跳转到主内容
加入维修社区 - 创建账户
Plantronics CS50 Headset System Reset
  1. Plantronics CS50 Headset System Reset, Plantronics CS50 Headset System Reset: 步骤 1 中的图像 1,2 Plantronics CS50 Headset System Reset, Plantronics CS50 Headset System Reset: 步骤 1 中的图像 2,2
    • Press and hold both the call control button and the listening volume/mute button for five seconds.
    • When the talk indicator light blinks, release both buttons.
    询问修复机器人
    添加评论
  2. Plantronics CS50 Headset System Reset: 步骤 2 中的图像 1,1
    • Press the call control button again.
    询问修复机器人
    添加评论
  3. Plantronics CS50 Headset System Reset: 步骤 3 中的图像 1,2 Plantronics CS50 Headset System Reset: 步骤 3 中的图像 2,2
    • Unplug the base unit's power source for ten seconds.
    • Plug the power source back in.
    询问修复机器人
    添加评论
终点
取消:我没有完成这个指南。
3等其他人完成本指南。
Joe
于04/12/12注册
117 声望
创作了3篇指南
团队
Cal Poly, Team 17-29, Amido Spring 2012 Cal Poly, Team 17-29, Amido Spring 2012 的会员
CPSU-AMIDO-S12S17G29
4 名成员
创作了21篇指南
4指南评论
Great fix. I was about to spend $200 on a new set. Thanks.
acseko - 回复 分享
I had a constant buzzing sound from the unit. I did what you recommended and could not stop it. Then I discovered that my handset also had the same buzzing sound so I unplugged the phone line and power cord (to the main phone unit) and it cleared up!
Russ - 回复 分享
I've got a unit that is getting no sound to or from the earpiece at all, though the lifter still lifts when I hit the answer button. I'll try this reset before I order a replacement set.
kool1zero - 回复 分享
I have the C053 model and have cleaned headset and base and can not get it to charge. I have noticed over the past few weeks that it will only stayed charged from 800 am to 100 pm. I have disconnected and restarted also. Any other suggestions?
Diane
Diane - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 42
总计 23,427
