跳转到主内容
加入维修社区 - 创建账户
PowerBook G3 Wallstreet Hard Drive Replacement
你所需要的
    1. PowerBook G3 Wallstreet Hard Drive Replacement, Keyboard: 步骤 1 中的图像 1,1
      • Remove both expansion bay modules using the levers on the front of the computer.
      • Insert your index fingers inside the expansion bays and search for the two ribbed tabs on the underside of the upper case. The tabs are located near the bottom corners of the keyboard.
      • Pull the tabs toward yourself and the keyboard will pop up.
      询问修复机器人
      添加评论
    2. PowerBook G3 Wallstreet Hard Drive Replacement: 步骤 2 中的图像 1,1
      • Pull the keyboard forward to disengage the tabs holding it in back and rotate it toward you.
      • Rest the keyboard on the trackpad.
      询问修复机器人
      添加评论
      • This is a diagram of the ribbon clamp connectors you will disconnect in the next step.
      • 1) With your fingernails, grasp the locking bar on either side and pull up a small amount (about 1/16" or 2 mm).
      • 2) After disengaging the locking bar, slide the cable out of the connector.
      询问修复机器人
      添加评论
    3. PowerBook G3 Wallstreet Hard Drive Replacement: 步骤 4 中的图像 1,1
      • Disconnect the two keyboard connectors by disengaging the clamps and pulling the ribbons directly upward.
      询问修复机器人
      添加评论
    4. PowerBook G3 Wallstreet Hard Drive Replacement: 步骤 5 中的图像 1,1
      • Slide a spudger downward between each plastic strain relief cable and the wall of the case in order to bow out the cable beyond the small tab holding it in place.
      • Once the strain relief cables are free, lift the keyboard off.
      询问修复机器人
      添加评论
    5. PowerBook G3 Wallstreet Hard Drive Replacement: 步骤 6 中的图像 1,1
      • Your laptop should look approximately like this.
      询问修复机器人
      添加评论
    1. PowerBook G3 Wallstreet Hard Drive Replacement, Heat Shield: 步骤 7 中的图像 1,1
      • Remove the two Phillips screws from the heat shield.
      • One screw is shorter than the other. When putting the Wallstreet back together, this screw goes in the middle of the heat shield.
      询问修复机器人
      添加评论
    2. PowerBook G3 Wallstreet Hard Drive Replacement: 步骤 8 中的图像 1,1
      • Grasp the metal handle on the heat shield and pull up and toward yourself.
      询问修复机器人
      添加评论
    1. PowerBook G3 Wallstreet Hard Drive Replacement, Hard Drive: 步骤 9 中的图像 1,1
      • Unscrew, but do not remove, the single Phillips screw from the hard drive bracket.
      询问修复机器人
      添加评论
    2. PowerBook G3 Wallstreet Hard Drive Replacement: 步骤 10 中的图像 1,1
      • Grasp the hard drive bracket on the left side and pull up and to the left.
      询问修复机器人
      添加评论
    3. PowerBook G3 Wallstreet Hard Drive Replacement: 步骤 11 中的图像 1,1
      询问修复机器人
      添加评论
    1. PowerBook G3 Wallstreet Hard Drive Replacement, Hard Drive: 步骤 12 中的图像 1,1
      • Remove the four T8 Torx screws from the hard drive bracket.
      询问修复机器人
      添加评论
    2. PowerBook G3 Wallstreet Hard Drive Replacement: 步骤 13 中的图像 1,1
      • Turn the hard drive bracket over.
      • Hold the hard drive bracket at the connector end and grasp the opposite end of the hard drive.
      • Pull the hard drive out of the bracket, making sure to pull evenly on both sides.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
43等其他人完成本指南。
附加文件
iRobot
于09/24/09注册
1 声望
创作了636篇指南
3指南评论
It is much easier to remove and replace the hard drive by first removing the two T8 Torx screws on the hard drive connector at the end of the hard drive bracket (small green IC board). Less of a chance of bending the HD pins.
randy3833 - 回复 分享
You absolutely do not need to remove the keyboard ribbon cables in order to replace the hard drive. You just need to be careful and the HDD caddy will come out just fine. As someone who has had some bad experiences with ribbon cables, I prefer not to remove them unless absolutely necessary.
Talor Berthelson - 回复 分享
True! I just did the same thing, without even touching the keyboard...
oldnwstf - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 27
过去 30 天: 116
总计 24,973
