跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Panasonic Lumix DMC-ZS25 Speaker Replacement
你所需要的
  1. Panasonic Lumix DMC-ZS25 Speaker Replacement, Speaker: 步骤 1 中的图像 1,3 Panasonic Lumix DMC-ZS25 Speaker Replacement, Speaker: 步骤 1 中的图像 2,3 Panasonic Lumix DMC-ZS25 Speaker Replacement, Speaker: 步骤 1 中的图像 3,3
    • Remove the four 3.4 mm screws from the right and left sides of your Panasonic Lumix Camera.
    • Remove the two 2.6 mm screws located next to the battery.
  2. Panasonic Lumix DMC-ZS25 Speaker Replacement: 步骤 2 中的图像 1,1
    • Use the plastic opening tool to lift off the rear cover of your device. Go gently to avoid breaking anything.
    • The easiest place to open your device is from the HDMI port.
    • Gently does it.
  3. Panasonic Lumix DMC-ZS25 Speaker Replacement: 步骤 3 中的图像 1,3 Panasonic Lumix DMC-ZS25 Speaker Replacement: 步骤 3 中的图像 2,3 Panasonic Lumix DMC-ZS25 Speaker Replacement: 步骤 3 中的图像 3,3
    • Use a spudger to lift the LCD ribbon cable locking bar by angling it up, then withdraw the ribbon.
    • Take care not to break it.
    • Use the plastic opening tool at the bottom right hand side of the button board to lift it up and out.
    • The buttons board comes out with a "click" as it snaps out of a connector below.
  4. Panasonic Lumix DMC-ZS25 Speaker Replacement: 步骤 4 中的图像 1,2 Panasonic Lumix DMC-ZS25 Speaker Replacement: 步骤 4 中的图像 2,2
    • The LCD is retained by a clip on the left hand side, which you can release with a plastic opening too.
    • Lift the LCD from the left hand side, disengaging it at the right hand side from two small tabs.
  5. Panasonic Lumix DMC-ZS25 Speaker Replacement: 步骤 5 中的图像 1,2 Panasonic Lumix DMC-ZS25 Speaker Replacement: 步骤 5 中的图像 2,2
    • Remove the two 4.2 mm screws in order to remove the inner cover located beneath the screen.
    • Having removed the screws, use the plastic opening tool to lift off the inner cover, releasing it from clips on the top and bottom edges.
  6. Panasonic Lumix DMC-ZS25 Speaker Replacement: 步骤 6 中的图像 1,2 Panasonic Lumix DMC-ZS25 Speaker Replacement: 步骤 6 中的图像 2,2
    • Remove the side covers using the plastic opening tool.
  7. Panasonic Lumix DMC-ZS25 Speaker Replacement: 步骤 7 中的图像 1,2 Panasonic Lumix DMC-ZS25 Speaker Replacement: 步骤 7 中的图像 2,2
    • After removing the side covers, you will be able to pull off the front cover.
    • Be careful when you pull the front cover to avoid breaking anything.
  8. Panasonic Lumix DMC-ZS25 Speaker Replacement: 步骤 8 中的图像 1,1
    • To remove the top cover, you need to remove a 3.7 mm screw as shown.
  9. Panasonic Lumix DMC-ZS25 Speaker Replacement: 步骤 9 中的图像 1,3 Panasonic Lumix DMC-ZS25 Speaker Replacement: 步骤 9 中的图像 2,3 Panasonic Lumix DMC-ZS25 Speaker Replacement: 步骤 9 中的图像 3,3
    • Release the top cover by lifting several tabs with the plastic opening tool. Go gently to avoid breaking them.
  10. Panasonic Lumix DMC-ZS25 Speaker Replacement: 步骤 10 中的图像 1,3 Panasonic Lumix DMC-ZS25 Speaker Replacement: 步骤 10 中的图像 2,3 Panasonic Lumix DMC-ZS25 Speaker Replacement: 步骤 10 中的图像 3,3
    • With the top cover removed the speaker can be very easily removed or replaced.
结论
团队
USF Tampa, Team 9-5, Brown Winter 2015 USF Tampa, Team 9-5, Brown Winter 2015 的会员
USFT-BROWN-W15S9G5
3 名成员
创作了7篇指南
一条评论
In step 5, comparing it with the similar DMC-TZ35 I rather think there should be 3 screws, not 2. A 3rd hole can be seen at the bottom.
Philip Le Riche - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 18
总计 770
