跳转到主内容
加入维修社区 - 创建账户
Pentax Super Program Front Block Removal
你所需要的
    1. Pentax Super Program Front Block Removal, Remove film advance lever: 步骤 1 中的图像 1,3 Pentax Super Program Front Block Removal, Remove film advance lever: 步骤 1 中的图像 2,3 Pentax Super Program Front Block Removal, Remove film advance lever: 步骤 1 中的图像 3,3
      • Remove the rubber decorative cap. It is attached with contact cement underneath. Isopropyl Alcohol may be used to soften the adhesive.
      • Unscrew the lock nut using a spanner wrench. The lock nut is reverse threaded.
      • Lift off the advance lever.
      • Remove the spring washer.
      • Remove one shim washer.
      询问修复机器人
      添加评论
    2. Pentax Super Program Front Block Removal, Remove mode dial: 步骤 2 中的图像 1,2 Pentax Super Program Front Block Removal, Remove mode dial: 步骤 2 中的图像 2,2
      • Set the mode dial to the 'L' position.
      • Use a spanner wrench to unscrew the dial lock nut.
      • Lift off the mode dial.
      询问修复机器人
      添加评论
    3. Pentax Super Program Front Block Removal, Remove exposure compensation dial: 步骤 3 中的图像 1,3 Pentax Super Program Front Block Removal, Remove exposure compensation dial: 步骤 3 中的图像 2,3 Pentax Super Program Front Block Removal, Remove exposure compensation dial: 步骤 3 中的图像 3,3
      • Place a rigid object in the fork.
      • Unscrew the rewind lever.
      • Use a spanner wrench to remove the lock nut.
      • Lift off the exposure compensation dial.
      询问修复机器人
      添加评论
    4. Pentax Super Program Front Block Removal, Remove top cover screws: 步骤 4 中的图像 1,3 Pentax Super Program Front Block Removal, Remove top cover screws: 步骤 4 中的图像 2,3 Pentax Super Program Front Block Removal, Remove top cover screws: 步骤 4 中的图像 3,3
      • Remove two screws on either side of the eye piece.
      • Remove two screws on either side of the lens mount.
      询问修复机器人
      添加评论
    5. Pentax Super Program Front Block Removal, Remove top cover: 步骤 5 中的图像 1,3 Pentax Super Program Front Block Removal, Remove top cover: 步骤 5 中的图像 2,3 Pentax Super Program Front Block Removal, Remove top cover: 步骤 5 中的图像 3,3
      • Remove one screw by the exposure compensation dial.
      • Use a spanner wrench to remove the lock nut under the advance lever.
      • Lift off the top cover slowly. It is still attached by one wire.
      • Unsolder one gray flash sync wire.
      询问修复机器人
      添加评论
    1. Pentax Super Program Front Block Removal, Remove bottom cover: 步骤 6 中的图像 1,1
      • Remove three M1.7 x 3 mm screws.
      • Remove bottom cover.
      询问修复机器人
      添加评论
    1. Pentax Super Program Front Block Removal, Remove front leatherette panels: 步骤 7 中的图像 1,3 Pentax Super Program Front Block Removal, Remove front leatherette panels: 步骤 7 中的图像 2,3 Pentax Super Program Front Block Removal, Remove front leatherette panels: 步骤 7 中的图像 3,3
      • Use a nickel or other large coin to remove the hand grip.
      • Drip isopropyl alcohol along the edge of the leatherette to soften the adhesive.
      • Use a dull scraper to lift one corner and pull off the panel.
      • Repeat on the rewind side of the camera.
      • Installation Notes: Use contact cement to reattach the leatherette after the camera has been fully reassembled and tested.
      询问修复机器人
      添加评论
    2. Pentax Super Program Front Block Removal, Detach flex PCB with adjustment pots: 步骤 8 中的图像 1,2 Pentax Super Program Front Block Removal, Detach flex PCB with adjustment pots: 步骤 8 中的图像 2,2
      • Remove one M1.7 x 4.5 mm screw.
      • Remove one slotted screw.
      • Use isopropyl alcohol to soften the adhesive under the flex PCB.
      • Gently lift the PCB until it is free from the camera body.
