跳转到主内容
加入维修社区 - 创建账户
Pentax Super Program Mirror Box Mechanism Service
你所需要的
    1. Pentax Super Program Mirror Box Mechanism Service, Remove film advance lever: 步骤 1 中的图像 1,3 Pentax Super Program Mirror Box Mechanism Service, Remove film advance lever: 步骤 1 中的图像 2,3 Pentax Super Program Mirror Box Mechanism Service, Remove film advance lever: 步骤 1 中的图像 3,3
      • Remove the rubber decorative cap. It is attached with contact cement underneath. Isopropyl Alcohol may be used to soften the adhesive.
      • Unscrew the lock nut using a spanner wrench. The lock nut is reverse threaded.
      • Lift off the advance lever.
      • Remove the spring washer.
      • Remove one shim washer.
      询问修复机器人
      添加评论
    2. Pentax Super Program Mirror Box Mechanism Service, Remove mode dial: 步骤 2 中的图像 1,2 Pentax Super Program Mirror Box Mechanism Service, Remove mode dial: 步骤 2 中的图像 2,2
      • Set the mode dial to the 'L' position.
      • Use a spanner wrench to unscrew the dial lock nut.
      • Lift off the mode dial.
      询问修复机器人
      添加评论
    3. Pentax Super Program Mirror Box Mechanism Service, Remove exposure compensation dial: 步骤 3 中的图像 1,3 Pentax Super Program Mirror Box Mechanism Service, Remove exposure compensation dial: 步骤 3 中的图像 2,3 Pentax Super Program Mirror Box Mechanism Service, Remove exposure compensation dial: 步骤 3 中的图像 3,3
      • Place a rigid object in the fork.
      • Unscrew the rewind lever.
      • Use a spanner wrench to remove the lock nut.
      • Lift off the exposure compensation dial.
      询问修复机器人
      添加评论
    4. Pentax Super Program Mirror Box Mechanism Service, Remove top cover screws: 步骤 4 中的图像 1,3 Pentax Super Program Mirror Box Mechanism Service, Remove top cover screws: 步骤 4 中的图像 2,3 Pentax Super Program Mirror Box Mechanism Service, Remove top cover screws: 步骤 4 中的图像 3,3
      • Remove two screws on either side of the eye piece.
      • Remove two screws on either side of the lens mount.
      询问修复机器人
      添加评论
    5. Pentax Super Program Mirror Box Mechanism Service, Remove top cover: 步骤 5 中的图像 1,3 Pentax Super Program Mirror Box Mechanism Service, Remove top cover: 步骤 5 中的图像 2,3 Pentax Super Program Mirror Box Mechanism Service, Remove top cover: 步骤 5 中的图像 3,3
      • Remove one screw by the exposure compensation dial.
      • Use a spanner wrench to remove the lock nut under the advance lever.
      • Lift off the top cover slowly. It is still attached by one wire.
      • Unsolder one gray flash sync wire.
      询问修复机器人
      添加评论
    1. Pentax Super Program Mirror Box Mechanism Service, Remove bottom cover: 步骤 6 中的图像 1,1
      • Remove three M1.7 x 3 mm screws.
      • Remove bottom cover.
      询问修复机器人
      添加评论
    1. Pentax Super Program Mirror Box Mechanism Service, Remove front leatherette panels: 步骤 7 中的图像 1,3 Pentax Super Program Mirror Box Mechanism Service, Remove front leatherette panels: 步骤 7 中的图像 2,3 Pentax Super Program Mirror Box Mechanism Service, Remove front leatherette panels: 步骤 7 中的图像 3,3
      • Use a nickel or other large coin to remove the hand grip.
      • Drip isopropyl alcohol along the edge of the leatherette to soften the adhesive.
      • Use a dull scraper to lift one corner and pull off the panel.
      • Repeat on the rewind side of the camera.
      • Installation Notes: Use contact cement to reattach the leatherette after the camera has been fully reassembled and tested.
      询问修复机器人
      添加评论
    2. Pentax Super Program Mirror Box Mechanism Service, Detach flex PCB with adjustment pots: 步骤 8 中的图像 1,2 Pentax Super Program Mirror Box Mechanism Service, Detach flex PCB with adjustment pots: 步骤 8 中的图像 2,2
      • Remove one M1.7 x 4.5 mm screw.
      • Remove one slotted screw.
      • Use isopropyl alcohol to soften the adhesive under the flex PCB.
      • Gently lift the PCB until it is free from the camera body.
