跳转到主内容
加入维修社区 - 创建账户
PlayStation 2 Optical Disc Drive Laser Assembly Replacement
你所需要的
  1. PlayStation 2 Optical Disc Drive Laser Assembly Replacement, Top Cover: 步骤 1 中的图像 1,3 PlayStation 2 Optical Disc Drive Laser Assembly Replacement, Top Cover: 步骤 1 中的图像 2,3 PlayStation 2 Optical Disc Drive Laser Assembly Replacement, Top Cover: 步骤 1 中的图像 3,3
    • Flip the PlayStation 2 over so it lays with the bottom of the device facing upwards.
    • Use the flat edge of a metal spudger to pry the eight flat screw covers out.
    • Remove the following eight screws securing the top cover to the bottom case:
    • Four 55.4 mm Philips screws
    • Four 18.0 mm Phillips screws
    添加评论
  2. PlayStation 2 Optical Disc Drive Laser Assembly Replacement: 步骤 2 中的图像 1,1
    • Some models have a different number of screws and feet. Remove all the feet and screws in the bottom of the case.
    • The 10 screw model has 6 screws in the bottom-most portion and 4 in the upper tray.
    询问修复机器人
    添加评论
  3. PlayStation 2 Optical Disc Drive Laser Assembly Replacement: 步骤 3 中的图像 1,1
    • Peel the warranty sticker (located next to the main power switch) straight away from the case.
    • To avoid activating the VOID that may come up, heat it carefully to remove and replace it clean
    询问修复机器人
    添加评论
  4. PlayStation 2 Optical Disc Drive Laser Assembly Replacement: 步骤 4 中的图像 1,2 PlayStation 2 Optical Disc Drive Laser Assembly Replacement: 步骤 4 中的图像 2,2
    • Flip the PlayStation 2 back to its original upside position.
    • Lift the top cover off the bottom case.
    • To facilitate the removal, it is recommended to pry open the half closer to the power switch first while rocking the top cover towards the front of the bottom case.
    • Carefully remove the power cord that attaches the top and bottom halves by disconnecting the power cord assembly from the top case.
    添加评论
  5. PlayStation 2 Optical Disc Drive Laser Assembly Replacement, Optical Disc Drive Laser Assembly: 步骤 5 中的图像 1,2 PlayStation 2 Optical Disc Drive Laser Assembly Replacement, Optical Disc Drive Laser Assembly: 步骤 5 中的图像 2,2
    • Remove the four 6.4 mm Phillips screws securing the top lid of the optical disc drive.
    • Lift and remove the lid from the optical disc drive.
    添加评论
  6. PlayStation 2 Optical Disc Drive Laser Assembly Replacement: 步骤 6 中的图像 1,1
    • Remove the two 7.2 mm Phillips black screws securing the metal silver rails that hold the laser in place.
    添加评论
  7. PlayStation 2 Optical Disc Drive Laser Assembly Replacement: 步骤 7 中的图像 1,1
    • Use your fingernail to flip up the retaining flap on the optical disc drive laser ribbon cable.
    • Be sure you are prying up on the movable retaining flap, not the socket itself.
    • Pull the optical disc drive laser ribbon cable straight away and out of its socket.
    • If you maneuver the unscrewed ends of the metal rails upwards, the laser will slide out.
    添加评论
结论
取消:我没有完成这个指南。
38等其他人完成本指南。
jwyoung
于11/04/09注册
3,199 声望
创作了5篇指南
团队
Cal Poly, Team 19-1, Maness Fall 2009 Cal Poly, Team 19-1, Maness Fall 2009 的会员
CPSU-MANESS-F09S19G1
4 名成员
创作了35篇指南
8指南评论
just did the laser replacement, however the playstation still identifies "no data" when game is inserted. it says "reading disk" for a few seconds then nothing else happens. thought?
Danyal Fatmi - 回复 分享
Have you removed the security solder blob? All new Lenses have this somewhere in the circuitry.
Carlos Bragatto - 回复 分享
Number 1 Ifixit the class world,
Mohsen - 回复 分享
I noticed that many times when you replace a lens it throws of the rotary motor. Some ps2 consoles have only 1 hex adjustment yet others have 2. If you have the covers off and just replaced the lenses you should always plug it back in w/ the top off still and adjust it until you see the disc spinning rapidly and laser is moving back and forth. Another way for calibrating is to remove said disc and if lens and ribbon move all the way forward and all the way back 3 or more times then you are almost done. At that point plug in tv chord and place in a disc if the PlayStation 2 logo comes on and disappears in less than 3 seconds carefully replace all parts and your good to go.
Raymond - 回复 分享
Could you please add the parts you would need to replace this to the parts portion.
Nice guide by the way.
Alexander Wiand - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 22
过去 7 天: 121
过去 30 天: 656
总计 93,765
