跳转到主内容
加入维修社区 - 创建账户
PowerBook G3 Lombard PRAM Battery Replacement
你所需要的
    1. PowerBook G3 Lombard PRAM Battery Replacement, Keyboard: 步骤 1 中的图像 1,1
      • Turn the computer so that the ports are facing you.
      • If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
      询问修复机器人
      添加评论
    2. PowerBook G3 Lombard PRAM Battery Replacement: 步骤 2 中的图像 1,1
      • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
      • Make sure you have removed the laptop battery and CD/DVD module from the expansion bays before proceeding.
      询问修复机器人
      添加评论
    3. PowerBook G3 Lombard PRAM Battery Replacement: 步骤 3 中的图像 1,1
      • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the trackpad.
      • In order to replace the keyboard, you must first remove the modem.
      询问修复机器人
      添加评论
    1. PowerBook G3 Lombard PRAM Battery Replacement, PRAM Battery: 步骤 4 中的图像 1,1
      • Pull the battery cable directly up from the logic board.
      询问修复机器人
      添加评论
    2. PowerBook G3 Lombard PRAM Battery Replacement: 步骤 5 中的图像 1,1
      • Remove the battery from its holder by pulling up and to the left.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
5等其他人完成本指南。
附加文件
iRobot
于09/24/09注册
1 声望
创作了636篇指南
2指南评论
Step 4, 5 and 6 are useless for changing the PRAM battery..
Godzil - 回复 分享
Seems the step I was referring to are no longer there!
Godzil - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 50
总计 11,813
