跳转到主内容
加入维修社区 - 创建账户
Pentax LX Main PCB Removal
你所需要的
    1. Pentax LX Main PCB Removal, Remove rewind knob: 步骤 1 中的图像 1,2 Pentax LX Main PCB Removal, Remove rewind knob: 步骤 1 中的图像 2,2
      • Place a thin tool in the rewind fork and unscrew the topside knob.
      • Remove the washer under the rewind knob.
      询问修复机器人
      添加评论
    2. Pentax LX Main PCB Removal, Remove exposure compensation dial: 步骤 2 中的图像 1,3 Pentax LX Main PCB Removal, Remove exposure compensation dial: 步骤 2 中的图像 2,3 Pentax LX Main PCB Removal, Remove exposure compensation dial: 步骤 2 中的图像 3,3
      • Remove three #000 5.5 mm screws.
      • Remove exposure compensation dial assembly.
      • Remove washer.
      • Remove rubber seal.
      询问修复机器人
      添加评论
    3. Pentax LX Main PCB Removal, Remove rewind side top cover: 步骤 3 中的图像 1,2 Pentax LX Main PCB Removal, Remove rewind side top cover: 步骤 3 中的图像 2,2
      • Remove one #00 X mm screw.
      • Remove one #00 2.5 mm screw.
      询问修复机器人
      添加评论
    1. Pentax LX Main PCB Removal, Remove winding lever: 步骤 4 中的图像 1,3 Pentax LX Main PCB Removal, Remove winding lever: 步骤 4 中的图像 2,3 Pentax LX Main PCB Removal, Remove winding lever: 步骤 4 中的图像 3,3
      • Winding lever cover is reverse threaded.
      • Use a piece of tape wrapped sticky side out to grip the winding lever cover. Turn clockwise to loosen and remove
      • Remove four #000 2.5 mm screws.
      • Use spanners to remove top cover retaining nut.
      询问修复机器人
      添加评论
    2. Pentax LX Main PCB Removal, Remove shutter speed dial: 步骤 5 中的图像 1,3 Pentax LX Main PCB Removal, Remove shutter speed dial: 步骤 5 中的图像 2,3 Pentax LX Main PCB Removal, Remove shutter speed dial: 步骤 5 中的图像 3,3
      • Gently remove the rubber covering around the shutter speed dial.
      • Remove three #000 1.6 mm screws.
      • Remove cover ring.
      • Installation Notes: After the camera has been fully tested, use a few dabs of contact cement to fix the rubber covering back in place.
      询问修复机器人
      添加评论
    3. Pentax LX Main PCB Removal, Remove wind side top cover: 步骤 6 中的图像 1,3 Pentax LX Main PCB Removal, Remove wind side top cover: 步骤 6 中的图像 2,3 Pentax LX Main PCB Removal, Remove wind side top cover: 步骤 6 中的图像 3,3
      • Lift off top cover.
      询问修复机器人
      添加评论
    1. Pentax LX Main PCB Removal, Remove bottom cover screws: 步骤 7 中的图像 1,3 Pentax LX Main PCB Removal, Remove bottom cover screws: 步骤 7 中的图像 2,3 Pentax LX Main PCB Removal, Remove bottom cover screws: 步骤 7 中的图像 3,3
      • Remove the rubber bumper covering the screw.
      • Remove one #00 1.8 mm screw.
      • Repeat on the other side of the bottom plate (#00 3.0 mm screw).
      询问修复机器人
      添加评论
    2. Pentax LX Main PCB Removal, Remove bottom cover: 步骤 8 中的图像 1,1
      • Remove one #00 3.0 mm screw.
      • Remove bottom cover.
      询问修复机器人
      添加评论
    1. Pentax LX Main PCB Removal, Remove front leatherette: 步骤 9 中的图像 1,2 Pentax LX Main PCB Removal, Remove front leatherette: 步骤 9 中的图像 2,2
      • Use isopropyl alcohol to soften the adhesive along the edge of the leatherette.
      • Use a dull spudger or scraper to peel off the covering.
      • Turn the self timer lever to the 9 o'clock position.
      • Loosen the entire right side leatherette in the same manner, then work it over and around the self timer lever to remove.
      • Installation Notes: Use contact cement to reattach the leatherette. This should be the very last step in reassembly, after the camera has been fully tested.
