跳转到主内容
加入维修社区 - 创建账户
Polaroid Automatic 100 Bellows Replacement
你所需要的
    1. Polaroid Automatic 100 Bellows Replacement, Bellows: 步骤 1 中的图像 1,3 Polaroid Automatic 100 Bellows Replacement, Bellows: 步骤 1 中的图像 2,3 Polaroid Automatic 100 Bellows Replacement, Bellows: 步骤 1 中的图像 3,3
      • Fully extend the bellows by lifting the #1 lever.
      • Remove the camera cover in order to make the camera easier to work with.
      • When collapsing bellows, press down on the metal frame above the bellows.
      询问修复机器人
      添加评论
    2. Polaroid Automatic 100 Bellows Replacement: 步骤 2 中的图像 1,1
      • Peel the two battery cable tabs off of the bellows.
      询问修复机器人
      添加评论
    3. Polaroid Automatic 100 Bellows Replacement: 步骤 3 中的图像 1,1
      在这个步骤中使用的工具:
      Flathead 3/32" or 2.5 mm Screwdriver
      $5.49
      • Remove one 15.5 mm flat head screw, with a 2.5 flathead screwdriver.
      • Remove two 2 mm flat head screws, with a 2.5 flathead screwdriver. Then carefully remove the cable cover.
      • Use the focus bar to extend bellows even further to access screws easier with the screwdriver.
      询问修复机器人
      添加评论
    4. Polaroid Automatic 100 Bellows Replacement: 步骤 4 中的图像 1,2 Polaroid Automatic 100 Bellows Replacement: 步骤 4 中的图像 2,2
      • Open the back cover by pushing the lever on the bottom towards the left.
      询问修复机器人
      添加评论
    5. Polaroid Automatic 100 Bellows Replacement: 步骤 5 中的图像 1,1
      • Remove the four 3 mm screws, which are attached to the lens of the camera, using a Phillips #0 screwdriver.
      • To make the screws easily accessible, close the bellows by pushing on the metal frame.
      • When reassembling, orient the camera so that screws are screwed in downward and stay in place.
      询问修复机器人
      添加评论
    6. Polaroid Automatic 100 Bellows Replacement: 步骤 6 中的图像 1,1
      • Carefully use a classic wide metal spudger to bend the tabs of the bellows.
      询问修复机器人
      添加评论
    7. Polaroid Automatic 100 Bellows Replacement: 步骤 7 中的图像 1,2 Polaroid Automatic 100 Bellows Replacement: 步骤 7 中的图像 2,2
      • Pull the bellow tabs back with long needle nose pliers.
      • Remove the bellows.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
Katie Miller
于04/14/15注册
680 声望
创作了5篇指南
团队
Cal Poly, Team 4-3, Maness Spring 2015 Cal Poly, Team 4-3, Maness Spring 2015 的会员
CPSU-MANESS-S15S4G3
4 名成员
创作了26篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 38
总计 2,763
