跳转到主内容
加入维修社区 - 创建账户
Pebble Time Screen Cover Replacement
你所需要的
    1. Pebble Time Screen Cover Replacement, Screen Cover: 步骤 1 中的图像 1,1
      • Lay the watch flat on your workstation.
      询问修复机器人
      添加评论
    2. Pebble Time Screen Cover Replacement: 步骤 2 中的图像 1,2 Pebble Time Screen Cover Replacement: 步骤 2 中的图像 2,2
      • Use the metal spudger to carefully pull apart the screen cover from the case.
      • Replace the metal spudger with a plastic opening tool to hold the cover open.
      添加评论
    3. Pebble Time Screen Cover Replacement: 步骤 3 中的图像 1,1
      • Use the metal spudger tool to carefully loosen the rest of the cover.
      询问修复机器人
      添加评论
    4. Pebble Time Screen Cover Replacement: 步骤 4 中的图像 1,1
      • Carefully, pull apart the cover with the plastic opening tool.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Nicolas Hempe
于02/15/17注册
1,516 声望
创作了5篇指南
团队
USF Tampa, Team 1-3, Sullivan Spring 2017 USF Tampa, Team 1-3, Sullivan Spring 2017 的会员
USFT-SULLIVAN-S17S1G3
4 名成员
创作了27篇指南
5指南评论
What does one use to hold the screen on and reseal for waterproofing?
Shannon Oswald - 回复 分享
Using RTV silicon is problematic, I got some on my LCD and now I’m looking for a replacement Pebble.
HI I scratched my Crystal on my Pebble Time watch. Can the Crystal be buffed to get the scratch out??
Janice Pruett - 回复 分享
This is a brand new Pebble Time watch!!
CONCLUSION
To reassemble your device, follow these instructions in reverse order.”
Yeah, what about an adhesive or sealant? Best practice for doing so?
Adam MacDonald - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 36
总计 2,302
