跳转到主内容
加入维修社区 - 创建账户
Pentax PZ-10 Button Replacement
你所需要的
    1. Pentax PZ-10 Button Replacement, Top Cover: 步骤 1 中的图像 1,1
      • The top cover is one piece encasing the top of the device except the shutter release button and flash.
      询问修复机器人
      添加评论
    2. Pentax PZ-10 Button Replacement, Removing Upper Right Housing Screw: 步骤 2 中的图像 1,2 Pentax PZ-10 Button Replacement, Removing Upper Right Housing Screw: 步骤 2 中的图像 2,2
      • With the camera lens face down, locate the screw under the overhanging piece of the top casing on the right side of the back panel.
      • Using the J0 screwdriver, remove the 6.3 mm screw.
      询问修复机器人
      添加评论
    3. Pentax PZ-10 Button Replacement, Removing Screw in Battery Compartment: 步骤 3 中的图像 1,2 Pentax PZ-10 Button Replacement, Removing Screw in Battery Compartment: 步骤 3 中的图像 2,2
      • Locate the next screw by holding the camera upside down with the battery compartment empty and face up.
      • Remove the 6.3 mm screw using a J0 screwdriver.
      询问修复机器人
      添加评论
    4. Pentax PZ-10 Button Replacement, Removing Screw Under Flash Bulb: 步骤 4 中的图像 1,2 Pentax PZ-10 Button Replacement, Removing Screw Under Flash Bulb: 步骤 4 中的图像 2,2
      • The next screw is found in the overhanging piece just above the lens.
      • With the top of the camera facing down, remove the 3.4 mm screw with a J0 screwdriver.
      询问修复机器人
      添加评论
    5. Pentax PZ-10 Button Replacement, Pulling Off the Top Cover: 步骤 5 中的图像 1,2 Pentax PZ-10 Button Replacement, Pulling Off the Top Cover: 步骤 5 中的图像 2,2
      • Gently pull off the top cover with your hands by pulling on the tab on the left of the camera.
      询问修复机器人
      添加评论
    1. Pentax PZ-10 Button Replacement, Locate Rubber Tabs: 步骤 6 中的图像 1,2 Pentax PZ-10 Button Replacement, Locate Rubber Tabs: 步骤 6 中的图像 2,2
      在这个步骤中使用的工具:
      • Gently remove the beige rubber tabs from under the casing by pulling each down using tweezers.
      询问修复机器人
      添加评论
    2. Pentax PZ-10 Button Replacement: 步骤 7 中的图像 1,1
      • Remove the 3 buttons by pushing them from under the casing out through the top.
      • Each button is slotted differently, so pay attention to the orientation of each piece.
      询问修复机器人
      添加评论
    3. Pentax PZ-10 Button Replacement, Buttons: 步骤 8 中的图像 1,1
      • The buttons are now free to be replaced or cleaned.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Jonathan Diaz
于04/20/15注册
213 声望
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 19
总计 847
