跳转到主内容
加入维修社区 - 创建账户
PlayStation 5 Slim USB-C Board Replacement
你所需要的
  1. PlayStation 5 Slim USB-C Board Replacement, Prepare your PlayStation for disassembly: 步骤 1 中的图像 1,3 PlayStation 5 Slim USB-C Board Replacement, Prepare your PlayStation for disassembly: 步骤 1 中的图像 2,3 PlayStation 5 Slim USB-C Board Replacement, Prepare your PlayStation for disassembly: 步骤 1 中的图像 3,3
    • Before starting your repair:
    • Shut down your console and unplug all cables and accessories.
    • Remove any stands supporting your device and lay it down.
  2. PlayStation 5 Slim USB-C Board Replacement, Remove the console covers: 步骤 2 中的图像 1,3 PlayStation 5 Slim USB-C Board Replacement, Remove the console covers: 步骤 2 中的图像 2,3 PlayStation 5 Slim USB-C Board Replacement, Remove the console covers: 步骤 2 中的图像 3,3
    • Each console cover is secured with hooks along the rear edge and clips along the front edge.
    • To remove a cover, firmly pull up the front edge to release the clips.
    • You'll hear distinct "pops" as the clips release.
    • Remove the cover.
  3. PlayStation 5 Slim USB-C Board Replacement: 步骤 3 中的图像 1,3 PlayStation 5 Slim USB-C Board Replacement: 步骤 3 中的图像 2,3 PlayStation 5 Slim USB-C Board Replacement: 步骤 3 中的图像 3,3
    • Use the same process to remove the three remaining covers.
    • To reinstall a cover, place the hooks into their cutouts along the rear edge and firmly press the front edge of the cover into place to re‑engage the clips.
  4. PlayStation 5 Slim USB-C Board Replacement, Remove the disc drive: 步骤 4 中的图像 1,3 PlayStation 5 Slim USB-C Board Replacement, Remove the disc drive: 步骤 4 中的图像 2,3 PlayStation 5 Slim USB-C Board Replacement, Remove the disc drive: 步骤 4 中的图像 3,3
    • If your PlayStation doesn't have a disc drive, skip this step.
    • Use the cutout on the bottom right corner of the disc drive to lift its right edge and disconnect it.
    • Remove the disc drive.
    • During reassembly, place the hooks on the left edge of the drive into their cutouts and firmly press the drive into place so the connector on the bottom right corner goes into its socket.
  5. PlayStation 5 Slim USB-C Board Replacement, Remove the expansion slot cover screw: 步骤 5 中的图像 1,2 PlayStation 5 Slim USB-C Board Replacement, Remove the expansion slot cover screw: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    FixMat
    $36.95
    • Use a Phillips screwdriver to remove the 17.1 mm‑long screw securing the expansion slot cover.
  6. PlayStation 5 Slim USB-C Board Replacement, Remove the expansion slot cover: 步骤 6 中的图像 1,3 PlayStation 5 Slim USB-C Board Replacement, Remove the expansion slot cover: 步骤 6 中的图像 2,3 PlayStation 5 Slim USB-C Board Replacement, Remove the expansion slot cover: 步骤 6 中的图像 3,3
    • Use your fingers to lift the expansion slot cover near the notch by the screw hole and remove it.
  7. PlayStation 5 Slim USB-C Board Replacement, Remove the fan cables cover: 步骤 7 中的图像 1,3 PlayStation 5 Slim USB-C Board Replacement, Remove the fan cables cover: 步骤 7 中的图像 2,3 PlayStation 5 Slim USB-C Board Replacement, Remove the fan cables cover: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    Tesa 61395 Tape
    $8.95
    • Use your fingers to remove the plastic cover hiding the fan cables connector.
    • The cover is secured with light adhesive.
    • During reassembly, press the piece of plastic back into place to secure it with the leftover adhesive. If it isn't sticking, use strips of double-sided tape to secure it.
  8. PlayStation 5 Slim USB-C Board Replacement, Free the fan cables: 步骤 8 中的图像 1,2 PlayStation 5 Slim USB-C Board Replacement, Free the fan cables: 步骤 8 中的图像 2,2
    • Gently pull the fan cables out from under their plastic clip on the frame.
