跳转到主内容
加入维修社区 - 创建账户
PalmOne Zire 72 Battery Replacement
你所需要的
    1. PalmOne Zire 72 Battery Replacement, Battery: 步骤 1 中的图像 1,2 PalmOne Zire 72 Battery Replacement, Battery: 步骤 1 中的图像 2,2
      • Using a T5 Torx screwdriver, unscrew the two 5mm screws located at the bottom of the device.
      询问修复机器人
      添加评论
    2. PalmOne Zire 72 Battery Replacement: 步骤 2 中的图像 1,1
      • Peel back the adhesive label below the camera on the rear to reveal a hidden screw.
      • If you peel the entire adhesive off, two holes underneath will be exposed to future damage. Try to preserve the label to reapply later.
      • Alternate Procedure: Underneath the camera, feel for a depression and cut the sticker directly above the depression to reveal the hidden screw.
      询问修复机器人
      添加评论
    3. PalmOne Zire 72 Battery Replacement: 步骤 3 中的图像 1,1
      • Use a #00 Philips screwdriver to remove the 2.5mm hidden screw.
      询问修复机器人
      添加评论
    4. PalmOne Zire 72 Battery Replacement: 步骤 4 中的图像 1,1
      • Use either end of a a spudger to carefully pry off the camera lens mesh cover.
      询问修复机器人
      添加评论
    5. PalmOne Zire 72 Battery Replacement: 步骤 5 中的图像 1,1
      • Using the #00 Phillips screwdriver, remove the two 9mm screws on the top corners of the device.
      询问修复机器人
      添加评论
    6. PalmOne Zire 72 Battery Replacement: 步骤 6 中的图像 1,2 PalmOne Zire 72 Battery Replacement: 步骤 6 中的图像 2,2
      • Spin the phone around so that the headphone jack is facing you.
      • Run the flat end of the spudger around the entire edge of the device to gently pry the case off.
      • Gently remove the case to avoid damaging it. Do not try to force the case open.
      • The L shaped latches located on the bottom of the device make it hard to remove the case; you should run the spudger around the device's edges again if you are having problems.
      询问修复机器人
      添加评论
    7. PalmOne Zire 72 Battery Replacement: 步骤 7 中的图像 1,2 PalmOne Zire 72 Battery Replacement: 步骤 7 中的图像 2,2
      • Remove the cover by lifting it from right to left.
      • This should be similar to the action of the opening of a book.
      • A connector may tear if this is not done carefully. The connector is a brown film connecting the motherboard to the case.
      询问修复机器人
      添加评论
    8. PalmOne Zire 72 Battery Replacement: 步骤 8 中的图像 1,1
      • Lift the control pad buttons off of the motherboard.
      询问修复机器人
      添加评论
    9. PalmOne Zire 72 Battery Replacement: 步骤 9 中的图像 1,1
      • Wedge the flat end of the spudger underneath the battery and gently pry it out.
      • Be cautious of the red and black wires on the battery, which may rip easily.
      • The battery may have adhesive holding it to the device.
      • The battery connector may rip if the battery is not removed carefully.
      询问修复机器人
      添加评论
    10. PalmOne Zire 72 Battery Replacement: 步骤 10 中的图像 1,1
      • Gently disconnect the white component connecting the battery to the motherboard.
      • The connector should be pulled upward.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
团队
Cal Poly, Team 6-49, Amido Spring 2012 Cal Poly, Team 6-49, Amido Spring 2012 的会员
CPSU-AMIDO-S12S6G49
4 名成员
创作了40篇指南
3指南评论
When going to put this back together the clips at the bottom of the unit did not want to go back into place. I found I had to clip off the clips with some high end wire cutters. The screws will hold it together anyway so they are redundant and you will be happier the next time you have to open it as it will be easier.
Also the first time you pry open the top of the unit as described you may bend a metal clip for the card slot. Be careful or you might destroy it. In my case it was just a bit bent and with electronics tweezers I was able to bend it back into shape and put it back in it's proper place. This is likely unavoidable especially the first time due to how tight the plastic and metal clips are.
Whatever you do be slow with the process. Trying to do it to fast will likely lead to problems. Thanks for the excellent instructions. They were quite helpful.
Leland Whitlock - 回复 分享
Hi is this unit of any value today?
Frank carmona - 回复 分享
For reassembly, the clips on the bottom are tricky, but you can press them in with your spudger to make it much easier to snap the halves back together.
cstrife89 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 13
过去 30 天: 70
总计 4,158
