跳转到主内容
Polaroid i835 LCD Replacement
你所需要的
  1. Polaroid i835 LCD Replacement, LCD: 步骤 1 中的图像 1,3 Polaroid i835 LCD Replacement, LCD: 步骤 1 中的图像 2,3 Polaroid i835 LCD Replacement, LCD: 步骤 1 中的图像 3,3
    • remove the batteries, the memory card as well as the carrying strip (if so equipped).
    • Remove the 2 screws on the right hand side.
    • Remove the 2 screws on the left hand side.
  2. Polaroid i835 LCD Replacement: 步骤 2 中的图像 1,3 Polaroid i835 LCD Replacement: 步骤 2 中的图像 2,3 Polaroid i835 LCD Replacement: 步骤 2 中的图像 3,3
    • One more screw on the bottom, underneath the manufacturer's label.
    • Start spitting the case from the battery compartment. You can use a plastic opening tool, or your finger nails. It does bind a bit at the USB port side, but will separate pretty quick.
    • With the back removed, the large LCD becomes immediately visible. There are no fasteners, it just rests inside the tray.
  3. Polaroid i835 LCD Replacement: 步骤 3 中的图像 1,2 Polaroid i835 LCD Replacement: 步骤 3 中的图像 2,2
    • Lift the LCD out of the tray and move it to the right of the tray. The cable is still attached to the logic board via a latch.
    • With the plastic opening tool, or your fingernails, gently flip the latch to the left side. This will free the LCD cable. Remove the LCD and install your new one.
结论
oldturkey03
于09/29/10注册
783,763 声望
创作了119篇指南
团队
Global Fixers Global Fixers 的会员
Community
33 名成员
创作了551篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 17
总计 1,121
