本指南有最近更改,您可查看未经巡查的最新版本。
简介
This guide will walk you through replacing the button panel circuit board in your device. You may need to know how to solder and desolder connections before proceeding with this guide.
你所需要的
Flip the speaker upside down with the back panel of plugs pointed away from you.
Lay the speaker down flat to make it easier to work on.
Remove the seven 4 mm screws with a Phillips #2 screwdriver.
即将完成!
结论
