跳转到主内容
加入维修社区 - 创建账户
Panasonic DVD-RV31 Player Disc Retainer Replacement
你所需要的
    1. Panasonic DVD-RV31 Player Disc Retainer Replacement, Disk Tray Cover: 步骤 1 中的图像 1,1
      • Eject the disk tray from the DVD player before removing power supply.
      询问修复机器人
      添加评论
    2. Panasonic DVD-RV31 Player Disc Retainer Replacement: 步骤 2 中的图像 1,1
      • Evenly lift upward on the disk tray front cover (not slanted, as pictured). This will allow for easier disassembly of the player.
      询问修复机器人
      添加评论
    1. Panasonic DVD-RV31 Player Disc Retainer Replacement, Outer Case: 步骤 3 中的图像 1,2 Panasonic DVD-RV31 Player Disc Retainer Replacement, Outer Case: 步骤 3 中的图像 2,2
      • Remove the three screws running along the back edge of case cover.
      • Remove the two screws from each side of the case cover.
      询问修复机器人
      添加评论
    2. Panasonic DVD-RV31 Player Disc Retainer Replacement: 步骤 4 中的图像 1,1
      • Grab edges of the cover with your hands. Pull outward slightly, then straight up.
      询问修复机器人
      添加评论
    1. Panasonic DVD-RV31 Player Disc Retainer Replacement, Front Panel: 步骤 5 中的图像 1,2 Panasonic DVD-RV31 Player Disc Retainer Replacement, Front Panel: 步骤 5 中的图像 2,2
      • Lift up the five tabs securing the front panel to the chassis. There are three on the bottom, and two on the inside edges of the panel. Panel should then lift off the player.
      添加评论
    1. Panasonic DVD-RV31 Player Disc Retainer Replacement, Disk Drive: 步骤 6 中的图像 1,3 Panasonic DVD-RV31 Player Disc Retainer Replacement, Disk Drive: 步骤 6 中的图像 2,3 Panasonic DVD-RV31 Player Disc Retainer Replacement, Disk Drive: 步骤 6 中的图像 3,3
      • Locate the four screws securing the disk drive assembly. There are two on each side.
      • Use a narrow screwdriver to remove all four screws.
      • Remove the blue ribbon wire from its connector. When doing this, be cautious to not damage the connector.
      添加评论
    2. Panasonic DVD-RV31 Player Disc Retainer Replacement: 步骤 7 中的图像 1,1
      • Lift assembly by the front to pull metal bracket from the power board.
      • Pull up back end and lift drive out.
      询问修复机器人
      添加评论
    3. Panasonic DVD-RV31 Player Disc Retainer Replacement: 步骤 8 中的图像 1,1
      • With the drive assembly separate from the player, hold as shown and pull the bracket edges away from the disk drive.
      • Lift bracket off and reserve for re-assembly.
      询问修复机器人
      添加评论
    1. Panasonic DVD-RV31 Player Disc Retainer Replacement, Disc Retainer: 步骤 9 中的图像 1,3 Panasonic DVD-RV31 Player Disc Retainer Replacement, Disc Retainer: 步骤 9 中的图像 2,3 Panasonic DVD-RV31 Player Disc Retainer Replacement, Disc Retainer: 步骤 9 中的图像 3,3
      • Grasp the bridge above the wheel and push the tabs on the side as shown.
      • Pull down firmly and away from the laser housing.
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
Kevin
于04/26/11注册
375 声望
创作了8篇指南
团队
Cal Poly, Team 18-20, Garner Spring 2011 Cal Poly, Team 18-20, Garner Spring 2011 的会员
CPSU-GARNER-S11S18G20
4 名成员
创作了47篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 47
总计 5,930
