跳转到主内容
加入维修社区 - 创建账户
PowerBook G3 Lombard Processor Replacement
你所需要的
  1. PowerBook G3 Lombard Processor Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Turn the computer so that the ports are facing you.
    • If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
    询问修复机器人
    添加评论
  2. PowerBook G3 Lombard Processor Replacement: 步骤 2 中的图像 1,1
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Make sure you have removed the laptop battery and CD/DVD module from the expansion bays before proceeding.
    询问修复机器人
    添加评论
  3. PowerBook G3 Lombard Processor Replacement: 步骤 3 中的图像 1,1
    • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the trackpad.
    • In order to replace the keyboard, you must first remove the modem.
    询问修复机器人
    添加评论
  4. PowerBook G3 Lombard Processor Replacement, Heat Shield: 步骤 4 中的图像 1,1
    • Remove the three silver Phillips screws that attach the heat shield to the internal metal framework.
    询问修复机器人
    添加评论
  5. PowerBook G3 Lombard Processor Replacement: 步骤 5 中的图像 1,1
    • Lift the heat shield up and pull it toward you.
    询问修复机器人
    添加评论
  6. PowerBook G3 Lombard Processor Replacement: 步骤 6 中的图像 1,1
    • Your laptop should look approximately like this.
    询问修复机器人
    添加评论
  7. PowerBook G3 Lombard Processor Replacement, PRAM Battery: 步骤 7 中的图像 1,1
    • Pull the battery cable directly up from the logic board.
    询问修复机器人
    添加评论
  8. PowerBook G3 Lombard Processor Replacement: 步骤 8 中的图像 1,1
    • Remove the battery from its holder by pulling up and to the left.
    询问修复机器人
    添加评论
  9. PowerBook G3 Lombard Processor Replacement, Modem: 步骤 9 中的图像 1,1
    • Remove the two silver Phillips screws from the modem.
    添加评论
  10. PowerBook G3 Lombard Processor Replacement: 步骤 10 中的图像 1,1
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to get under the modem's edge and pry it up from its socket as shown in the picture.
    询问修复机器人
    添加评论
  11. PowerBook G3 Lombard Processor Replacement: 步骤 11 中的图像 1,1
    • Disconnect the cable from the right side of the modem.
    询问修复机器人
    添加评论
  12. PowerBook G3 Lombard Processor Replacement: 步骤 12 中的图像 1,1
    询问修复机器人
    添加评论
  13. PowerBook G3 Lombard Processor Replacement, Processor: 步骤 13 中的图像 1,1
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
    询问修复机器人
    添加评论
  14. PowerBook G3 Lombard Processor Replacement: 步骤 14 中的图像 1,1
    • Disconnect the keyboard cable from the logic board by pulling directly up on the clear plastic loop.
    • This step is out of sequence with the keyboard because in order to remove the keyboard you must first remove the modem.
    询问修复机器人
    添加评论
  15. PowerBook G3 Lombard Processor Replacement: 步骤 15 中的图像 1,1
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
5等其他人完成本指南。
附加文件
iRobot
于09/24/09注册
1 声望
创作了636篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 39
总计 6,389
