跳转到主内容
加入维修社区 - 创建账户
Panasonic DMC-FZ70 Back Panel Replacement
你所需要的
    1. Panasonic DMC-FZ70 Back Panel Replacement, Back Panel: 步骤 1 中的图像 1,2 Panasonic DMC-FZ70 Back Panel Replacement, Back Panel: 步骤 1 中的图像 2,2
      • All screws should be removed using a Phillips #0 screwdriver.
      • Using your screwdriver, unscrew the two 5.0 mm Philips screws to the right of the LCD screen.
      询问修复机器人
      添加评论
    2. Panasonic DMC-FZ70 Back Panel Replacement: 步骤 2 中的图像 1,2 Panasonic DMC-FZ70 Back Panel Replacement: 步骤 2 中的图像 2,2
      • Flip the camera over to the left side of the screen and unscrew the 5mm Phillips screw found there.
      询问修复机器人
      添加评论
    3. Panasonic DMC-FZ70 Back Panel Replacement: 步骤 3 中的图像 1,2 Panasonic DMC-FZ70 Back Panel Replacement: 步骤 3 中的图像 2,2
      • Turn the camera upside down and unscrew the three 5mm screws found on the bottom.
      询问修复机器人
      添加评论
    4. Panasonic DMC-FZ70 Back Panel Replacement: 步骤 4 中的图像 1,2 Panasonic DMC-FZ70 Back Panel Replacement: 步骤 4 中的图像 2,2
      • On the top of the camera locate the two rails with a thin sheet of metal on the floor between them.
      • With a metal spudger, lift this sheet and push it out of the rail device to detach it from the camera.
      询问修复机器人
      添加评论
    5. Panasonic DMC-FZ70 Back Panel Replacement: 步骤 5 中的图像 1,1
      • Proceed to remove the four 5mm Phillips screws that you just uncovered.
      询问修复机器人
      添加评论
    6. Panasonic DMC-FZ70 Back Panel Replacement: 步骤 6 中的图像 1,1
      • Slowly pull on both side of the camera, until both halves begin to separate from each other.
      • Do not pull too hard, as both halves are held together with ZIF connector cables.
      询问修复机器人
      添加评论
    7. Panasonic DMC-FZ70 Back Panel Replacement: 步骤 7 中的图像 1,3 Panasonic DMC-FZ70 Back Panel Replacement: 步骤 7 中的图像 2,3 Panasonic DMC-FZ70 Back Panel Replacement: 步骤 7 中的图像 3,3
      • Using a plastic opening tool, carefully flip up the small black levers that attach the ribbon cables to the ZIF connectors on the motherboard.
      • Carefully pull the ribbon cables out of the slot once they have been released.
      • Only the two indicated connectors need to be removed to separate the two halves of the camera.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
Cal Poly, Team 21-3, Maness Winter 2017 Cal Poly, Team 21-3, Maness Winter 2017 的会员
CPSU-MANESS-W17S21G3
6 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 27
总计 1,174
