跳转到主内容
加入维修社区 - 创建账户
Philips DC320 37 Connector Replacement
你所需要的
    1. Philips DC320 37 Connector Replacement, Docking entertainment system: 步骤 1 中的图像 1,1
      • Pry off the four white feet with the pointed end of the spudger
      询问修复机器人
      添加评论
    2. Philips DC320 37 Connector Replacement: 步骤 2 中的图像 1,1
      • Gently unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
      询问修复机器人
      添加评论
    3. Philips DC320 37 Connector Replacement: 步骤 3 中的图像 1,1
      • Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
      • The connectors on the panel are fragile and may break.
      询问修复机器人
      添加评论
    4. Philips DC320 37 Connector Replacement: 步骤 4 中的图像 1,3 Philips DC320 37 Connector Replacement: 步骤 4 中的图像 2,3 Philips DC320 37 Connector Replacement: 步骤 4 中的图像 3,3
      • Carefully pull up and out the four electrical connectors and two ribbon connectors that connect the bottom panel to the dock.
      • Electrical Connectors
      • Ribbon Connectors
      • The cables do not have a lot of slack in them. Be careful not to break the connectors.
      • One wire is soldered onto the bottom panel. Be careful not to break this bond.
      询问修复机器人
      添加评论
    1. Philips DC320 37 Connector Replacement, Connector: 步骤 5 中的图像 1,1
      • Pull the copper plate out of the way of the two Phillips #00 screws in the middle of the connector.
      询问修复机器人
      添加评论
    2. Philips DC320 37 Connector Replacement: 步骤 6 中的图像 1,1
      • Unscrew the two 7 mm Phillips #00 screws holding the connector together.
      • Unscrew the four 5 mm Phillips #00 screws holding the connector to the dock
      询问修复机器人
      添加评论
    3. Philips DC320 37 Connector Replacement: 步骤 7 中的图像 1,3 Philips DC320 37 Connector Replacement: 步骤 7 中的图像 2,3 Philips DC320 37 Connector Replacement: 步骤 7 中的图像 3,3
      • Turn the dock so that you are looking at the front of the dock.
      • Pull out the black U-shaped piece.
      • Pull out the iPhone/iPod support cradle.
      • Pull out the two springs.
      询问修复机器人
      添加评论
    4. Philips DC320 37 Connector Replacement: 步骤 8 中的图像 1,1
      • Turn the dock so that you are looking at the bottom of the dock.
      • Pop out the black connector frame and attached circuit board from the body of the dock.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Greg Lane
于04/16/13注册
39 声望
创作了4篇指南
团队
Cal Poly, Team 3-48, Amido Spring 2013 Cal Poly, Team 3-48, Amido Spring 2013 的会员
CPSU-AMIDO-S13S3G48
4 名成员
创作了13篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 34
总计 1,533
