跳转到主内容
加入维修社区 - 创建账户
PowerBook G3 Lombard Hard Drive Replacement
你所需要的
    1. PowerBook G3 Lombard Hard Drive Replacement, Keyboard: 步骤 1 中的图像 1,1
      • Turn the computer so that the ports are facing you.
      • If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
      询问修复机器人
      添加评论
    2. PowerBook G3 Lombard Hard Drive Replacement: 步骤 2 中的图像 1,1
      • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
      • Make sure you have removed the laptop battery and CD/DVD module from the expansion bays before proceeding.
      询问修复机器人
      添加评论
    3. PowerBook G3 Lombard Hard Drive Replacement: 步骤 3 中的图像 1,1
      • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the trackpad.
      • In order to replace the keyboard, you must first remove the modem.
      询问修复机器人
      添加评论
    1. PowerBook G3 Lombard Hard Drive Replacement, Heat Shield: 步骤 4 中的图像 1,1
      • Remove the three silver Phillips screws that attach the heat shield to the internal metal framework.
      询问修复机器人
      添加评论
    2. PowerBook G3 Lombard Hard Drive Replacement: 步骤 5 中的图像 1,1
      • Lift the heat shield up and pull it toward you.
      询问修复机器人
      添加评论
    3. PowerBook G3 Lombard Hard Drive Replacement: 步骤 6 中的图像 1,1
      • Your laptop should look approximately like this.
      询问修复机器人
      添加评论
    1. PowerBook G3 Lombard Hard Drive Replacement, Modem: 步骤 7 中的图像 1,1
      • Remove the two silver Phillips screws from the modem.
      添加评论
    2. PowerBook G3 Lombard Hard Drive Replacement: 步骤 8 中的图像 1,1
      • Use a spudger, the tips of your fingers, or a flat non-metal tool to get under the modem's edge and pry it up from its socket as shown in the picture.
      询问修复机器人
      添加评论
    3. PowerBook G3 Lombard Hard Drive Replacement: 步骤 9 中的图像 1,1
      • Disconnect the cable from the right side of the modem.
      询问修复机器人
      添加评论
    4. PowerBook G3 Lombard Hard Drive Replacement: 步骤 10 中的图像 1,1
      询问修复机器人
      添加评论
    1. PowerBook G3 Lombard Hard Drive Replacement, Processor: 步骤 11 中的图像 1,1
      • Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
      询问修复机器人
      添加评论
    2. PowerBook G3 Lombard Hard Drive Replacement: 步骤 12 中的图像 1,1
      • Disconnect the keyboard cable from the logic board by pulling directly up on the clear plastic loop.
      • This step is out of sequence with the keyboard because in order to remove the keyboard you must first remove the modem.
      询问修复机器人
      添加评论
    3. PowerBook G3 Lombard Hard Drive Replacement: 步骤 13 中的图像 1,1
      询问修复机器人
      添加评论
    1. PowerBook G3 Lombard Hard Drive Replacement, Hard Drive: 步骤 14 中的图像 1,1
      • Grasp the orange cable at the left end of the hard drive and disconnect it from the logic board.
      • Try to grasp the cable on the plastic connector rather than on the flexible cable section.
      询问修复机器人
      添加评论
    2. PowerBook G3 Lombard Hard Drive Replacement: 步骤 15 中的图像 1,1
      • Grasp the plastic tab and pull the hard drive up and to the left, making sure that the metal bracket doesn't catch on the black plastic casing.
      询问修复机器人
      添加评论
    1. PowerBook G3 Lombard Hard Drive Replacement, Hard Drive: 步骤 16 中的图像 1,1
      • Remove the four black Torx screws located at the four corners of the hard drive bracket.
      询问修复机器人
      添加评论
    2. PowerBook G3 Lombard Hard Drive Replacement: 步骤 17 中的图像 1,1
      • Pull the connector cable out from the hard drive, applying even pressure while gently rocking up and down.
      • Be very careful to apply even pressure when removing the cable. If you torque too hard to either side, you may damage or destroy the hard drive's connector pins, rendering your data inaccessible.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
10等其他人完成本指南。
附加文件
iRobot
于09/24/09注册
1 声望
创作了636篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 50
总计 13,027
