跳转到主内容
PowerA Fusion Controller For Xbox One Motherboard Replacement
你所需要的
  1. PowerA Fusion Controller For Xbox One Motherboard Replacement, Vibration Motors: 步骤 1 中的图像 1,3 PowerA Fusion Controller For Xbox One Motherboard Replacement, Vibration Motors: 步骤 1 中的图像 2,3 PowerA Fusion Controller For Xbox One Motherboard Replacement, Vibration Motors: 步骤 1 中的图像 3,3
    • Remove the nine 9.2mm screws with a JIS #1 screwdriver.
    • Remove the two bottom plastic grip covers.
  2. PowerA Fusion Controller For Xbox One Motherboard Replacement: 步骤 2 中的图像 1,2 PowerA Fusion Controller For Xbox One Motherboard Replacement: 步骤 2 中的图像 2,2
    • Remove the two 9.2mm screws with a JIS #1 screwdriver.
    • Remove the back cover of the controller.
  3. PowerA Fusion Controller For Xbox One Motherboard Replacement: 步骤 3 中的图像 1,2 PowerA Fusion Controller For Xbox One Motherboard Replacement: 步骤 3 中的图像 2,2
    • Take off the glue that is on top of the soldered joints with a sprudger.
    • Desolder the soldered joints of the red and black wires that are connecting the vibration motors to the motherboard.
    • Remove the vibration motors and put them aside.
    • This guide will show how to solder and desolder connections.
  4. PowerA Fusion Controller For Xbox One Motherboard Replacement, Motherboard: 步骤 4 中的图像 1,3 PowerA Fusion Controller For Xbox One Motherboard Replacement, Motherboard: 步骤 4 中的图像 2,3 PowerA Fusion Controller For Xbox One Motherboard Replacement, Motherboard: 步骤 4 中的图像 3,3
    • Remove the five 9.2mm screws with a JIS #1 screwdriver. Indicated by the red circles.
    • Lift the motherboard and let it hang.
  5. PowerA Fusion Controller For Xbox One Motherboard Replacement: 步骤 5 中的图像 1,2 PowerA Fusion Controller For Xbox One Motherboard Replacement: 步骤 5 中的图像 2,2
    • Remove the four 9.2mm screws that are holding the D-Pad to the controller housing. Indicated by the red circles.
    • Remove the motherboard.
结论
另外一个人完成了本指南。
Andrea
于09/26/17注册
668 声望
创作了4篇指南
团队
USF Tampa, Team S14-G4, Boczar Fall 2017 USF Tampa, Team S14-G4, Boczar Fall 2017 的会员
USFT-BOCZAR-F17S14G4
4 名成员
创作了7篇指南
1指南评论
Hi I have a powera fusion controler model CPFA115315-02 and I took the controller apart to clean and I forgot how the lb rb button springs go, I look on the internet and couldn't find anything. Any help would be great
Thanks
Nhgamer - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 16
过去 30 天: 51
总计 3,591
