跳转到主内容
加入维修社区 - 创建账户
PowerBook G4 Titanium DVI Inverter Replacement
你所需要的
    1. PowerBook G4 Titanium DVI Inverter Replacement, Battery: 步骤 1 中的图像 1,2 PowerBook G4 Titanium DVI Inverter Replacement, Battery: 步骤 1 中的图像 2,2
      • Locate the battery release tab on the underside of the G4.
      • Slide the battery release tab to the left and lift the battery out of the computer.
      询问修复机器人
      添加评论
    1. PowerBook G4 Titanium DVI Inverter Replacement, Lower Case: 步骤 2 中的图像 1,2 PowerBook G4 Titanium DVI Inverter Replacement, Lower Case: 步骤 2 中的图像 2,2
      • Remove the seven T8 Torx screws from the lower case.
      • Using your thumbs, slide the lower case toward the front of the computer.
      • The lower case may stick in the front on a tab just above the center of the optical drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
      • Lift the lower case off.
      询问修复机器人
      添加评论
    1. PowerBook G4 Titanium DVI Inverter Replacement, Hard Drive: 步骤 3 中的图像 1,1
      • Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger.
      询问修复机器人
      添加评论
    2. PowerBook G4 Titanium DVI Inverter Replacement: 步骤 4 中的图像 1,1
      • To free the hard drive, remove the two T8 Torx screws from the right wall of the battery housing.
      添加评论
    3. PowerBook G4 Titanium DVI Inverter Replacement: 步骤 5 中的图像 1,1
      • Remove the hard drive by lifting the left edge up and out of the computer.
      • There are four rubber bumpers that fit over the hard drive screws. Ensure that these bumpers come out when you remove the hard drive.
      添加评论
    4. PowerBook G4 Titanium DVI Inverter Replacement: 步骤 6 中的图像 1,1
      • Your laptop should look approximately like this.
      询问修复机器人
      添加评论
    1. PowerBook G4 Titanium DVI Inverter Replacement, Optical Drive Removal: 步骤 7 中的图像 1,1
      • Disconnect and remove the indicated orange ribbon cable.
      询问修复机器人
      添加评论
    2. PowerBook G4 Titanium DVI Inverter Replacement: 步骤 8 中的图像 1,1
      • Disconnect the pink and white inverter cable from the inverter board.
      • The display inverter has orange plastic shielding around it that looks similar to the tape used elsewhere within the computer. Do not remove the shielding from the inverter.
      添加评论
    3. PowerBook G4 Titanium DVI Inverter Replacement: 步骤 9 中的图像 1,1
      • Remove the two silver T8 Torx screws from the black plastic bar.
      • Lift the black plastic bar out.
      • Reassembly will be significantly easier if you reseat the hard drive before returning the black bar to its place.
      询问修复机器人
      添加评论
    4. PowerBook G4 Titanium DVI Inverter Replacement: 步骤 10 中的图像 1,1
      • Disconnect the two orange connectors from the logic board, removing tape as necessary.
      询问修复机器人
      添加评论
    5. PowerBook G4 Titanium DVI Inverter Replacement: 步骤 11 中的图像 1,1
      • Lift the drive up on the right side so that you can access and disconnect the modem cable and inverter cable.
      询问修复机器人
      添加评论
    6. PowerBook G4 Titanium DVI Inverter Replacement: 步骤 12 中的图像 1,1
      • Remove the drive by lifting the right edge up and out of the computer.
      添加评论
    1. PowerBook G4 Titanium DVI Inverter Replacement, Modem: 步骤 13 中的图像 1,1
      • Remove the two T6 Torx screws from the modem.
      • Lift the modem off the optical drive, carefully guiding the orange ribbon cable through the space in the drive mount.
      询问修复机器人
      添加评论
    1. PowerBook G4 Titanium DVI Inverter Replacement, Inverter: 步骤 14 中的图像 1,1
      • Remove the two T6 Torx screws from the inverter board.
      • Lift the inverter board off the optical drive.
      询问修复机器人
      添加评论
    2. PowerBook G4 Titanium DVI Inverter Replacement: 步骤 15 中的图像 1,1
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
12等其他人完成本指南。
附加文件
iRobot
于09/24/09注册
1 声望
创作了636篇指南
2指南评论
I didn't need to remove the modem on my Antimony model.
Fred Hood - 回复 分享
Absolutely no reason to remove the HDD, modem, or optical drive to do this on the 1GHz model. Remove the back cover and the two screws that hold the inverter in place, and thats all you need to do.
insaneiaq - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 56
总计 15,355
