跳转到主内容
加入维修社区 - 创建账户
PlayStation 5 Slim Fan Replacement
你所需要的
  1. PlayStation 5 Slim Fan Replacement, Prepare your PlayStation for disassembly: 步骤 1 中的图像 1,3 PlayStation 5 Slim Fan Replacement, Prepare your PlayStation for disassembly: 步骤 1 中的图像 2,3 PlayStation 5 Slim Fan Replacement, Prepare your PlayStation for disassembly: 步骤 1 中的图像 3,3
    • Before starting your repair:
    • Shut down your console and unplug all cables and accessories.
    • Remove any stands supporting your device and lay it down.
  2. PlayStation 5 Slim Fan Replacement, Lay your PlayStation down: 步骤 2 中的图像 1,1
    • Lay your PlayStation on its side so the right side covers are facing up.
  3. PlayStation 5 Slim Fan Replacement, Remove the fan and SSD cover: 步骤 3 中的图像 1,3 PlayStation 5 Slim Fan Replacement, Remove the fan and SSD cover: 步骤 3 中的图像 2,3 PlayStation 5 Slim Fan Replacement, Remove the fan and SSD cover: 步骤 3 中的图像 3,3
    • The cover is secured with hooks along the back edge and clips along the front edge.
    • Firmly pull up the front edge of the smaller, upper cover to release the clips.
    • You'll hear distinct "pops" as the clips disengage.
    • Remove the cover.
    • To reinstall the cover, place the hooks into their cutouts along the rear edge and firmly press the front edge of the cover into place to re‑engage the two clips.
  4. PlayStation 5 Slim Fan Replacement, Remove the fan cables cover: 步骤 4 中的图像 1,3 PlayStation 5 Slim Fan Replacement, Remove the fan cables cover: 步骤 4 中的图像 2,3 PlayStation 5 Slim Fan Replacement, Remove the fan cables cover: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    Tesa 61395 Tape
    $8.95
    • A piece of plastic covers the fan cables connector.
    • Use your fingers to remove the plastic cover.
    • During reassembly, press the piece of plastic back into place to secure it with the leftover adhesive. If it isn't sticking, use strips of double-sided tape to secure it.
  5. PlayStation 5 Slim Fan Replacement, Free the fan cables: 步骤 5 中的图像 1,2 PlayStation 5 Slim Fan Replacement, Free the fan cables: 步骤 5 中的图像 2,2
    • Gently pull the fan cables out from under their plastic clip on the frame.
  6. PlayStation 5 Slim Fan Replacement, Disconnect the fan: 步骤 6 中的图像 1,3 PlayStation 5 Slim Fan Replacement, Disconnect the fan: 步骤 6 中的图像 2,3 PlayStation 5 Slim Fan Replacement, Disconnect the fan: 步骤 6 中的图像 3,3
    • Firmly grip the fan cables' white connector head and pull it straight up and out of its socket.
    • If you're having trouble, grip the cables just above the connector head, and gently pull.
    • During reassembly, align the connector over its socket and push down on the edges with the flat end of a spudger until it slides fully into its socket.
  7. PlayStation 5 Slim Fan Replacement, Remove the fan screws: 步骤 7 中的图像 1,2 PlayStation 5 Slim Fan Replacement, Remove the fan screws: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    FixMat
    $36.95
    • Use a T8 Torx Security screwdriver to remove the four screws securing the fan:
    • One 31.2 mm‑long screw
    • Two 21.3 mm‑long screws
    • One 11.6 mm‑long screw
  8. PlayStation 5 Slim Fan Replacement, Remove the fan: 步骤 8 中的图像 1,2 PlayStation 5 Slim Fan Replacement, Remove the fan: 步骤 8 中的图像 2,2
    • Use your fingers to grab the fan by its vents and lift it straight up to remove it.
    • If you're using this guide to clean your fan, use compressed air and a clean cloth to remove any dust or dirt.
    • During reassembly, insert the fan so its cables are near their connector.
结论
17等其他人完成本指南。
Spencer Day
于09/14/22注册
182,639 声望
创作了1,165篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了25,504篇指南
1指南评论
Cooling Fan Replacement For Sony PS5 Slim 19 Blades check kasynparts
gameparts - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 51
过去 7 天: 380
过去 30 天: 1,404
总计 29,895
