跳转到主内容
加入维修社区 - 创建账户
Pentax Super Program Shutter Service
你所需要的
  1. Pentax Super Program Shutter Service, Remove film advance lever: 步骤 1 中的图像 1,3 Pentax Super Program Shutter Service, Remove film advance lever: 步骤 1 中的图像 2,3 Pentax Super Program Shutter Service, Remove film advance lever: 步骤 1 中的图像 3,3
    • Remove the rubber decorative cap. It is attached with contact cement underneath. Isopropyl Alcohol may be used to soften the adhesive.
    • Unscrew the lock nut using a spanner wrench. The lock nut is reverse threaded.
    • Lift off the advance lever.
    • Remove the spring washer.
    • Remove one shim washer.
    询问修复机器人
    添加评论
  2. Pentax Super Program Shutter Service, Remove mode dial: 步骤 2 中的图像 1,2 Pentax Super Program Shutter Service, Remove mode dial: 步骤 2 中的图像 2,2
    • Set the mode dial to the 'L' position.
    • Use a spanner wrench to unscrew the dial lock nut.
    • Lift off the mode dial.
    询问修复机器人
    添加评论
  3. Pentax Super Program Shutter Service, Remove exposure compensation dial: 步骤 3 中的图像 1,3 Pentax Super Program Shutter Service, Remove exposure compensation dial: 步骤 3 中的图像 2,3 Pentax Super Program Shutter Service, Remove exposure compensation dial: 步骤 3 中的图像 3,3
    • Place a rigid object in the fork.
    • Unscrew the rewind lever.
    • Use a spanner wrench to remove the lock nut.
    • Lift off the exposure compensation dial.
    询问修复机器人
    添加评论
  4. Pentax Super Program Shutter Service, Remove top cover screws: 步骤 4 中的图像 1,3 Pentax Super Program Shutter Service, Remove top cover screws: 步骤 4 中的图像 2,3 Pentax Super Program Shutter Service, Remove top cover screws: 步骤 4 中的图像 3,3
    • Remove two screws on either side of the eye piece.
    • Remove two screws on either side of the lens mount.
    询问修复机器人
    添加评论
  5. Pentax Super Program Shutter Service, Remove top cover: 步骤 5 中的图像 1,3 Pentax Super Program Shutter Service, Remove top cover: 步骤 5 中的图像 2,3 Pentax Super Program Shutter Service, Remove top cover: 步骤 5 中的图像 3,3
    • Remove one screw by the exposure compensation dial.
    • Use a spanner wrench to remove the lock nut under the advance lever.
    • Lift off the top cover slowly. It is still attached by one wire.
    • Unsolder one gray flash sync wire.
    询问修复机器人
    添加评论
  6. Pentax Super Program Shutter Service, Remove bottom cover: 步骤 6 中的图像 1,1
    • Remove three M1.7 x 3 mm screws.
    • Remove bottom cover.
    询问修复机器人
    添加评论
  7. Pentax Super Program Shutter Service, Remove front leatherette panels: 步骤 7 中的图像 1,3 Pentax Super Program Shutter Service, Remove front leatherette panels: 步骤 7 中的图像 2,3 Pentax Super Program Shutter Service, Remove front leatherette panels: 步骤 7 中的图像 3,3
    • Use a nickel or other large coin to remove the hand grip.
    • Drip isopropyl alcohol along the edge of the leatherette to soften the adhesive.
    • Use a dull scraper to lift one corner and pull off the panel.
    • Repeat on the rewind side of the camera.
    • Installation Notes: Use contact cement to reattach the leatherette after the camera has been fully reassembled and tested.
    询问修复机器人
    添加评论
  8. Pentax Super Program Shutter Service, Detach flex PCB with adjustment pots: 步骤 8 中的图像 1,2 Pentax Super Program Shutter Service, Detach flex PCB with adjustment pots: 步骤 8 中的图像 2,2
    • Remove one M1.7 x 4.5 mm screw.
    • Remove one slotted screw.
    • Use isopropyl alcohol to soften the adhesive under the flex PCB.
    • Gently lift the PCB until it is free from the camera body.
    询问修复机器人
    添加评论
  9. Pentax Super Program Shutter Service, Unsolder motor drive connections: 步骤 9 中的图像 1,2 Pentax Super Program Shutter Service, Unsolder motor drive connections: 步骤 9 中的图像 2,2
    • Unsolder red wire for positive battery.
    • Unsolder green wire.
    • Unsolder orange wire for motor drive shutter release.
    • Unsolder purple wire for wind completion switch.
    询问修复机器人
    添加评论
  10. Pentax Super Program Shutter Service, Remove tripod mount: 步骤 10 中的图像 1,2 Pentax Super Program Shutter Service, Remove tripod mount: 步骤 10 中的图像 2,2
    • Remove one M1.7 x 5 mm screw.
    • Remove one countersunk M1.7 x 5.5 mm screw.
    • Lift the contact terminal free from its seat.
    • Remove the tripod mount.
    询问修复机器人
    添加评论
  11. Pentax Super Program Shutter Service, Detach ISO resistor assembly: 步骤 11 中的图像 1,2 Pentax Super Program Shutter Service, Detach ISO resistor assembly: 步骤 11 中的图像 2,2
    • Remove one M1.7 x 4 mm screw.
    • Loosen one slotted screw (this will remain connected to the assembly).
    • Lift the ISO resistor assembly off the rewind post. It is still attached by a flex PCB.
