跳转到主内容
加入维修社区 - 创建账户
Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement
你所需要的
    1. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement, Battery: 步骤 1 中的图像 1,1
      • On the bottom of the camera, use your finger to push the lock button to the open position which will cause the hinged door to swing open.
      询问修复机器人
      添加评论
    2. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: 步骤 2 中的图像 1,2 Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: 步骤 2 中的图像 2,2
      • Push the small black tab that holds the battery with your finger to release the battery.
      • Use your fingers to pull the battery out of the camera.
      询问修复机器人
      添加评论
    1. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement, Back Cover: 步骤 3 中的图像 1,3 Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement, Back Cover: 步骤 3 中的图像 2,3 Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement, Back Cover: 步骤 3 中的图像 3,3
      • Using a Phillips #00 screwdriver, remove six 2.69mm, silver screws located on the two short sides of the camera and the bottom side.
      添加评论
    2. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: 步骤 4 中的图像 1,3 Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: 步骤 4 中的图像 2,3 Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: 步骤 4 中的图像 3,3
      • Gently lift up the back cover to access the ZIF connectors for the blue and yellow ribbons.
      • To unlock the ZIF connectors, gently push the black portion of the lock from a flat position to an upright position using a spudger.
      • Take caution not to rip the ribbons out of the ZIF connectors when lifting the back panel.
      询问修复机器人
      添加评论
    3. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: 步骤 5 中的图像 1,1
      • Gently push the blue and yellow ribbons out of the unlocked ZIF connectors using your fingers.
      询问修复机器人
      添加评论
    4. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: 步骤 6 中的图像 1,1
      • Using a Phillips #00 screwdriver, remove the 3.5 mm silver screw from the upper left hand corner of the back cover.
      询问修复机器人
      添加评论
    5. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: 步骤 7 中的图像 1,1
      • Using a spudger, lift up and remove the plastic cover piece from the back cover.
      • Plastic cover may fall off without prying.
      询问修复机器人
      添加评论
    6. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: 步骤 8 中的图像 1,1
      • Using a Phillips #00 screwdriver, remove the 2.69 mm silver screw located beneath the plastic piece that was previously removed.
      询问修复机器人
      添加评论
    7. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: 步骤 9 中的图像 1,1
      • Using a spudger, lift up and separate the heavier metal cover from the light, plastic back cover.
      • Metal cover may fall off without prying.
      询问修复机器人
      添加评论
    1. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement, Back Panel Buttons: 步骤 10 中的图像 1,2 Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement, Back Panel Buttons: 步骤 10 中的图像 2,2
      • Push on the back panel buttons from the frontside of the back cover.
      • There might be some adhesives holding the back panel buttons to the cover. Extra force may be necessary.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Kingsley East
于10/30/16注册
474 声望
创作了4篇指南
团队
Baylor, Team 5-9, Williams Fall 2016 Baylor, Team 5-9, Williams Fall 2016 的会员
BU-WILLIAMS-F16S5G9
3 名成员
创作了11篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 28
总计 1,216