  9. PlayStation 5 Slim USB-C Board Replacement, Disconnect the fan: 步骤 9 中的图像 1,3 PlayStation 5 Slim USB-C Board Replacement, Disconnect the fan: 步骤 9 中的图像 2,3 PlayStation 5 Slim USB-C Board Replacement, Disconnect the fan: 步骤 9 中的图像 3,3
    • Firmly grip the fan cables white connector head and pull it straight up and out of its socket.
    • If you're having trouble, grip the cables just above the connector head, and gently pull.
    • During reassembly, align the connector over its socket and push down on the edges with the flat end of a spudger until it slides fully into its socket.
  10. PlayStation 5 Slim USB-C Board Replacement, Remove the fan screws: 步骤 10 中的图像 1,2 PlayStation 5 Slim USB-C Board Replacement, Remove the fan screws: 步骤 10 中的图像 2,2
    • Use a T8 Torx Security screwdriver to remove the four screws securing the fan:
    • One 31.2 mm‑long screw
    • Two 21.3 mm‑long screws
    • One 11.6 mm‑long screw
  11. PlayStation 5 Slim USB-C Board Replacement, Remove the fan: 步骤 11 中的图像 1,2 PlayStation 5 Slim USB-C Board Replacement, Remove the fan: 步骤 11 中的图像 2,2
    • Use your fingers to grab the fan by its vents, and lift it straight up to remove it.
    • During reassembly:
    • This is a good point to clean the fan. Use a clean cloth and some compressed air to remove any dust or dirt.
    • Insert the fan so its cables are near their connector.
  12. PlayStation 5 Slim USB-C Board Replacement, Flip your PlayStation over: 步骤 12 中的图像 1,1
    • Flip your PlayStation over.
  13. PlayStation 5 Slim USB-C Board Replacement, Remove the power supply screws: 步骤 13 中的图像 1,2 PlayStation 5 Slim USB-C Board Replacement, Remove the power supply screws: 步骤 13 中的图像 2,2
    • Use a T8 Torx Security screwdriver to remove the two 21.3 mm‑long screws securing the power supply.
  14. PlayStation 5 Slim USB-C Board Replacement, Flip your PlayStation over: 步骤 14 中的图像 1,1
  15. PlayStation 5 Slim USB-C Board Replacement, Peel up the tamper evident sticker: 步骤 15 中的图像 1,3 PlayStation 5 Slim USB-C Board Replacement, Peel up the tamper evident sticker: 步骤 15 中的图像 2,3 PlayStation 5 Slim USB-C Board Replacement, Peel up the tamper evident sticker: 步骤 15 中的图像 3,3
    在这个步骤中使用的工具:
  16. PlayStation 5 Slim USB-C Board Replacement, Remove the right‑side inner shell screws: 步骤 16 中的图像 1,2 PlayStation 5 Slim USB-C Board Replacement, Remove the right‑side inner shell screws: 步骤 16 中的图像 2,2
    • Use a T8 Torx Security screwdriver to remove the nine screws securing the right‑side inner shell:
    • Four 18.9 mm‑long screws
    • One 21.3 mm‑long screw
    • Four 31.2 mm‑long screws
  17. PlayStation 5 Slim USB-C Board Replacement, Remove the right‑side inner shell: 步骤 17 中的图像 1,2 PlayStation 5 Slim USB-C Board Replacement, Remove the right‑side inner shell: 步骤 17 中的图像 2,2
    • Lift the right‑side inner shell straight up and remove it.
  18. PlayStation 5 Slim USB-C Board Replacement, Remove the interconnect cable cover screws: 步骤 18 中的图像 1,2 PlayStation 5 Slim USB-C Board Replacement, Remove the interconnect cable cover screws: 步骤 18 中的图像 2,2
    • Use a T8 Torx Security screwdriver to remove the four screws securing the interconnect cable cover:
    • One 28.7 mm‑long screw
    • Three 7.5 mm‑long screws
  19. PlayStation 5 Slim USB-C Board Replacement, Remove the interconnect cable cover: 步骤 19 中的图像 1,2 PlayStation 5 Slim USB-C Board Replacement, Remove the interconnect cable cover: 步骤 19 中的图像 2,2
    • Remove the interconnect cable cover.
