跳转到主内容
加入维修社区 - 创建账户
Polaroid Automatic 100 Bottom Frame Spring Replacement
你所需要的
    1. Polaroid Automatic 100 Bottom Frame Spring Replacement, Bottom Frame Spring Replacement: 步骤 1 中的图像 1,3 Polaroid Automatic 100 Bottom Frame Spring Replacement, Bottom Frame Spring Replacement: 步骤 1 中的图像 2,3 Polaroid Automatic 100 Bottom Frame Spring Replacement, Bottom Frame Spring Replacement: 步骤 1 中的图像 3,3
      • Fully extend the bellows to prevent collapse using the #1 tab.
      • Remove the camera cover in order to make the camera easier to work with.
      • When collapsing bellows, press down on the metal frame above the bellows.
      询问修复机器人
      添加评论
    2. Polaroid Automatic 100 Bottom Frame Spring Replacement: 步骤 2 中的图像 1,1
      • Remove the Phillips #0 6mm screw on the shutter mount and the washers using a size 5 nut driver.
      询问修复机器人
      添加评论
    3. Polaroid Automatic 100 Bottom Frame Spring Replacement: 步骤 3 中的图像 1,1
      • Unscrew the 4.5 mm Phillips screw on the right with a Phillips #0 Screwdriver.
      询问修复机器人
      添加评论
    4. Polaroid Automatic 100 Bottom Frame Spring Replacement: 步骤 4 中的图像 1,3 Polaroid Automatic 100 Bottom Frame Spring Replacement: 步骤 4 中的图像 2,3 Polaroid Automatic 100 Bottom Frame Spring Replacement: 步骤 4 中的图像 3,3
      • Remove the spring from the shutter mount.
      • The hooks on the ends of the spring within the shutter mount may recoil when being removed, and may be sharp enough to puncture skin.
      • When reassembling, getting the smaller screw on the right hand side can be challenging. It may be helpful to tip the camera upside down so that gravity helps the screw fall into place.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
Katie Miller
于04/14/15注册
680 声望
创作了5篇指南
团队
Cal Poly, Team 4-3, Maness Spring 2015 Cal Poly, Team 4-3, Maness Spring 2015 的会员
CPSU-MANESS-S15S4G3
4 名成员
创作了16篇指南
2指南评论
Thank you so very much!!!
You saved my camera and my sanity!!!!
CAROL HOLDER - 回复 分享
Has anyone ever had to replace their bellows with a new one? If so, where do I get one from?
sbenite - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 40
总计 1,579
