跳转到主内容
加入维修社区 - 创建账户
Palm Zire m150 Control Button Replacement
你所需要的
    1. Palm Zire m150 Control Button Replacement, Control Button: 步骤 1 中的图像 1,2 Palm Zire m150 Control Button Replacement, Control Button: 步骤 1 中的图像 2,2
      • Lift up the flap on the Palm Zire M150.
      • For the purpose of this guide and being able to see clearly, we removed the flap completely. You can keep your flap on if you wish.
      • If you wish to remove it, gently lift up on the flap and pull horizontally. It should come off without an issue.
      询问修复机器人
      添加评论
    2. Palm Zire m150 Control Button Replacement: 步骤 2 中的图像 1,1
      • Take the screwdriver from the IFixit toolkit and use the T6 bit. Unscrew the the top two 3mm screws above where the flap was connected to the device.
      询问修复机器人
      添加评论
    3. Palm Zire m150 Control Button Replacement: 步骤 3 中的图像 1,2 Palm Zire m150 Control Button Replacement: 步骤 3 中的图像 2,2
      • Gently pull the top half and bottom half off the device apart using both hands so that it looks like the second photo.
      • You can use your finger nails to pry apart the top half and the bottom half of the device. If that doesn't work, use the opening picks from the toolkit.
      询问修复机器人
      添加评论
    4. Palm Zire m150 Control Button Replacement: 步骤 4 中的图像 1,1
      • This is the button that you are going to be replacing. Grab the grey button and pull it apart from the device.
      • If you are not replacing the button and you are just cleaning it, make sure you are gentle when you pull it from the device so that you don't break the button.
      • You can use compressed air to clean them or an alcohol wipe.
      询问修复机器人
      添加评论
    5. Palm Zire m150 Control Button Replacement: 步骤 5 中的图像 1,1
      • The button is now off of the device. If you are cleaning it, use the compressed air or the alcohol wipe.
      • If installing a new button, throw away the one you just took off and snap the new one back on the white piece.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Kate
于01/26/16注册
528 声望
创作了5篇指南
团队
1指南评论
Kate what hairy arms you have lol
Jimfixer - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 33
总计 865
