跳转到主内容
加入维修社区 - 创建账户
Panasonic DVD-RV31 Player Left Control Board Replacement
你所需要的
  1. Panasonic DVD-RV31 Player Left Control Board Replacement, Outer Case: 步骤 1 中的图像 1,2 Panasonic DVD-RV31 Player Left Control Board Replacement, Outer Case: 步骤 1 中的图像 2,2
    • Remove the three screws running along the back edge of case cover.
    • Remove the two screws from each side of the case cover.
  2. Panasonic DVD-RV31 Player Left Control Board Replacement: 步骤 2 中的图像 1,1
    • Grab edges of the cover with your hands. Pull outward slightly, then straight up.
  3. Panasonic DVD-RV31 Player Left Control Board Replacement, Front Panel: 步骤 3 中的图像 1,2 Panasonic DVD-RV31 Player Left Control Board Replacement, Front Panel: 步骤 3 中的图像 2,2
    • Lift up the five tabs securing the front panel to the chassis. There are three on the bottom, and two on the inside edges of the panel. Panel should then lift off the player.
  4. Panasonic DVD-RV31 Player Left Control Board Replacement, Left Control Board: 步骤 4 中的图像 1,2 Panasonic DVD-RV31 Player Left Control Board Replacement, Left Control Board: 步骤 4 中的图像 2,2
    • Grip jogger dial and lift up. It should come off easily.
  5. Panasonic DVD-RV31 Player Left Control Board Replacement: 步骤 5 中的图像 1,3 Panasonic DVD-RV31 Player Left Control Board Replacement: 步骤 5 中的图像 2,3 Panasonic DVD-RV31 Player Left Control Board Replacement: 步骤 5 中的图像 3,3
    • Remove 4 mounting screws as shown.
    • Unscrew and save brass tab.
    • Push in 2 plastic retainers and lift out.
结论
Kevin
于04/26/11注册
375 声望
创作了8篇指南
团队
Cal Poly, Team 18-20, Garner Spring 2011 Cal Poly, Team 18-20, Garner Spring 2011 的会员
CPSU-GARNER-S11S18G20
4 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 49
总计 2,383
