerBook G4 Titanium DVI RAM Replacement: 步骤 4 中的图像 1,1
      • Your laptop should look approximately like this.
      询问修复机器人
      添加评论
    1. PowerBook G4 Titanium DVI RAM Replacement, RAM: 步骤 5 中的图像 1,1
      • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
      • Pull the RAM chip out.
      • Repeat this process if a second RAM chip is installed.
      添加评论
结论
取消:我没有完成这个指南。
24等其他人完成本指南。
附加文件
iRobot
于09/24/09注册
1 声望
创作了635篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 57
总计 15,451