      询问修复机器人
      添加评论
    3. Pentax Super Program Front Block Removal, Unsolder motor drive connections: 步骤 9 中的图像 1,2 Pentax Super Program Front Block Removal, Unsolder motor drive connections: 步骤 9 中的图像 2,2
      • Unsolder red wire for positive battery.
      • Unsolder green wire.
      • Unsolder orange wire for motor drive shutter release.
      • Unsolder purple wire for wind completion switch.
      询问修复机器人
      添加评论
    4. Pentax Super Program Front Block Removal, Remove tripod mount: 步骤 10 中的图像 1,2 Pentax Super Program Front Block Removal, Remove tripod mount: 步骤 10 中的图像 2,2
      • Remove one M1.7 x 5 mm screw.
      • Remove one countersunk M1.7 x 5.5 mm screw.
      • Lift the contact terminal free from its seat.
      • Remove the tripod mount.
      询问修复机器人
      添加评论
    5. Pentax Super Program Front Block Removal, Detach ISO resistor assembly: 步骤 11 中的图像 1,2 Pentax Super Program Front Block Removal, Detach ISO resistor assembly: 步骤 11 中的图像 2,2
      • Remove one M1.7 x 4 mm screw.
      • Loosen one slotted screw (this will remain connected to the assembly).
      • Lift the ISO resistor assembly off the rewind post. It is still attached by a flex PCB.
      询问修复机器人
      添加评论
    6. Pentax Super Program Front Block Removal, Detach mode dial unit: 步骤 12 中的图像 1,3 Pentax Super Program Front Block Removal, Detach mode dial unit: 步骤 12 中的图像 2,3 Pentax Super Program Front Block Removal, Detach mode dial unit: 步骤 12 中的图像 3,3
      • Remove one M1.7 x 2.5 mm screw. It is only accessible when the mode dial is in the 'L' position.
      • Lift the LCD out of the way. It is still attached by a flex PCB.
      • Remove one slotted post.
      询问修复机器人
      添加评论
    7. Pentax Super Program Front Block Removal, Unsolder flash sync wires: 步骤 13 中的图像 1,1
      • Unsolder two gray wires.
      询问修复机器人
      添加评论
    8. Pentax Super Program Front Block Removal, Unsolder shutter wires: 步骤 14 中的图像 1,2 Pentax Super Program Front Block Removal, Unsolder shutter wires: 步骤 14 中的图像 2,2
      • Unsolder white wire.
      • Unsolder brown wire.
      • Unsolder red wire.
      询问修复机器人
      添加评论
    9. Pentax Super Program Front Block Removal, Unscrew mirror box: 步骤 15 中的图像 1,2 Pentax Super Program Front Block Removal, Unscrew mirror box: 步骤 15 中的图像 2,2
      • Remove two M1.7 x 2.5 mm screws.
      • Remove one M1.7 x 3.5 mm screw under the bottom plate.
      • Some versions of the camera may have an additional screw under the tripod mount that needs to be removed.
      询问修复机器人
      添加评论
    10. Pentax Super Program Front Block Removal, Unscrew front board: 步骤 16 中的图像 1,2 Pentax Super Program Front Block Removal, Unscrew front board: 步骤 16 中的图像 2,2
      • Wind the advance lever to put the shutter and mirror box in the charged state.
      • Remove four M1.9 x 5 mm screws.
      询问修复机器人
      添加评论
    11. Pentax Super Program Front Block Removal, Remove mirror box and front board: 步骤 17 中的图像 1,1
      • Make sure the mode dial unit and ISO selector unit are free from their mounting points.
      • Wiggle the mirror box and front board free.
      • Watch for wire snags as you pull it free.
      • Check for loose shim washers on the front board and note their position.
      询问修复机器人
      添加评论
    12. Pentax Super Program Front Block Removal, Installation Notes: Front Block: 步骤 18 中的图像 1,1
      • Shutter should be in the charged state.
      • Mirror box should be in released state.
      • Pay close attention to wire routing during install.
      • To test the actuation of the mirror and shutter, wind the camera, then insert a tool into this slot and push the release lever to the left.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Sam Gustafson
于09/01/22注册
14,444 声望
创作了78篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 33
总计 391
