跳转到主内容
加入维修社区 - 创建账户
Panasonic Lumix ZS50 Flash Assembly Replacement
你所需要的
    1. Panasonic Lumix ZS50 Flash Assembly Replacement, Battery: 步骤 1 中的图像 1,2 Panasonic Lumix ZS50 Flash Assembly Replacement, Battery: 步骤 1 中的图像 2,2
      • Turn the camera off and identify the battery door located on the bottom of the camera.
      询问修复机器人
      添加评论
    2. Panasonic Lumix ZS50 Flash Assembly Replacement: 步骤 2 中的图像 1,2 Panasonic Lumix ZS50 Flash Assembly Replacement: 步骤 2 中的图像 2,2
      • Slide the "open" latch to the left: the battery door should spring open.
      • If your battery door doesn't open you may have to pry it open using a plastic opening tool or a standard spudger.
      询问修复机器人
      添加评论
    3. Panasonic Lumix ZS50 Flash Assembly Replacement: 步骤 3 中的图像 1,1
      • To release the battery, slide the white release lever next to the SD card slot.
      • If you find the battery release lever to be jammed you can push it using a plastic opening tool or standard spudger.
      询问修复机器人
      添加评论
    4. Panasonic Lumix ZS50 Flash Assembly Replacement: 步骤 4 中的图像 1,1
      • The battery should now be released; you may now remove the battery from the camera body.
      询问修复机器人
      添加评论
    1. Panasonic Lumix ZS50 Flash Assembly Replacement, LCD Screen: 步骤 5 中的图像 1,3 Panasonic Lumix ZS50 Flash Assembly Replacement, LCD Screen: 步骤 5 中的图像 2,3 Panasonic Lumix ZS50 Flash Assembly Replacement, LCD Screen: 步骤 5 中的图像 3,3
      • Orient the camera so the bottom is facing up and the battery door is on the right side.
      • Remove four black screws from the bottom of the camera.
      • Remove two black screws from the right side of the camera.
      • Remove one black screw from the left side of the camera.
      添加评论
    2. Panasonic Lumix ZS50 Flash Assembly Replacement: 步骤 6 中的图像 1,2 Panasonic Lumix ZS50 Flash Assembly Replacement: 步骤 6 中的图像 2,2
      • Remove the casing from the camera by hand or using a plastic opening tool.
      询问修复机器人
      添加评论
    3. Panasonic Lumix ZS50 Flash Assembly Replacement: 步骤 7 中的图像 1,2 Panasonic Lumix ZS50 Flash Assembly Replacement: 步骤 7 中的图像 2,2
      • Use a spudger to lift up and tug off the green button board.
      • Be careful to not damage the attached ribbon cable.
      询问修复机器人
      添加评论
    4. Panasonic Lumix ZS50 Flash Assembly Replacement: 步骤 8 中的图像 1,3 Panasonic Lumix ZS50 Flash Assembly Replacement: 步骤 8 中的图像 2,3 Panasonic Lumix ZS50 Flash Assembly Replacement: 步骤 8 中的图像 3,3
      • Remove the screen using the plastic opening tool, prying from the top.
      • Once it's lifted up, tug lightly on the large ribbon cable to detach the screen from the camera body.
      添加评论
    1. Panasonic Lumix ZS50 Flash Assembly Replacement, Lens Assembly: 步骤 9 中的图像 1,3 Panasonic Lumix ZS50 Flash Assembly Replacement, Lens Assembly: 步骤 9 中的图像 2,3 Panasonic Lumix ZS50 Flash Assembly Replacement, Lens Assembly: 步骤 9 中的图像 3,3
      • Remove the three screws from the center of the copper plate.
      • Remove the four screws from the outer edges of the copper plate.
      • Use a plastic or metal spudger to pry the copper plate out of place.
      添加评论
    2. Panasonic Lumix ZS50 Flash Assembly Replacement: 步骤 10 中的图像 1,2 Panasonic Lumix ZS50 Flash Assembly Replacement: 步骤 10 中的图像 2,2
      • Remove the casing from the circuitboard by hand.
      • Remove the HDMI port casing by hand.
      询问修复机器人
      添加评论
    3. Panasonic Lumix ZS50 Flash Assembly Replacement: 步骤 11 中的图像 1,3 Panasonic Lumix ZS50 Flash Assembly Replacement: 步骤 11 中的图像 2,3 Panasonic Lumix ZS50 Flash Assembly Replacement: 步骤 11 中的图像 3,3
      • Disconnect all orange ribbon cables connecting to the circuitboard by hand.
      • Disconnect the circuitboard by hand.
      • There will be one orange ribbon cable attached to the top that can now be removed.
      询问修复机器人
      添加评论
    4. Panasonic Lumix ZS50 Flash Assembly Replacement: 步骤 12 中的图像 1,3 Panasonic Lumix ZS50 Flash Assembly Replacement: 步骤 12 中的图像 2,3 Panasonic Lumix ZS50 Flash Assembly Replacement: 步骤 12 中的图像 3,3
      • Remove the seven screws surrounding the lens assembly.
      • Move all ribbon cables out of your way while unscrewing.
      • Remove the three springs surrounding the lens.
      • Apply pressure on the front of the lens to push the lens out.
      添加评论
    1. Panasonic Lumix ZS50 Flash Assembly Replacement, Flash Assembly: 步骤 13 中的图像 1,3 Panasonic Lumix ZS50 Flash Assembly Replacement, Flash Assembly: 步骤 13 中的图像 2,3 Panasonic Lumix ZS50 Flash Assembly Replacement, Flash Assembly: 步骤 13 中的图像 3,3
      • Remove the one screw holding the camera and the flash component together.
      • Gently pull the flash component out of the camera body.
      询问修复机器人
      添加评论
    2. Panasonic Lumix ZS50 Flash Assembly Replacement: 步骤 14 中的图像 1,3 Panasonic Lumix ZS50 Flash Assembly Replacement: 步骤 14 中的图像 2,3 Panasonic Lumix ZS50 Flash Assembly Replacement: 步骤 14 中的图像 3,3
      • Separate the top camera casing from the flash component by unscrewing the three surrounding screws.
      • Remove the flash assembly, including the circuit board, by detaching it and the ribbon cables from the casing.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
Baylor, Team 8-5, Whitney Spring 2017 Baylor, Team 8-5, Whitney Spring 2017 的会员
BU-WHITNEY-S17S8G5
3 名成员
创作了16篇指南
1指南评论
Step 7: Does not mention the HDMI port door. Make sure you account for it
BayleeVersteeg - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 22
过去 30 天: 97
总计 1,031
