跳转到主内容
加入维修社区 - 创建账户
Polaroid A10 Battery Replacement
你所需要的
    1. Polaroid A10 Battery Replacement, Back Cover: 步骤 1 中的图像 1,3 Polaroid A10 Battery Replacement, Back Cover: 步骤 1 中的图像 2,3 Polaroid A10 Battery Replacement, Back Cover: 步骤 1 中的图像 3,3
      • Begin by having the side with volume and power button face up towards you.
      • Insert a plastic opening tool between the display and the back cover.
      • Once you have one plastic opening tool in, you can insert another one. While holding one in place, slide the other along the gap to release the tabs.
      • It is easier to remove the back cover, if the display screen is faced down.
      • The tabs must be released from all four sides before removing the back cover.
      询问修复机器人
      添加评论
    1. Polaroid A10 Battery Replacement, Battery: 步骤 2 中的图像 1,3 Polaroid A10 Battery Replacement, Battery: 步骤 2 中的图像 2,3 Polaroid A10 Battery Replacement, Battery: 步骤 2 中的图像 3,3
      在这个步骤中使用的工具:
      Plastic Cards
      $2.99
      • Begin by inserting the flat end of a spudger underneath the battery to separate the glue from the battery.
      • It is better to use a plastic card if you have one.
      • Gently lift up the battery as you continue to separate the glue from the battery.
      • Lift up just enough to see where the glue is, so that you don't bend the battery.
      • Once the glue has been separated, gently lift up the battery and you will notice two wires attached to the motherboard.
      询问修复机器人
      添加评论
    2. Polaroid A10 Battery Replacement: 步骤 3 中的图像 1,3 Polaroid A10 Battery Replacement: 步骤 3 中的图像 2,3 Polaroid A10 Battery Replacement: 步骤 3 中的图像 3,3
      询问修复机器人
      添加评论
    3. Polaroid A10 Battery Replacement: 步骤 4 中的图像 1,1
      • Gently lift the battery up and out of the device.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
armando
于01/14/15注册
150 声望
撰写一个指南
团队
UW Tacoma, Team 3-3, Rose Winter 2015 UW Tacoma, Team 3-3, Rose Winter 2015 的会员
UWT-ROSE-W15S3G3
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 23
总计 1,140
