跳转到主内容
加入维修社区 - 创建账户
Petnet SmartFeeder SF10E 12 Pin Connector Replacement
你所需要的
    1. Petnet SmartFeeder SF10E 12 Pin Connector Replacement, 12 Pin Connector: 步骤 1 中的图像 1,3 Petnet SmartFeeder SF10E 12 Pin Connector Replacement, 12 Pin Connector: 步骤 1 中的图像 2,3 Petnet SmartFeeder SF10E 12 Pin Connector Replacement, 12 Pin Connector: 步骤 1 中的图像 3,3
      • Eject the SmartBowl by pressing the button located at the front of the SmartFeeder base.
      询问修复机器人
      添加评论
    2. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: 步骤 2 中的图像 1,3 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: 步骤 2 中的图像 2,3 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: 步骤 2 中的图像 3,3
      • Remove the food tub by twisting it counter-clockwise with both hands and lifting it up.
      询问修复机器人
      添加评论
    3. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: 步骤 3 中的图像 1,1
      • Remove the black plastic gasket from the top of the SmartFeeder by placing your fingers on the side of it and lifting up.
      • It should come off easily.
      询问修复机器人
      添加评论
    4. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: 步骤 4 中的图像 1,1
      • Flip over the SmartFeeder by using both hands.
      • Partially open the outer case of the SmartFeeder by wedging an iFixit Opening Tool on each side.
      询问修复机器人
      添加评论
    5. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: 步骤 5 中的图像 1,2 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: 步骤 5 中的图像 2,2
      • Turn the SmartFeeder on its side and with one hand on the base, carefully pull out the central section.
      • Place the bottom piece of the device right-side up.
      询问修复机器人
      添加评论
    6. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: 步骤 6 中的图像 1,2 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: 步骤 6 中的图像 2,2
      • Remove one 10 mm screw by using the Phillips #1 screwdriver.
      • Remove the plastic retaining piece for the daughterboard by pulling it out with one hand.
      询问修复机器人
      添加评论
    7. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: 步骤 7 中的图像 1,3 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: 步骤 7 中的图像 2,3 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: 步骤 7 中的图像 3,3
      • Pull the daughterboard out of the device and remove the three-prong connectors by using your hands.
      • Hold onto the sockets on the motherboard or you could accidentally pull off the entire assembly.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Ashley Kim
于10/08/18注册
187 声望
撰写一个指南
团队
Cal Poly, Team S13-G7, White Fall 2018 Cal Poly, Team S13-G7, White Fall 2018 的会员
CPSU-WHITE-F18S13G7
4 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 24
总计 618