    询问修复机器人
    添加评论
  12. Pentax Super Program Shutter Service, Detach mode dial unit: 步骤 12 中的图像 1,3 Pentax Super Program Shutter Service, Detach mode dial unit: 步骤 12 中的图像 2,3 Pentax Super Program Shutter Service, Detach mode dial unit: 步骤 12 中的图像 3,3
    • Remove one M1.7 x 2.5 mm screw. It is only accessible when the mode dial is in the 'L' position.
    • Lift the LCD out of the way. It is still attached by a flex PCB.
    • Remove one slotted post.
    询问修复机器人
    添加评论
  13. Pentax Super Program Shutter Service, Unsolder flash sync wires: 步骤 13 中的图像 1,1
    • Unsolder two gray wires.
    询问修复机器人
    添加评论
  14. Pentax Super Program Shutter Service, Unsolder shutter wires: 步骤 14 中的图像 1,2 Pentax Super Program Shutter Service, Unsolder shutter wires: 步骤 14 中的图像 2,2
    • Unsolder white wire.
    • Unsolder brown wire.
    • Unsolder red wire.
    询问修复机器人
    添加评论
  15. Pentax Super Program Shutter Service, Unscrew mirror box: 步骤 15 中的图像 1,2 Pentax Super Program Shutter Service, Unscrew mirror box: 步骤 15 中的图像 2,2
    • Remove two M1.7 x 2.5 mm screws.
    • Remove one M1.7 x 3.5 mm screw under the bottom plate.
    • Some versions of the camera may have an additional screw under the tripod mount that needs to be removed.
    询问修复机器人
    添加评论
  16. Pentax Super Program Shutter Service, Unscrew front board: 步骤 16 中的图像 1,2 Pentax Super Program Shutter Service, Unscrew front board: 步骤 16 中的图像 2,2
    • Wind the advance lever to put the shutter and mirror box in the charged state.
    • Remove four M1.9 x 5 mm screws.
    询问修复机器人
    添加评论
  17. Pentax Super Program Shutter Service, Remove mirror box and front board: 步骤 17 中的图像 1,1
    • Make sure the mode dial unit and ISO selector unit are free from their mounting points.
    • Wiggle the mirror box and front board free.
    • Watch for wire snags as you pull it free.
    • Check for loose shim washers on the front board and note their position.
    询问修复机器人
    添加评论
  18. Pentax Super Program Shutter Service, Installation Notes: Front Block: 步骤 18 中的图像 1,1
    • Shutter should be in the charged state.
    • Mirror box should be in released state.
    • Pay close attention to wire routing during install.
    • To test the actuation of the mirror and shutter, wind the camera, then insert a tool into this slot and push the release lever to the left.
    询问修复机器人
    添加评论
  19. Pentax Super Program Shutter Service, Remove shutter unit: 步骤 19 中的图像 1,3 Pentax Super Program Shutter Service, Remove shutter unit: 步骤 19 中的图像 2,3 Pentax Super Program Shutter Service, Remove shutter unit: 步骤 19 中的图像 3,3
    • Lift shutter unit out of camera body.
    询问修复机器人
    添加评论
  20. Pentax Super Program Shutter Service, Release the shutter: 步骤 20 中的图像 1,1
    • Push the shutter release latch down to fire the shutter.
    • Reducing the tension of the shutter springs makes disassembly and reassembly easier.
    询问修复机器人
    添加评论
  21. Pentax Super Program Shutter Service, Remove rear plate: 步骤 21 中的图像 1,3 Pentax Super Program Shutter Service, Remove rear plate: 步骤 21 中的图像 2,3 Pentax Super Program Shutter Service, Remove rear plate: 步骤 21 中的图像 3,3
    • Remove old foam seals.
    • Foam seals should be replaced with new material during reassembly.
    • Remove four M1.4 x 2.4 mm screws.
    • Remove top spacer bushing.
    询问修复机器人
    添加评论
  22. Pentax Super Program Shutter Service, Remove closing curtain: 步骤 22 中的图像 1,2 Pentax Super Program Shutter Service, Remove closing curtain: 步骤 22 中的图像 2,2
    • Remove closing curtain linkage.
    • Remove five curtain blades.
    • Installation Notes: Make sure the helper spring is properly hooked on the closing curtain linkage when reassembled.
    询问修复机器人
    添加评论
  23. Pentax Super Program Shutter Service, Remove curtain separator: 步骤 23 中的图像 1,2 Pentax Super Program Shutter Service, Remove curtain separator: 步骤 23 中的图像 2,2
    • Remove curtain separator.
    • Remove lower separator bushing.
    询问修复机器人
    添加评论
  24. Pentax Super Program Shutter Service, Remove opening curtain: 步骤 24 中的图像 1,2 Pentax Super Program Shutter Service, Remove opening curtain: 步骤 24 中的图像 2,2
    • Remove three curtain blades.
    • Remove opening curtain linkage.
    询问修复机器人
    添加评论
  25. Pentax Super Program Shutter Service, Clean the shutter: 步骤 25 中的图像 1,3 Pentax Super Program Shutter Service, Clean the shutter: 步骤 25 中的图像 2,3 Pentax Super Program Shutter Service, Clean the shutter: 步骤 25 中的图像 3,3
    • Remove two curtain guides.
    • Clean any residue from the shutter frame and blades using isopropyl alcohol or other solvent.
    • Clean the curtain pivots.
    • Remove degraded rubber dampers and clean the surrounding area. They do not need to be replaced.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Sam Gustafson
于09/01/22注册
11,000 声望
创作了78篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 52
总计 577
