跳转到主内容
加入维修社区 - 创建账户
Polaroid A10 Front/Back Camera Replacement
你所需要的
    1. Polaroid A10 Front/Back Camera Replacement, Back Cover: 步骤 1 中的图像 1,3 Polaroid A10 Front/Back Camera Replacement, Back Cover: 步骤 1 中的图像 2,3 Polaroid A10 Front/Back Camera Replacement, Back Cover: 步骤 1 中的图像 3,3
      • Begin by having the side with volume and power button face up towards you.
      • Insert a plastic opening tool between the display and the back cover.
      • Once you have one plastic opening tool in, you can insert another one. While holding one in place, slide the other along the gap to release the tabs.
      • It is easier to remove the back cover, if the display screen is faced down.
      • The tabs must be released from all four sides before removing the back cover.
      询问修复机器人
      添加评论
    1. Polaroid A10 Front/Back Camera Replacement, Battery: 步骤 2 中的图像 1,3 Polaroid A10 Front/Back Camera Replacement, Battery: 步骤 2 中的图像 2,3 Polaroid A10 Front/Back Camera Replacement, Battery: 步骤 2 中的图像 3,3
      在这个步骤中使用的工具:
      Plastic Cards
      $2.99
      • Begin by inserting the flat end of a spudger underneath the battery to separate the glue from the battery.
      • It is better to use a plastic card if you have one.
      • Gently lift up the battery as you continue to separate the glue from the battery.
      • Lift up just enough to see where the glue is, so that you don't bend the battery.
      • Once the glue has been separated, gently lift up the battery and you will notice two wires attached to the motherboard.
      询问修复机器人
      添加评论
    2. Polaroid A10 Front/Back Camera Replacement: 步骤 3 中的图像 1,3 Polaroid A10 Front/Back Camera Replacement: 步骤 3 中的图像 2,3 Polaroid A10 Front/Back Camera Replacement: 步骤 3 中的图像 3,3
      询问修复机器人
      添加评论
    3. Polaroid A10 Front/Back Camera Replacement: 步骤 4 中的图像 1,1
      • Gently lift the battery up and out of the device.
      询问修复机器人
      添加评论
    1. Polaroid A10 Front/Back Camera Replacement, Front/Back Camera: 步骤 5 中的图像 1,1
      • The camera head is located on the upper middle section of the device, close to the battery.
      询问修复机器人
      添加评论
    2. Polaroid A10 Front/Back Camera Replacement: 步骤 6 中的图像 1,2 Polaroid A10 Front/Back Camera Replacement: 步骤 6 中的图像 2,2
      • Start by locating the two left and right screws which hold the camera head in place.
      • Using the Phillip's 000 screwdriver, remove the two 7 mm screws located in the picture by rotating the screw counter-clockwise.
      询问修复机器人
      添加评论
    3. Polaroid A10 Front/Back Camera Replacement: 步骤 7 中的图像 1,3 Polaroid A10 Front/Back Camera Replacement: 步骤 7 中的图像 2,3 Polaroid A10 Front/Back Camera Replacement: 步骤 7 中的图像 3,3
      • Locate the camera ribbon cable that is connected to the motherboard.
      • With a spudger, remove the camera ribbon cable base from the motherboard connector.
      • With one finger, delicately remove the camera ribbon cable by sliding down.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
UW Tacoma, Team 3-3, Rose Winter 2015 UW Tacoma, Team 3-3, Rose Winter 2015 的会员
UWT-ROSE-W15S3G3
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 33
总计 532