  20. PlayStation 5 Slim USB-C Board Replacement, Disconnect the interconnect cable: 步骤 20 中的图像 1,3 PlayStation 5 Slim USB-C Board Replacement, Disconnect the interconnect cable: 步骤 20 中的图像 2,3 PlayStation 5 Slim USB-C Board Replacement, Disconnect the interconnect cable: 步骤 20 中的图像 3,3
    • Use the point of a spudger to push the interconnect cable's metal latch down and away from the connector to unlock it.
    • Keep the latch in its unlocked position and carefully pull the interconnect cable straight out of its socket.
    • During reassembly, push the latch into its unlocked position and insert the cable into its socket. Then, push the latch back in place to lock the cable.
  21. PlayStation 5 Slim USB-C Board Replacement, Disconnect the antenna cables: 步骤 21 中的图像 1,3 PlayStation 5 Slim USB-C Board Replacement, Disconnect the antenna cables: 步骤 21 中的图像 2,3 PlayStation 5 Slim USB-C Board Replacement, Disconnect the antenna cables: 步骤 21 中的图像 3,3
    • Insert a spudger under the metal neck of one of the antenna cable's coaxial connectors and lift straight up to disconnect it.
    • Repeat the process to disconnect the other antenna cable.
    • To reconnect a cable, hold the metal connector head over its socket and press down with the flat end of a spudger until the connector snaps into place. Don't try to force the connector into place. If you're having trouble, reposition the connector and try again.
  22. PlayStation 5 Slim USB-C Board Replacement, Peel up the antenna cable tape: 步骤 22 中的图像 1,2 PlayStation 5 Slim USB-C Board Replacement, Peel up the antenna cable tape: 步骤 22 中的图像 2,2
    • A piece of tape and a block of foam secure the antenna cables to the heatsink shield.
    • Gently lift both antenna cables to separate the tape from the heatsink shield.
  23. PlayStation 5 Slim USB-C Board Replacement, Peel up the antenna cable foam: 步骤 23 中的图像 1,2 PlayStation 5 Slim USB-C Board Replacement, Peel up the antenna cable foam: 步骤 23 中的图像 2,2
    • Light adhesive secures the foam block to the heatsink shield.
    • Use tweezers to gently peel up the foam block.
    • If you're having trouble, heat an iOpener and apply it to the foam for one minute to soften the adhesive. If you don't have an iOpener, you can use a hair dryer instead.
  24. PlayStation 5 Slim USB-C Board Replacement, Reposition the antenna cables: 步骤 24 中的图像 1,3 PlayStation 5 Slim USB-C Board Replacement, Reposition the antenna cables: 步骤 24 中的图像 2,3 PlayStation 5 Slim USB-C Board Replacement, Reposition the antenna cables: 步骤 24 中的图像 3,3
    • Move the antenna cables over the side of your PlayStation so they're out of the way.
    • During reassembly, use this photo as a reference to put the antenna cables back in their original position.
  25. PlayStation 5 Slim USB-C Board Replacement, Lift the main board assembly: 步骤 25 中的图像 1,2 PlayStation 5 Slim USB-C Board Replacement, Lift the main board assembly: 步骤 25 中的图像 2,2
    • The power supply is connected to the bottom of the main board assembly by metal prongs that plug into the bottom left corner.
    • Lift the bottom left corner of the main board assembly off its gray plastic post. Keep the assembly lifted for the next step.
    • Your PlayStation's plastic housing will likely flex while lifting the assembly.
  26. PlayStation 5 Slim USB-C Board Replacement, Detach the power supply: 步骤 26 中的图像 1,3 PlayStation 5 Slim USB-C Board Replacement, Detach the power supply: 步骤 26 中的图像 2,3 PlayStation 5 Slim USB-C Board Replacement, Detach the power supply: 步骤 26 中的图像 3,3
    • Keep the main board assembly raised with one hand.
    • With your free hand, insert your finger between the assembly and power supply.
    • Push down on the power supply and lift the assembly to separate them.
