跳转到主内容
加入维修社区 - 创建账户
PowerBook G3 Pismo PRAM Battery Replacement
你所需要的
    1. PowerBook G3 Pismo PRAM Battery Replacement, Keyboard: 步骤 1 中的图像 1,1
      • Turn the keyboard locking screw so that it is parallel to the space bar.
      • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
      • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the track pad.
      询问修复机器人
      添加评论
    2. PowerBook G3 Pismo PRAM Battery Replacement: 步骤 2 中的图像 1,1
      • Pull the keyboard ribbon straight up from the logic board. Place the keyboard aside.
      • The connector may be tight. Gently rock the connector from side to side while pulling directly upward to free it. You can use this technique on many of the cards and cables you'll be disconnecting.
      • Make sure you have removed the laptop battery and CD/DVD modules from the expansion bays before proceeding.
      询问修复机器人
      添加评论
    3. PowerBook G3 Pismo PRAM Battery Replacement: 步骤 3 中的图像 1,1
      • Your laptop should look approximately like this.
      询问修复机器人
      添加评论
    1. PowerBook G3 Pismo PRAM Battery Replacement, Heat Shield: 步骤 4 中的图像 1,1
      • Remove the two silver Phillips #1 screws that attach the heat shield to the internal metal framework.
      • Lift the heat shield up and pull it toward you.
      添加评论
    2. PowerBook G3 Pismo PRAM Battery Replacement: 步骤 5 中的图像 1,1
      询问修复机器人
      添加评论
    1. PowerBook G3 Pismo PRAM Battery Replacement, Airport Card: 步骤 6 中的图像 1,1
      • Skip this step if your computer does not have an Airport card installed.
      • Firmly grasp the plastic tab attached to the Airport card and pull up and then to the right.
      • The Airport card is still attached to the antenna cable, so don't just yank it out of the slot.
      添加评论
    2. PowerBook G3 Pismo PRAM Battery Replacement: 步骤 7 中的图像 1,1
      • Disconnect the antenna cable from the Airport card.
      添加评论
    1. PowerBook G3 Pismo PRAM Battery Replacement, PRAM Battery: 步骤 8 中的图像 1,1
      • Pull the battery cable directly up from the logic board.
      • Remove the battery from its holder by pulling up and to the left.
      询问修复机器人
      添加评论
    2. PowerBook G3 Pismo PRAM Battery Replacement: 步骤 9 中的图像 1,1
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
27等其他人完成本指南。
附加文件
iRobot
于09/24/09注册
1 声望
创作了635篇指南
6指南评论
Frankly speaking I do not have idea why do I need steps 2-7 to replace battery? Why I can't go directly to step 8 if it is possible? BTW - the battery seems to be composed from 4 standard batteries. Is anyone aware how to assembly new battery? It is not available as spare part (616-0108)
Tomek - 回复 分享
Agreed, I just successfully removed my PRAM battery skipping all those steps, just popped the keyboard out, removed the DVD drive from the right-hand out and popped that bad boy out, no problemo.
Edward Gain - 回复 分享
I read that you "removed the DVD drive from the right-hand out...." I'm baffled as to what you mean or how that is done. Can you explain that step?
Scott Kohanek - 回复 分享
Why do I need to remove the airport card? It's just like telling somebody to remove their shoes to take off their hat?
christopher Ng - 回复 分享
Wish I had read the comments before proceeding. Just removed the Airport card and put it back in for no reason. Thanks for the instructions though.
j.boersma - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 16
过去 30 天: 83
总计 42,245