      询问修复机器人
      添加评论
    3. Pentax Super Program Mirror Box Mechanism Service, Unsolder motor drive connections: 步骤 9 中的图像 1,2 Pentax Super Program Mirror Box Mechanism Service, Unsolder motor drive connections: 步骤 9 中的图像 2,2
      • Unsolder red wire for positive battery.
      • Unsolder green wire.
      • Unsolder orange wire for motor drive shutter release.
      • Unsolder purple wire for wind completion switch.
      询问修复机器人
      添加评论
    4. Pentax Super Program Mirror Box Mechanism Service, Remove tripod mount: 步骤 10 中的图像 1,2 Pentax Super Program Mirror Box Mechanism Service, Remove tripod mount: 步骤 10 中的图像 2,2
      • Remove one M1.7 x 5 mm screw.
      • Remove one countersunk M1.7 x 5.5 mm screw.
      • Lift the contact terminal free from its seat.
      • Remove the tripod mount.
      询问修复机器人
      添加评论
    5. Pentax Super Program Mirror Box Mechanism Service, Detach ISO resistor assembly: 步骤 11 中的图像 1,2 Pentax Super Program Mirror Box Mechanism Service, Detach ISO resistor assembly: 步骤 11 中的图像 2,2
      • Remove one M1.7 x 4 mm screw.
      • Loosen one slotted screw (this will remain connected to the assembly).
      • Lift the ISO resistor assembly off the rewind post. It is still attached by a flex PCB.
      询问修复机器人
      添加评论
    6. Pentax Super Program Mirror Box Mechanism Service, Detach mode dial unit: 步骤 12 中的图像 1,3 Pentax Super Program Mirror Box Mechanism Service, Detach mode dial unit: 步骤 12 中的图像 2,3 Pentax Super Program Mirror Box Mechanism Service, Detach mode dial unit: 步骤 12 中的图像 3,3
      • Remove one M1.7 x 2.5 mm screw. It is only accessible when the mode dial is in the 'L' position.
      • Lift the LCD out of the way. It is still attached by a flex PCB.
      • Remove one slotted post.
      询问修复机器人
      添加评论
    7. Pentax Super Program Mirror Box Mechanism Service, Unsolder flash sync wires: 步骤 13 中的图像 1,1
      • Unsolder two gray wires.
      询问修复机器人
      添加评论
    8. Pentax Super Program Mirror Box Mechanism Service, Unsolder shutter wires: 步骤 14 中的图像 1,2 Pentax Super Program Mirror Box Mechanism Service, Unsolder shutter wires: 步骤 14 中的图像 2,2
      • Unsolder white wire.
      • Unsolder brown wire.
      • Unsolder red wire.
      询问修复机器人
      添加评论
    9. Pentax Super Program Mirror Box Mechanism Service, Unscrew mirror box: 步骤 15 中的图像 1,2 Pentax Super Program Mirror Box Mechanism Service, Unscrew mirror box: 步骤 15 中的图像 2,2
      • Remove two M1.7 x 2.5 mm screws.
      • Remove one M1.7 x 3.5 mm screw under the bottom plate.
      • Some versions of the camera may have an additional screw under the tripod mount that needs to be removed.
      询问修复机器人
      添加评论
    10. Pentax Super Program Mirror Box Mechanism Service, Unscrew front board: 步骤 16 中的图像 1,2 Pentax Super Program Mirror Box Mechanism Service, Unscrew front board: 步骤 16 中的图像 2,2
      • Wind the advance lever to put the shutter and mirror box in the charged state.
      • Remove four M1.9 x 5 mm screws.
      询问修复机器人
      添加评论
    11. Pentax Super Program Mirror Box Mechanism Service, Remove mirror box and front board: 步骤 17 中的图像 1,1
      • Make sure the mode dial unit and ISO selector unit are free from their mounting points.
      • Wiggle the mirror box and front board free.
      • Watch for wire snags as you pull it free.
      • Check for loose shim washers on the front board and note their position.
      询问修复机器人
      添加评论
    12. Pentax Super Program Mirror Box Mechanism Service, Installation Notes: Front Block: 步骤 18 中的图像 1,1
      • Shutter should be in the charged state.
      • Mirror box should be in released state.
      • Pay close attention to wire routing during install.
      • To test the actuation of the mirror and shutter, wind the camera, then insert a tool into this slot and push the release lever to the left.
      询问修复机器人
      添加评论
    1. Pentax Super Program Mirror Box Mechanism Service, Unsolder Main PCB: 步骤 19 中的图像 1,1
      • Unsolder one orange and one blue wire for the mirror release solenoid.
      • Unsolder one pink wire for the LCD backlight.
      • Unsolder two purple wires for the TL switch.
      • Unsolder one green wire for the MD switch.
