当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
Use a spudger to lift the LCD ribbon cable locking bar by angling it up, then withdraw the ribbon.
Use the plastic opening tool at the bottom right hand side of the button board to lift it up and out.
The buttons board comes out with a "click" as it snaps out of a connector below.
即将完成!
终点
一条评论
In step 5, comparing it with the similar DMC-TZ35 I rather think there should be 3 screws, not 2. A 3rd hole can be seen at the bottom.