      询问修复机器人
      添加评论
    2. Pentax LX Main PCB Removal, Remove two cover plates: 步骤 10 中的图像 1,2 Pentax LX Main PCB Removal, Remove two cover plates: 步骤 10 中的图像 2,2
      • Remove the two cover plates under the leatherette.
      • They may stick to the covering adhesive and come off on their own.
      • This small plug may also be loose.
      询问修复机器人
      添加评论
    3. Pentax LX Main PCB Removal, Unsolder relay board: 步骤 11 中的图像 1,2 Pentax LX Main PCB Removal, Unsolder relay board: 步骤 11 中的图像 2,2
      • Unsolder one gray wire.
      • Unsolder two yellow wires.
      • Unsolder one blue wire.
      • Unsolder one red wire.
      询问修复机器人
      添加评论
    4. Pentax LX Main PCB Removal, Remove front lens board: 步骤 12 中的图像 1,3 Pentax LX Main PCB Removal, Remove front lens board: 步骤 12 中的图像 2,3 Pentax LX Main PCB Removal, Remove front lens board: 步骤 12 中的图像 3,3
      • Unscrew four #00 X mm screws.
      • Unsolder one white wire.
      • Unsolder one pink wire.
      • Unsolder one light green wire.
      • Check the mounting points for shim washers. If they are loose, note the position and remove.
      • Installation Notes: Check the function of the self timer and the depth of field preview lever after install.
      询问修复机器人
      添加评论
    1. Pentax LX Main PCB Removal, Remove light seal frame: 步骤 13 中的图像 1,1
      • Remove four #000 1.8 mm screws.
      • Remove the light seal frame.
      询问修复机器人
      添加评论
    2. Pentax LX Main PCB Removal, Unsolder exp/ISO resistor: 步骤 14 中的图像 1,3 Pentax LX Main PCB Removal, Unsolder exp/ISO resistor: 步骤 14 中的图像 2,3 Pentax LX Main PCB Removal, Unsolder exp/ISO resistor: 步骤 14 中的图像 3,3
      • Unsolder one purple wire.
      • Unsolder one green wire.
      • Unsolder two brown wires under the loop of flex cable.
      询问修复机器人
      添加评论
    3. Pentax LX Main PCB Removal, Remove exp/ISO resistor: 步骤 15 中的图像 1,3 Pentax LX Main PCB Removal, Remove exp/ISO resistor: 步骤 15 中的图像 2,3 Pentax LX Main PCB Removal, Remove exp/ISO resistor: 步骤 15 中的图像 3,3
      • Unscrew three #00 3.0 mm screws.
      • Remove exp/ISO resistor assembly.
      • Remove exp. compensation coupling cam.
      • There are two loose ball bearings that sit in these holes. Do not lose.
      • Installation Note: Push this lever back to properly seat the exposure compensation lock. Check that the flag in the viewfinder is working properly. It should not be visible when dial is set to 1x and pop into view when set to any other value.
      添加评论
    4. Pentax LX Main PCB Removal, Detach metering cell PCB: 步骤 16 中的图像 1,1
      • Remove two #000 screws.
      • The PCB will remain attached but can move out of the way for soldering access.
      询问修复机器人
      添加评论
    5. Pentax LX Main PCB Removal, Unsolder adjustment PCB: 步骤 17 中的图像 1,2 Pentax LX Main PCB Removal, Unsolder adjustment PCB: 步骤 17 中的图像 2,2
      • Unsolder five black wires.
      • Unsolder two green wires.
      • Unsolder one yellow wire.
      • Unsolder one orange wire.
      • Unsolder one light brown wire.
      询问修复机器人
      添加评论
    6. Pentax LX Main PCB Removal, Remove battery compartment: 步骤 18 中的图像 1,2 Pentax LX Main PCB Removal, Remove battery compartment: 步骤 18 中的图像 2,2
      • Unscrew two #00 2.5 mm screws.
      询问修复机器人
      添加评论
    7. Pentax LX Main PCB Removal, Unsolder main PCB: 步骤 19 中的图像 1,3 Pentax LX Main PCB Removal, Unsolder main PCB: 步骤 19 中的图像 2,3 Pentax LX Main PCB Removal, Unsolder main PCB: 步骤 19 中的图像 3,3
      • Unsolder one light blue wire (may appear beige).
      • Unsolder two black wires.
      • Unsolder one brown wire.
