跳转到主内容
加入维修社区 - 创建账户
PowerBook G3 Wallstreet Keyboard Replacement
你所需要的
    1. PowerBook G3 Wallstreet Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
      • Remove both expansion bay modules using the levers on the front of the computer.
      • Insert your index fingers inside the expansion bays and search for the two ribbed tabs on the underside of the upper case. The tabs are located near the bottom corners of the keyboard.
      • Pull the tabs toward yourself and the keyboard will pop up.
      询问修复机器人
      添加评论
    2. PowerBook G3 Wallstreet Keyboard Replacement: 步骤 2 中的图像 1,1
      • Pull the keyboard forward to disengage the tabs holding it in back and rotate it toward you.
      • Rest the keyboard on the trackpad.
      询问修复机器人
      添加评论
      • This is a diagram of the ribbon clamp connectors you will disconnect in the next step.
      • 1) With your fingernails, grasp the locking bar on either side and pull up a small amount (about 1/16" or 2 mm).
      • 2) After disengaging the locking bar, slide the cable out of the connector.
      询问修复机器人
      添加评论
    3. PowerBook G3 Wallstreet Keyboard Replacement: 步骤 4 中的图像 1,1
      • Disconnect the two keyboard connectors by disengaging the clamps and pulling the ribbons directly upward.
      询问修复机器人
      添加评论
    4. PowerBook G3 Wallstreet Keyboard Replacement: 步骤 5 中的图像 1,1
      • Slide a spudger downward between each plastic strain relief cable and the wall of the case in order to bow out the cable beyond the small tab holding it in place.
      • Once the strain relief cables are free, lift the keyboard off.
      询问修复机器人
      添加评论
    5. PowerBook G3 Wallstreet Keyboard Replacement: 步骤 6 中的图像 1,1
      • Your laptop should look approximately like this.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
9等其他人完成本指南。
iRobot
于09/24/09注册
1 声望
创作了636篇指南
3指南评论
The first iFixit guide?
ljcool2006 - 回复 分享
Yes sir! (text minimum)
guardian10 - 回复 分享
Yes yes yes yes
Lol - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 23
过去 30 天: 90
总计 22,500