      询问修复机器人
      添加评论
    2. Pentax Super Program Mirror Box Mechanism Service, Unsolder lens mount connections (early production): 步骤 20 中的图像 1,1
      • Unsolder six wires for the lens mount pin connections.
      • These are only present on the early production models. Later production models moved these connection points to the flex connector.
      询问修复机器人
      添加评论
    3. Pentax Super Program Mirror Box Mechanism Service, Unsolder aperture resistor: 步骤 21 中的图像 1,2 Pentax Super Program Mirror Box Mechanism Service, Unsolder aperture resistor: 步骤 21 中的图像 2,2
      • Unsolder two yellow wires for the aperture resistor.
      询问修复机器人
      添加评论
    4. Pentax Super Program Mirror Box Mechanism Service, Unsolder eye piece: 步骤 22 中的图像 1,3 Pentax Super Program Mirror Box Mechanism Service, Unsolder eye piece: 步骤 22 中的图像 2,3 Pentax Super Program Mirror Box Mechanism Service, Unsolder eye piece: 步骤 22 中的图像 3,3
      • Unsolder the red and black wires for the metering cells in the eye piece.
      • Unsolder pink and green wires for the flash sync connections.
      询问修复机器人
      添加评论
    5. Pentax Super Program Mirror Box Mechanism Service, Unsolder front board connections (early production): 步骤 23 中的图像 1,2 Pentax Super Program Mirror Box Mechanism Service, Unsolder front board connections (early production): 步骤 23 中的图像 2,2
      • Unsolder blue and black wires for self-timer LED.
      • Unsolder orange wire for beeper.
      • Unsolder gray and pink wires for aperture solenoid.
      • Unsolder light blue and yellow wires for aperture optical encoder.
      • Unsolder purple wire for self-timer contact.
      • Remove one screw.
      询问修复机器人
      添加评论
    6. Pentax Super Program Mirror Box Mechanism Service, Detach flex PCB connection (late production): 步骤 24 中的图像 1,2 Pentax Super Program Mirror Box Mechanism Service, Detach flex PCB connection (late production): 步骤 24 中的图像 2,2
      • Remove two M1.4 x 2 mm screws.
      • Use a spudger to gently pry off the connector plate.
      • Remove the silicone insulating pad.
      询问修复机器人
      添加评论
    7. Pentax Super Program Mirror Box Mechanism Service, Detach viewfinder LCD: 步骤 25 中的图像 1,1
      • Remove two M1.4 x 1.6 mm screws.
      • Look for shim washers when removing and note their position.
      询问修复机器人
      添加评论
    8. Pentax Super Program Mirror Box Mechanism Service, Remove mirror governor: 步骤 26 中的图像 1,3 Pentax Super Program Mirror Box Mechanism Service, Remove mirror governor: 步骤 26 中的图像 2,3 Pentax Super Program Mirror Box Mechanism Service, Remove mirror governor: 步骤 26 中的图像 3,3
      • Loosen one M1.7 x 4.5 mm screw but leave it in place.
      • Remove two M1.7 x 1.6 mm screws.
      • Remove the mirror governor.
      • Remove one plastic bushing.
      询问修复机器人
      添加评论
    9. Pentax Super Program Mirror Box Mechanism Service, Remove main PCB: 步骤 27 中的图像 1,1
      • Gently lift away the PCB from the mirror box.
      • The TTL flash metering cell needs to be unseated from the side of the mirror box to free the PCB for removal.
      询问修复机器人
      添加评论
    1. Pentax Super Program Mirror Box Mechanism Service, Detach front flex PCB: 步骤 28 中的图像 1,2 Pentax Super Program Mirror Box Mechanism Service, Detach front flex PCB: 步骤 28 中的图像 2,2
      • Lift flex PCB off of mounting posts.
      • Remove silicone insulator pad.
      询问修复机器人
      添加评论
    2. Pentax Super Program Mirror Box Mechanism Service, Remove beeper: 步骤 29 中的图像 1,2 Pentax Super Program Mirror Box Mechanism Service, Remove beeper: 步骤 29 中的图像 2,2
      • Remove one screw and retainer plate.
      • Remove beeper.
      询问修复机器人
      添加评论
    3. Pentax Super Program Mirror Box Mechanism Service, Unscrew mirror box: 步骤 30 中的图像 1,3 Pentax Super Program Mirror Box Mechanism Service, Unscrew mirror box: 步骤 30 中的图像 2,3 Pentax Super Program Mirror Box Mechanism Service, Unscrew mirror box: 步骤 30 中的图像 3,3
      • Remove two M2 x 3 mm screws.
      • Remove one M1.7 x 3 mm screw.
