跳转到主内容
加入维修社区 - 创建账户
Polycom SoundStation Microphone Replacement
你所需要的
    1. Polycom SoundStation Microphone Replacement, Back Housing: 步骤 1 中的图像 1,1
      • Flip the device over. Using a Phillips #00 screwdriver, remove the black 10mm screw on each three legs of the phone.
      • Using a Phillips #00 screwdriver, remove the two silver 7mm screws as pictured.
      询问修复机器人
      添加评论
    2. Polycom SoundStation Microphone Replacement: 步骤 2 中的图像 1,2 Polycom SoundStation Microphone Replacement: 步骤 2 中的图像 2,2
      • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing off!
      询问修复机器人
      添加评论
    1. Polycom SoundStation Microphone Replacement, Microphone: 步骤 3 中的图像 1,1
      • Gently remove the yellow padding that covers the red and gray microphone wire on each phone leg.
      询问修复机器人
      添加评论
    2. Polycom SoundStation Microphone Replacement: 步骤 4 中的图像 1,2 Polycom SoundStation Microphone Replacement: 步骤 4 中的图像 2,2
      • Gently pull up on the black plastic tab connected to the motherboard to disconnect each microphone.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
2指南评论
Does anyone know where to purchase replacement microphones for Soundstation 100's? And if replacing mic's does not resolve the problem, are there any other solutions to address the issue of one's voice starting to drop out after about 10 minutes into a call? Thx
working ideas - 回复 分享
I encountered an older version. Padding pieces are black. Microphones soldered on board with black & red wires, no plastic tab to disconnect
Putting the thing back together proved to be a challenge : the little display came apart and started shifting all over. Getting that one aligned inside while closing the thing with my fat fingers… . Nasty.
Hans Deseure - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 31
总计 2,527
