跳转到主内容
加入维修社区 - 创建账户
PowerBook G3 Wallstreet Display Replacement
你所需要的
  1. PowerBook G3 Wallstreet Display Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Remove both expansion bay modules using the levers on the front of the computer.
    • Insert your index fingers inside the expansion bays and search for the two ribbed tabs on the underside of the upper case. The tabs are located near the bottom corners of the keyboard.
    • Pull the tabs toward yourself and the keyboard will pop up.
    询问修复机器人
    添加评论
  2. PowerBook G3 Wallstreet Display Replacement: 步骤 2 中的图像 1,1
    • Pull the keyboard forward to disengage the tabs holding it in back and rotate it toward you.
    • Rest the keyboard on the trackpad.
    询问修复机器人
    添加评论
    • This is a diagram of the ribbon clamp connectors you will disconnect in the next step.
    • 1) With your fingernails, grasp the locking bar on either side and pull up a small amount (about 1/16" or 2 mm).
    • 2) After disengaging the locking bar, slide the cable out of the connector.
    询问修复机器人
    添加评论
  3. PowerBook G3 Wallstreet Display Replacement: 步骤 4 中的图像 1,1
    • Disconnect the two keyboard connectors by disengaging the clamps and pulling the ribbons directly upward.
    询问修复机器人
    添加评论
  4. PowerBook G3 Wallstreet Display Replacement: 步骤 5 中的图像 1,1
    • Slide a spudger downward between each plastic strain relief cable and the wall of the case in order to bow out the cable beyond the small tab holding it in place.
    • Once the strain relief cables are free, lift the keyboard off.
    询问修复机器人
    添加评论
  5. PowerBook G3 Wallstreet Display Replacement: 步骤 6 中的图像 1,1
    • Your laptop should look approximately like this.
    询问修复机器人
    添加评论
  6. PowerBook G3 Wallstreet Display Replacement, Heat Shield: 步骤 7 中的图像 1,1
    • Remove the two Phillips screws from the heat shield.
    • One screw is shorter than the other. When putting the Wallstreet back together, this screw goes in the middle of the heat shield.
    询问修复机器人
    添加评论
  7. PowerBook G3 Wallstreet Display Replacement: 步骤 8 中的图像 1,1
    • Grasp the metal handle on the heat shield and pull up and toward yourself.
    询问修复机器人
    添加评论
  8. PowerBook G3 Wallstreet Display Replacement, Hard Drive: 步骤 9 中的图像 1,1
    • Unscrew, but do not remove, the single Phillips screw from the hard drive bracket.
    询问修复机器人
    添加评论
  9. PowerBook G3 Wallstreet Display Replacement: 步骤 10 中的图像 1,1
    • Grasp the hard drive bracket on the left side and pull up and to the left.
    询问修复机器人
    添加评论
  10. PowerBook G3 Wallstreet Display Replacement: 步骤 11 中的图像 1,1
    询问修复机器人
    添加评论
  11. PowerBook G3 Wallstreet Display Replacement, Processor: 步骤 12 中的图像 1,1
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
    • Remove the processor by sliding it up and to the right.
    • The processor and RAM can be removed as a unit. It is not necessary to remove the RAM from the processor.
    • There are two tabs on the left side of the processor that fit into slots on the metal framework. Make sure these tabs are in the slots.
    询问修复机器人
    添加评论
  12. PowerBook G3 Wallstreet Display Replacement, Modem: 步骤 13 中的图像 1,1
    • Remove the single Phillips screw from the modem.
    • Disconnect the orange PMU cable by pulling it directly up.
    询问修复机器人
    添加评论
  13. PowerBook G3 Wallstreet Display Replacement: 步骤 14 中的图像 1,1
    • Disconnect the modem from the logic board by lifting up on the right side using a spudger, the tip of your finger, or a flat non-metal tool.
    • Remove the modem by sliding it up and to the right.
    询问修复机器人
    添加评论
  14. PowerBook G3 Wallstreet Display Replacement: 步骤 15 中的图像 1,1
    询问修复机器人
    添加评论
  15. PowerBook G3 Wallstreet Display Replacement, Clutch Cover: 步骤 16 中的图像 1,1
    • Push the display back so that it lies flat.
    • Slip a spudger or your index finger under the clutch cover near the power button and pull upward until you feel it come free.
    • Repeat the previous step on the left side.
    询问修复机器人
    添加评论
  16. PowerBook G3 Wallstreet Display Replacement: 步骤 17 中的图像 1,1
    • Lift the clutch cover off by rotating it up and then toward you.
    询问修复机器人
    添加评论
  17. PowerBook G3 Wallstreet Display Replacement, Display: 步骤 18 中的图像 1,1
    • Disconnect the orange display data cable on the left side of the computer. Grasp the cable near the connector and pull directly up.
    询问修复机器人
    添加评论
  18. PowerBook G3 Wallstreet Display Replacement: 步骤 19 中的图像 1,1
    • Disconnect the orange display inverter cable on the right side of the computer. Grasp the cable near the connector and pull directly up.
    • Make sure that both cables are free from the plastic casing before proceeding to the next step.
    询问修复机器人
    添加评论
  19. PowerBook G3 Wallstreet Display Replacement: 步骤 20 中的图像 1,1
    • Turn the laptop around so that its back faces you.
    • Open the port door located at the back of the laptop.
    • Remove the four black T8 Torx screws.
    询问修复机器人
    添加评论
  20. PowerBook G3 Wallstreet Display Replacement: 步骤 21 中的图像 1,1
    • Turn the laptop back around so that the screen faces you.
    • Adjust the display so that it is in a vertical position.
    • Hold the display on both sides and pull directly up until its hinges are free of their mounts
    询问修复机器人
    添加评论
  21. PowerBook G3 Wallstreet Display Replacement: 步骤 22 中的图像 1,1
    • Your laptop should look like this.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
8等其他人完成本指南。
附加文件
iRobot
于09/24/09注册
1 声望
创作了636篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 71
总计 9,922
