跳转到主内容
加入维修社区 - 创建账户
PlayStation Move Trigger Button Replacement
你所需要的
    1. PlayStation Move Trigger Button Replacement, Battery: 步骤 1 中的图像 1,3 PlayStation Move Trigger Button Replacement, Battery: 步骤 1 中的图像 2,3 PlayStation Move Trigger Button Replacement, Battery: 步骤 1 中的图像 3,3
      • Using a Phillips #0 screwdriver, remove the four 10mm screws located on the back of the device.
      询问修复机器人
      添加评论
    2. PlayStation Move Trigger Button Replacement: 步骤 2 中的图像 1,2 PlayStation Move Trigger Button Replacement: 步骤 2 中的图像 2,2
      • Insert the plastic opening tool at the indent.
      • Gently use a forward and backward motion to safely pop open the cover.
      • Using your hands to further pull it apart.
      询问修复机器人
      添加评论
    3. PlayStation Move Trigger Button Replacement: 步骤 3 中的图像 1,2 PlayStation Move Trigger Button Replacement: 步骤 3 中的图像 2,2
      • Once the device is opened, lift the battery out of the black plastic holder.
      • Carefully pull the battery out and ensure that it's wires are still connected to the inside.
      添加评论
    4. PlayStation Move Trigger Button Replacement: 步骤 4 中的图像 1,3 PlayStation Move Trigger Button Replacement: 步骤 4 中的图像 2,3 PlayStation Move Trigger Button Replacement: 步骤 4 中的图像 3,3
      • Using a Phillips head screwdriver, remove the 9mm screw located to the right of the battery, which is connected to the inner plastic frame.
      • Using the plastic opening tool carefully take out the grey cylindrical piece (vibrator) that is also attached to a wire.
      询问修复机器人
      添加评论
    5. PlayStation Move Trigger Button Replacement: 步骤 5 中的图像 1,2 PlayStation Move Trigger Button Replacement: 步骤 5 中的图像 2,2
      • Gently pull out the small grey cylindrical piece (vibrator).
      • Removing this piece makes it easier to access the wire connection of the battery and remove it.
      询问修复机器人
      添加评论
    6. PlayStation Move Trigger Button Replacement: 步骤 6 中的图像 1,2 PlayStation Move Trigger Button Replacement: 步骤 6 中的图像 2,2
      在这个步骤中使用的工具:
      • Using tweezers, remove the small piece with a cylindrical top that is located to the left of the inner plastic frame.
      询问修复机器人
      添加评论
    7. PlayStation Move Trigger Button Replacement: 步骤 7 中的图像 1,3 PlayStation Move Trigger Button Replacement: 步骤 7 中的图像 2,3 PlayStation Move Trigger Button Replacement: 步骤 7 中的图像 3,3
      • Using one hand to hold the device, and the other hand to squeeze the inner plastic frame.
      • Remove by squeezing the inner plastic frame, lift and pull it towards you.
      • While removing the frame, be extremely careful because it could damage the frame or the motherboard.
      询问修复机器人
      添加评论
    8. PlayStation Move Trigger Button Replacement: 步骤 8 中的图像 1,2 PlayStation Move Trigger Button Replacement: 步骤 8 中的图像 2,2
      • Gently pull on the white piece connecting the battery and the connector.
      询问修复机器人
      添加评论
    1. PlayStation Move Trigger Button Replacement, Motherboard: 步骤 9 中的图像 1,3 PlayStation Move Trigger Button Replacement, Motherboard: 步骤 9 中的图像 2,3 PlayStation Move Trigger Button Replacement, Motherboard: 步骤 9 中的图像 3,3
      • Remove the five 1.2 mm screws from upper portion of the controller.
      • If you are replacing the trigger button, continue to step 13.
      询问修复机器人
      添加评论
    2. PlayStation Move Trigger Button Replacement: 步骤 10 中的图像 1,2 PlayStation Move Trigger Button Replacement: 步骤 10 中的图像 2,2
      • Remove the two 1.2mm Phillips #1 screws.
      询问修复机器人
      添加评论
    3. PlayStation Move Trigger Button Replacement: 步骤 11 中的图像 1,3 PlayStation Move Trigger Button Replacement: 步骤 11 中的图像 2,3 PlayStation Move Trigger Button Replacement: 步骤 11 中的图像 3,3
      • Cautiously remove the circular white piece at the top without removing the LED inside.
      添加评论
    4. PlayStation Move Trigger Button Replacement: 步骤 12 中的图像 1,3 PlayStation Move Trigger Button Replacement: 步骤 12 中的图像 2,3 PlayStation Move Trigger Button Replacement: 步骤 12 中的图像 3,3
      • Remove the blue strip that is connected to the trigger button from the motherboard.
      • Be careful to gently detach it from the motherboard. The strip may rip if too much strength is applied.
      询问修复机器人
      添加评论
    5. PlayStation Move Trigger Button Replacement: 步骤 13 中的图像 1,2 PlayStation Move Trigger Button Replacement: 步骤 13 中的图像 2,2
      • Remove the trigger button from the controller.
      询问修复机器人
      添加评论
    6. PlayStation Move Trigger Button Replacement: 步骤 14 中的图像 1,3 PlayStation Move Trigger Button Replacement: 步骤 14 中的图像 2,3 PlayStation Move Trigger Button Replacement: 步骤 14 中的图像 3,3
      • Remove the LED light by removing the white strip.
      • If you are replacing the LED light, continue to Step 17.
      添加评论
    7. PlayStation Move Trigger Button Replacement: 步骤 15 中的图像 1,2 PlayStation Move Trigger Button Replacement: 步骤 15 中的图像 2,2
      • Remove the motherboard from the plastic case.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
USF Tampa, Team 3-3, Passmore Fall 2016 USF Tampa, Team 3-3, Passmore Fall 2016 的会员
USFT-PASSMORE-F16S3G3
4 名成员
创作了44篇指南
3指南评论
This disassembly is destructive (namely to the LED connector as it is soldered to the main board) and has many unnecessary steps for simply replacing the trigger button assembly. It also says no parts are required but you would clearly need replacement trigger parts.
Peter Miller - 回复 分享
this did not help at all
lucas ainsworth - 回复 分享
I have searched a lot on the internet and cannot find any parts for it.
Dormius Oksivox - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 64
总计 3,926
