简介
If you need to replace the grip of your Porter-Cable PCE211 impact wrench, follow this guide. You'll need to remove the grip to access the switch as well.
Be sure to turn off the device and unplug from the power source prior to beginning this repair.
你所需要的
Using the Hex Security SAE 7/32", remove the four 10 mm socket screws at the base of the gearcase.
另外一个人完成了本指南。