      • Charge and release the mirror so it is in the taking position (up against the focusing screen).
      询问修复机器人
      添加评论
    4. Pentax Super Program Mirror Box Mechanism Service, Remove mirror box: 步骤 31 中的图像 1,1
      • Lift mirror box away from front lens board.
      询问修复机器人
      添加评论
    5. Pentax Super Program Mirror Box Mechanism Service, Installation Notes: Mirror Box: 步骤 32 中的图像 1,2 Pentax Super Program Mirror Box Mechanism Service, Installation Notes: Mirror Box: 步骤 32 中的图像 2,2
      • Check the following coupling points between the front lens board and the mirror box.
      • Aperture control.
      • Self-timer lever is above the mirror release latch.
      • Depth of field preview lever.
      询问修复机器人
      添加评论
      • Insert wisdom here.
      询问修复机器人
      添加评论
    1. Pentax Super Program Mirror Box Mechanism Service, Remove mirror return latch: 步骤 34 中的图像 1,3 Pentax Super Program Mirror Box Mechanism Service, Remove mirror return latch: 步骤 34 中的图像 2,3 Pentax Super Program Mirror Box Mechanism Service, Remove mirror return latch: 步骤 34 中的图像 3,3
      • Remove one M1.3 x 2.1 mm shoulder screw.
      • Remove one M1.3 x 2.4 mm screw.
      • Remove coil spring.
      • Note the rubber bumper on the pivot post. This should be removed and cleaned before reassembly.
      询问修复机器人
      添加评论
    2. Pentax Super Program Mirror Box Mechanism Service, Remove shutter release lever: 步骤 35 中的图像 1,2 Pentax Super Program Mirror Box Mechanism Service, Remove shutter release lever: 步骤 35 中的图像 2,2
      • Remove one M1.5 x 3.5 mm screw.
      • Remove the bias spring.
      • Remove the brass bushing.
      询问修复机器人
      添加评论
    3. Pentax Super Program Mirror Box Mechanism Service, Remove depth of field preview lever: 步骤 36 中的图像 1,3 Pentax Super Program Mirror Box Mechanism Service, Remove depth of field preview lever: 步骤 36 中的图像 2,3 Pentax Super Program Mirror Box Mechanism Service, Remove depth of field preview lever: 步骤 36 中的图像 3,3
      • Unhook and remove the coil spring. It may be tacked in place with lacquer.
      • Remove one M1.3 x 4.5 mm screw.
      • Remove the depth of field preview lever.
      • Remove the bushing.
      询问修复机器人
      添加评论
    4. Pentax Super Program Mirror Box Mechanism Service, Remove auto-aperture control lever: 步骤 37 中的图像 1,2 Pentax Super Program Mirror Box Mechanism Service, Remove auto-aperture control lever: 步骤 37 中的图像 2,2
      • Use a spanner wrench or u-bit to remove two nuts.
      • Lift off auto-aperture control lever.
      询问修复机器人
      添加评论
    5. Pentax Super Program Mirror Box Mechanism Service, Remove mirror flip-up lever: 步骤 38 中的图像 1,2 Pentax Super Program Mirror Box Mechanism Service, Remove mirror flip-up lever: 步骤 38 中的图像 2,2
      • Lift off mirror flip-up lever.
      • Remove shim washer.
      • Remove plastic bushing.
      询问修复机器人
      添加评论
    6. Pentax Super Program Mirror Box Mechanism Service, Remove aperture stop-down lever: 步骤 39 中的图像 1,2 Pentax Super Program Mirror Box Mechanism Service, Remove aperture stop-down lever: 步骤 39 中的图像 2,2
      • Remove aperture stop-down lever.
      • Installation Notes: Ensure the lever foot is placed properly between the mirror flip-up spring and the mirror return lever during reassembly.
      询问修复机器人
      添加评论
    7. Pentax Super Program Mirror Box Mechanism Service, Clean mirror box components: 步骤 40 中的图像 1,1
      • Remove two old rubber bumpers.
      • Clean all pivots with isopropyl alcohol.
      • Clean all removed components with isopropyl alcohol.
      询问修复机器人
      添加评论
    8. Pentax Super Program Mirror Box Mechanism Service, Reassembly Notes: 步骤 41 中的图像 1,1
      • The mirror mechanism does not need lubrication to operate properly. Most moving interfaces run dry.
      • High friction latching points can be lubricated with a heavy moly grease to reduce wear.
      • Replacement rubber dampers are optional. Silicone tubing cut to length is good source.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Sam Gustafson
于09/01/22注册
14,444 声望
创作了78篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 16
过去 30 天: 53
总计 562
