跳转到主内容
加入维修社区 - 创建账户
Porter Cable 690LR Power Switch Replacement
你所需要的
    1. Porter Cable 690LR Power Switch Replacement, Power Switch: 步骤 1 中的图像 1,2 Porter Cable 690LR Power Switch Replacement, Power Switch: 步骤 1 中的图像 2,2
      • Use a Torx screwdriver to unscrew the 25.4 mm screws found at the top of the model.
      询问修复机器人
      添加评论
    2. Porter Cable 690LR Power Switch Replacement: 步骤 2 中的图像 1,2 Porter Cable 690LR Power Switch Replacement: 步骤 2 中的图像 2,2
      • Remove the top by gently lifting the cover from router body.
      • Be careful when pulling the top from its place; wires connect the switch to the electrical cord and could be pulled loose or damaged.
      询问修复机器人
      添加评论
    3. Porter Cable 690LR Power Switch Replacement: 步骤 3 中的图像 1,1
      • Use a spudger to pull off the plastic covering of the power switch.
      • Don’t be afraid to really pry underneath the plastic (no components of the router will be damaged if you do so).
      询问修复机器人
      添加评论
    4. Porter Cable 690LR Power Switch Replacement: 步骤 4 中的图像 1,1
      • Push the power switch through the top of the router. The power switch should now be completely detached from the router (besides the wire connections).
      询问修复机器人
      添加评论
    5. Porter Cable 690LR Power Switch Replacement: 步骤 5 中的图像 1,2 Porter Cable 690LR Power Switch Replacement: 步骤 5 中的图像 2,2
      • Find the wire plugs which are attached to the power switch. These connections are located at the back of the plastic box that houses the switch.
      • Use the spudger to carefully loosen the metal and rubber coverings, and detach the connections from the switch.
      • While some force is needed in order to successfully pull the connections free, have care in making sure that you don’t damage any of the metal components. If needed you may carefully use a metal spudger instead of a plastic opening tool.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
Cal Poly, Team 20-7, Livingston Fall 2016 Cal Poly, Team 20-7, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S20G7
4 名成员
创作了30篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 17
总计 1,259
