跳转到主内容
加入维修社区 - 创建账户
Philips SBA1060 Capacitor Replacement
你所需要的
  1. Philips SBA1060 Capacitor Replacement, Battery Casing: 步骤 1 中的图像 1,1
    • Remove the back cover by sliding it off.
    • Remove the 3 AAA batteries.
    询问修复机器人
    添加评论
  2. Philips SBA1060 Capacitor Replacement: 步骤 2 中的图像 1,3 Philips SBA1060 Capacitor Replacement: 步骤 2 中的图像 2,3 Philips SBA1060 Capacitor Replacement: 步骤 2 中的图像 3,3
    • Unscrew the nine exterior screws on the back panel using a PH0-size Philips-head screwdriver.
    • A larger screwdriver head and more force may be required for damaged screws.
    • Remove the triangular end piece by pulling it straight off.
    询问修复机器人
    添加评论
  3. Philips SBA1060 Capacitor Replacement: 步骤 3 中的图像 1,2 Philips SBA1060 Capacitor Replacement: 步骤 3 中的图像 2,2
    • Remove the colored grill by sliding it off in the direction of the removed end piece.
    • Pry off the back battery panel with the plastic opening tool.
    • Be careful to avoid tearing any wires.
    询问修复机器人
    添加评论
  4. Philips SBA1060 Capacitor Replacement, Capacitor: 步骤 4 中的图像 1,1
    • Remove the two screws on opposite ends of the circuit board with the PH0 size philips head screw driver.
    • Slowly pull the circuit board out of the device
    • NOTE: Be careful not to damage any of the wires protruding from the back of the circuit board.
    询问修复机器人
    添加评论
  5. Philips SBA1060 Capacitor Replacement: 步骤 5 中的图像 1,2 Philips SBA1060 Capacitor Replacement: 步骤 5 中的图像 2,2
    • Flip the device and remove the battery plug from the circuit board by pulling out the plugs to fully remove back panel.
    • Remove the speaker plugs from the circuit board by pulling out the plugs. They are located on opposite sides of the circuit board.
    • NOTE: When reassembling, note that the speaker with the red wire goes to the red plug, and the speaker with the white wire goes to the adjacent white plug.
    • Remove the light plug from the circuit board.
    • NOTE: This plug is twice as wide as the speaker and battery plugs.
    询问修复机器人
    添加评论
  6. Philips SBA1060 Capacitor Replacement: 步骤 6 中的图像 1,2 Philips SBA1060 Capacitor Replacement: 步骤 6 中的图像 2,2
    • Locate the capacitor and carefully slide it out of the circuit board.
    • NOTE: The capacitor will be a cylindrical object protruding vertically near the center of the circuit board.
    • Slide the prongs of the replacement capacitor into the two holes of the circuit board where the original capacitor was removed from.
    • Reassemble the speaker.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
团队
Clemson, Team 14-4, Benson Fall 2013 Clemson, Team 14-4, Benson Fall 2013 的会员
CLEM-BENSON-F13S14G4
3 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 18
总计 1,050