      询问修复机器人
      添加评论
    8. Pentax LX Main PCB Removal, Unsoldering: 步骤 20 中的图像 1,3 Pentax LX Main PCB Removal, Unsoldering: 步骤 20 中的图像 2,3 Pentax LX Main PCB Removal, Unsoldering: 步骤 20 中的图像 3,3
      • Unsolder one light blue/teal wire.
      询问修复机器人
      添加评论
    9. Pentax LX Main PCB Removal, Remove condenser lens: 步骤 21 中的图像 1,1
      • Remove four #00 1.8 mm screws.
      • Lift out bezel with glass attached.
      询问修复机器人
      添加评论
    10. Pentax LX Main PCB Removal, Lock viewfinder needle indicator: 步骤 22 中的图像 1,2 Pentax LX Main PCB Removal, Lock viewfinder needle indicator: 步骤 22 中的图像 2,2
      • Turn shutter speed selector to 'Auto'.
      • Turn lock lever screw clockwise to loosen. Do not remove.
      • Lock lever screw is reverse threaded.
      • Push lock lever toward the needle indicator gear.
      • Turn lock lever screw counter-clockwise to tighten.
      • Locking the needle indicator keeps it in the proper position once the mirror box is removed.
      询问修复机器人
      添加评论
    11. Pentax LX Main PCB Removal, Unscrew main PCB: 步骤 23 中的图像 1,3 Pentax LX Main PCB Removal, Unscrew main PCB: 步骤 23 中的图像 2,3 Pentax LX Main PCB Removal, Unscrew main PCB: 步骤 23 中的图像 3,3
      • Remove two #00 2.8 mm screws. Remove two loose spacers underneath the PCB.
      • Remove two #00 2.0 mm screws.
      询问修复机器人
      添加评论
    12. Pentax LX Main PCB Removal, Remove mirror box: 步骤 24 中的图像 1,2 Pentax LX Main PCB Removal, Remove mirror box: 步骤 24 中的图像 2,2
      • Remove two #00 3.0 mm screws.
      • Remove one #00 5.0 mm screw.
      • Remove mirror box by lifting up then out. Pull slowly and check for snags as you remove.
      询问修复机器人
      添加评论
    13. Pentax LX Main PCB Removal, Installation Notes: Mirror box: 步骤 25 中的图像 1,2 Pentax LX Main PCB Removal, Installation Notes: Mirror box: 步骤 25 中的图像 2,2
      • Before installing the mirror box, the shutter should be wound and the mirror released into the taking position (up against the focusing screen).
      • After mounting the mirror box, make sure all necessary wires are available through the bottom of the camera for soldering.
      • Check for proper coupling of the self timer and the shutter button release.
      • Check that the closing curtain latch sits forward of the mirror return latch.
      • Check that the FP switch lever holds the magnet lever.
      • Select one of the mechanical shutter speeds and test the function of the mirror and shutter. The camera should be capable of a complete exposure cycle at this point.
      询问修复机器人
      添加评论
    1. Pentax LX Main PCB Removal, Unsolder main PCB: 步骤 26 中的图像 1,3 Pentax LX Main PCB Removal, Unsolder main PCB: 步骤 26 中的图像 2,3 Pentax LX Main PCB Removal, Unsolder main PCB: 步骤 26 中的图像 3,3
      • Unsolder three flash sync connections along the top of the viewfinder.
      询问修复机器人
      添加评论
    2. Pentax LX Main PCB Removal, Remove main PCB: 步骤 27 中的图像 1,3 Pentax LX Main PCB Removal, Remove main PCB: 步骤 27 中的图像 2,3 Pentax LX Main PCB Removal, Remove main PCB: 步骤 27 中的图像 3,3
      • Remove two 2.3 mm #00 screws holding the viewfinder LEDs. These will need to be properly aligned during reassembly.
      • Remove one 2.3 mm #00 screw.
      • Pull or pry off one 3.7 mm plastic retaining post.
      • Pull or pry off one 2.8 mm plastic retaining post.
      • Gently pull main PCB away from mirror box housing.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Sam Gustafson
于09/01/22注册
14,444 声望
创作了78篇指南
1指南评论
The Pentax LX camera does not function properly with the TTL feature when paired with the AF280T flash unit. Regardless of aperture setting—from minimum to maximum—the flash fires at full power. Furthermore, the camera's exposure indicator does not blink to confirm proper exposure after the shot. I can confirm the flash unit is in good working order, as it functions perfectly when used with a Pentax Super A camera. What should I do to resolve this issue?
Guanru Jin - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 39
总计 607
