跳转到主内容
加入维修社区 - 创建账户
Petcube Play 2 LED Replacement
你所需要的
  1. Petcube Play 2 LED Replacement, Motherboard: 步骤 1 中的图像 1,3 Petcube Play 2 LED Replacement, Motherboard: 步骤 1 中的图像 2,3 Petcube Play 2 LED Replacement, Motherboard: 步骤 1 中的图像 3,3
    • Flip over the Petcube so the rubber bottom faces you.
    • Pull up the rubber layer with an iFixit opening pick to expose the screws underneath.
  2. Petcube Play 2 LED Replacement: 步骤 2 中的图像 1,2 Petcube Play 2 LED Replacement: 步骤 2 中的图像 2,2
    • Remove the four 3.5mm screws from under the rubber cover using a Phillips #1 screwdriver.
    • The glue may cause slight resistance, but the screws should come out with minimal effort.
  3. Petcube Play 2 LED Replacement: 步骤 3 中的图像 1,2 Petcube Play 2 LED Replacement: 步骤 3 中的图像 2,2
    • Carefully pry off the glass front panel using an opening pick or a spudger.
    • Do not force the front panel off, as it may crack and break.
  4. Petcube Play 2 LED Replacement: 步骤 4 中的图像 1,3 Petcube Play 2 LED Replacement: 步骤 4 中的图像 2,3 Petcube Play 2 LED Replacement: 步骤 4 中的图像 3,3
    • Slide off the two covers, starting with the top plastic cover.
    • Slide out the internal assembly from the aluminum casing.
  5. Petcube Play 2 LED Replacement: 步骤 5 中的图像 1,3 Petcube Play 2 LED Replacement: 步骤 5 中的图像 2,3 Petcube Play 2 LED Replacement: 步骤 5 中的图像 3,3
    • Once the internal assembly is removed, a brass cylinder in one corner of the cube's front face will be visible. A screw will be attached to it.
    • Remove the screw with a Phillips #1 screwdriver.
  6. Petcube Play 2 LED Replacement: 步骤 6 中的图像 1,3 Petcube Play 2 LED Replacement: 步骤 6 中的图像 2,3 Petcube Play 2 LED Replacement: 步骤 6 中的图像 3,3
    • Flip the cube onto its side to locate the pull tabs.
    • Using an opening tool, lift each of the five tabs to separate the two halves of the Petcube 2.
  7. Petcube Play 2 LED Replacement: 步骤 7 中的图像 1,3 Petcube Play 2 LED Replacement: 步骤 7 中的图像 2,3 Petcube Play 2 LED Replacement: 步骤 7 中的图像 3,3
    • Gently disconnect the cable connectors to separate the two halves of the device.
    • Avoid pulling on the wires to prevent damage to the connectors.
  8. Petcube Play 2 LED Replacement: 步骤 8 中的图像 1,3 Petcube Play 2 LED Replacement: 步骤 8 中的图像 2,3 Petcube Play 2 LED Replacement: 步骤 8 中的图像 3,3
    • Use a Phillips #1 screwdriver to remove the two 1mm screws.
    • Carefully release each of the tabs on the sides of the cube and remove the motherboard.
    • Be gentle with the tabs. They will break under too much pressure.
  9. Petcube Play 2 LED Replacement, LED: 步骤 9 中的图像 1,3 Petcube Play 2 LED Replacement, LED: 步骤 9 中的图像 2,3 Petcube Play 2 LED Replacement, LED: 步骤 9 中的图像 3,3
    • Using a Phillips #1 screwdriver, remove the screws to disconnect the front plates from each other.
  10. Petcube Play 2 LED Replacement: 步骤 10 中的图像 1,3 Petcube Play 2 LED Replacement: 步骤 10 中的图像 2,3 Petcube Play 2 LED Replacement: 步骤 10 中的图像 3,3
    • Remove the front plastic casing from the circuit board.
    • Identify the LED and the foam protector.
    • Remove the foam protector by gently pulling upwards with thin tweezers.
    • Use a soldering iron to desolder the LED from the board. Solder the new LED in the same place and orientation.
    • Never touch a hot soldering iron.
    • When soldering, be careful not to damage any other components be resting the iron on them. Remove the solder on the LED only, then solder the new one on.
结论
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
团队
UMass Dartmouth, Team 1-5, Konn Spring 2024 UMass Dartmouth, Team 1-5, Konn Spring 2024 的会员
UMASSD-KONN-S24S1G5
4 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 22
总计 237