    • It'll take a significant amount of force to separate the two.
    • During reassembly, press down firmly on the bottom left corner of the main board assembly to fully connect it to the power supply.
  27. PlayStation 5 Slim USB-C Board Replacement, Remove the main board assembly: 步骤 27 中的图像 1,3 PlayStation 5 Slim USB-C Board Replacement, Remove the main board assembly: 步骤 27 中的图像 2,3 PlayStation 5 Slim USB-C Board Replacement, Remove the main board assembly: 步骤 27 中的图像 3,3
    • Do not grab the main board assembly by the copper heat pipes or its fins, as they can easily be damaged.
    • Firmly secure the plastic housing with one hand.
    • With your free hand, grab the upper edge of the main board assembly and lift it out of the plastic housing.
    • Make sure the interconnect cable doesn't get stuck under the main board assembly when lowering it into place.
    • Lower the assembly into its recess so its prongs go into their socket on the power supply and the three cutouts go over their alignment posts.
  28. PlayStation 5 Slim USB-C Board Replacement, Remove the power supply: 步骤 28 中的图像 1,3 PlayStation 5 Slim USB-C Board Replacement, Remove the power supply: 步骤 28 中的图像 2,3 PlayStation 5 Slim USB-C Board Replacement, Remove the power supply: 步骤 28 中的图像 3,3
    • Lift the left edge of the power supply and remove it.
    • Insert the power port into its cutout on the back of your PlayStation.
    • Lower the power supply into its recess, making sure the cutout on the bottom left corner goes over its plastic post.
  29. PlayStation 5 Slim USB-C Board Replacement, Unclip the antenna cables: 步骤 29 中的图像 1,3 PlayStation 5 Slim USB-C Board Replacement, Unclip the antenna cables: 步骤 29 中的图像 2,3 PlayStation 5 Slim USB-C Board Replacement, Unclip the antenna cables: 步骤 29 中的图像 3,3
    • Pull both antenna cables up and out of their clips along the rear edge of your PlayStation.
    • During reassembly, place the cables back into their clips on the rear edge of the frame.
  30. PlayStation 5 Slim USB-C Board Replacement: 步骤 30 中的图像 1,2 PlayStation 5 Slim USB-C Board Replacement: 步骤 30 中的图像 2,2
    • Push both antenna cables down and out from under their clip on the top right corner of the plastic housing.
  31. PlayStation 5 Slim USB-C Board Replacement, Unclip the front trim: 步骤 31 中的图像 1,2 PlayStation 5 Slim USB-C Board Replacement, Unclip the front trim: 步骤 31 中的图像 2,2
    • With one hand, secure the right edge of the plastic housing.
    • With your free hand, firmly lift the top edge of the front trim to release its three plastic clips.
    • During reassembly, push the front trim onto the frame so the clips snap into place.
  32. PlayStation 5 Slim USB-C Board Replacement, Remove the front trim: 步骤 32 中的图像 1,2 PlayStation 5 Slim USB-C Board Replacement, Remove the front trim: 步骤 32 中的图像 2,2
    • Lift the front trim straight up and remove it.
  33. PlayStation 5 Slim USB-C Board Replacement, Remove the USB-C board screw: 步骤 33 中的图像 1,3 PlayStation 5 Slim USB-C Board Replacement, Remove the USB-C board screw: 步骤 33 中的图像 2,3 PlayStation 5 Slim USB-C Board Replacement, Remove the USB-C board screw: 步骤 33 中的图像 3,3
    • Secure the front trim against your workspace so the USB-C board screws are facing up.
    • Use a Phillips screwdriver to remove the four 6.7 mm‑long screws securing the board.
  34. PlayStation 5 Slim USB-C Board Replacement, Remove the USB-C board: 步骤 34 中的图像 1,3 PlayStation 5 Slim USB-C Board Replacement, Remove the USB-C board: 步骤 34 中的图像 2,3 PlayStation 5 Slim USB-C Board Replacement, Remove the USB-C board: 步骤 34 中的图像 3,3
结论
Spencer Day
于09/14/22注册
159,414 声望
创作了1,043篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,927篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 83
过去 30 天: 460
总计 5,147
