跳转到主内容
加入维修社区 - 创建账户
Pantech Breakout Micro SD/SIM Card Replacement
  1. Pantech Breakout Micro SD/SIM Card Replacement, Removing Back Cover: 步骤 1 中的图像 1,3 Pantech Breakout Micro SD/SIM Card Replacement, Removing Back Cover: 步骤 1 中的图像 2,3 Pantech Breakout Micro SD/SIM Card Replacement, Removing Back Cover: 步骤 1 中的图像 3,3
    • Before proceeding, completely power off phone and disconnect power cords to avoid electrical shock.
    • Turn phone over so that the back side is facing up.
    • Using a finger, apply moderate pressure to the top of the back cover while sliding the cover down and off.
    • Lift and remove the back cover from the phone.
    询问修复机器人
    添加评论
  2. Pantech Breakout Micro SD/SIM Card Replacement, Removing the Battery: 步骤 2 中的图像 1,2 Pantech Breakout Micro SD/SIM Card Replacement, Removing the Battery: 步骤 2 中的图像 2,2
    • Locate the battery: It is a silver, rectangular object.
    • Insert a fingernail into the indent just below the battery about 0.5 inches from the bottom of the phone.
    • Then, apply pressure to the battery, pushing up and away from the phone. It will come out easily.
    询问修复机器人
    添加评论
  3. Pantech Breakout Micro SD/SIM Card Replacement, Inserting Micro SD or SIM Card: 步骤 3 中的图像 1,2 Pantech Breakout Micro SD/SIM Card Replacement, Inserting Micro SD or SIM Card: 步骤 3 中的图像 2,2
    • The slots for the Micro SD and SIM cards are directly above the battery tray.
    • To insert a card, slide it face up into the slot. To remove a card, slide the card out from the slot.
    • Micro SD Card Slot - On the Left
    • SIM Card Slot - On the Right
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
Ryan Murphy
于09/25/14注册
898 声望
创作了7篇指南
团队
USF Tampa, Team 5-5, Mcgee Fall 2014 USF Tampa, Team 5-5, Mcgee Fall 2014 的会员
USFT-MCGEE-F14S5G5
4 名成员
创作了28篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 44
总计 2,980
