跳转到主内容
加入维修社区 - 创建账户
Polar M400 Watch Battery Replacement
你所需要的
    1. Polar M400 Watch Battery Replacement, Wrist Strap: 步骤 1 中的图像 1,1
      • Insert a standard paper clip into the holes on both sides of the watch that connect the watch's face with the wrist strap.
      添加评论
    2. Polar M400 Watch Battery Replacement: 步骤 2 中的图像 1,2 Polar M400 Watch Battery Replacement: 步骤 2 中的图像 2,2
      在这个步骤中使用的工具:
      • Apply an upward pressure to the holes until the locking pins release.
      • Use precision tweezers to remove the pins that connect the face with the strap.
      询问修复机器人
      添加评论
    3. Polar M400 Watch Battery Replacement: 步骤 3 中的图像 1,1
      • Once the pins are released, the old wrist strap should snap off.
      • Simply lock the new wrist strap into place.
      添加评论
    1. Polar M400 Watch Battery Replacement, Battery: 步骤 4 中的图像 1,1
      • Use the T5 head on the iFixit screwdriver to unscrew the four screws on the back of the watch’s face.
      询问修复机器人
      添加评论
    2. Polar M400 Watch Battery Replacement: 步骤 5 中的图像 1,2 Polar M400 Watch Battery Replacement: 步骤 5 中的图像 2,2
      • Gently remove the backing from the watch.
      询问修复机器人
      添加评论
    3. Polar M400 Watch Battery Replacement: 步骤 6 中的图像 1,2 Polar M400 Watch Battery Replacement: 步骤 6 中的图像 2,2
      在这个步骤中使用的工具:
      • Use tweezers to gently pry the golden sensor away from the battery.
      • Remove battery using the plastic opening tools.
      添加评论
结论
取消:我没有完成这个指南。
16等其他人完成本指南。
团队
25指南评论
Hello, thanks for the details !
The most tricky part: find the right spare part. I can’t find a replacement battery that could fit the original dimensions with reasonnable capacity.
Do you have any lead?
Vincent - 回复 分享
In case if anyone is still looking for the spare part I have just replaced my M400 battery with this one: https://www.aliexpress.com/item/10050045...
Replacement instructions were detailed enough to get my watch to work again.
Roman - 回复 分享
Bonjour
Pourriez-vous m’indiquer ou je peux acheter une batterie compatible ou originale
Merci à vous
ducellier - 回复 分享
where can i buy a batery for my polar m400? Link please. Thanks
lsmi_21 - 回复 分享
Once the battery is changed, the M400 does not work. Do you have to press any combination of keys?
lojobis - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 47
过去 30 天: 166
总计 36,446
