跳转到主内容
加入维修社区 - 创建账户
Palm Treo Pro Display Glass Replacement
你所需要的
  1. Palm Treo Pro Display Glass Replacement, Battery: 步骤 1 中的图像 1,3 Palm Treo Pro Display Glass Replacement, Battery: 步骤 1 中的图像 2,3 Palm Treo Pro Display Glass Replacement, Battery: 步骤 1 中的图像 3,3
    • Press down on the back of the case and slide forward to remove it.
    询问修复机器人
    添加评论
  2. Palm Treo Pro Display Glass Replacement: 步骤 2 中的图像 1,1
    • Remove the battery by pulling up on the tab near the camera lens.
    • Insert the new battery into the open slot. Make sure the battery is oriented so that the Palm logo is in the upper-left corner opposite the camera lens.
    询问修复机器人
    添加评论
  3. Palm Treo Pro Display Glass Replacement, Motherboard: 步骤 3 中的图像 1,3 Palm Treo Pro Display Glass Replacement, Motherboard: 步骤 3 中的图像 2,3 Palm Treo Pro Display Glass Replacement, Motherboard: 步骤 3 中的图像 3,3
    • Use the Torx T5 screwdriver to remove the 5 visible 6mm screws on the back of the phone.
    • Be careful not to misplace these screws as they are very small and will be important during reassembly.
    • If the screws are stripped a flat head screw driver may be necessary.
    询问修复机器人
    添加评论
  4. Palm Treo Pro Display Glass Replacement: 步骤 4 中的图像 1,3 Palm Treo Pro Display Glass Replacement: 步骤 4 中的图像 2,3 Palm Treo Pro Display Glass Replacement: 步骤 4 中的图像 3,3
    • Use a plastic opening tool to remove the small panel on the top of the phone by prying underneath the black plastic around the camera.
    询问修复机器人
    添加评论
  5. Palm Treo Pro Display Glass Replacement: 步骤 5 中的图像 1,3 Palm Treo Pro Display Glass Replacement: 步骤 5 中的图像 2,3 Palm Treo Pro Display Glass Replacement: 步骤 5 中的图像 3,3
    • Remove the main plastic body
    • Insert the plastic opening tool into the slot on the top (indicated by the spudger) and pry the black part off phone.
    • The bottom piece around the headphone and USB port may get caught during this step. Simply carefully maneuver the case until it is released.
    询问修复机器人
    添加评论
  6. Palm Treo Pro Display Glass Replacement: 步骤 6 中的图像 1,3 Palm Treo Pro Display Glass Replacement: 步骤 6 中的图像 2,3 Palm Treo Pro Display Glass Replacement: 步骤 6 中的图像 3,3
    • Use the Philips Head 00 screwdriver to unscrew the 3.5mm silver screw on the right hand side of the phone.
    • Use the Philips Head 00 screwdriver to unscrew the two 3mm black screws in the upper right and lower left corners of the motherboard.
    询问修复机器人
    添加评论
  7. Palm Treo Pro Display Glass Replacement: 步骤 7 中的图像 1,2 Palm Treo Pro Display Glass Replacement: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    • Use tweezers to carefully remove the yellow piece of tape covering the two ribbon cables.
    询问修复机器人
    添加评论
  8. Palm Treo Pro Display Glass Replacement: 步骤 8 中的图像 1,3 Palm Treo Pro Display Glass Replacement: 步骤 8 中的图像 2,3 Palm Treo Pro Display Glass Replacement: 步骤 8 中的图像 3,3
    • There are two ribbon cables under the yellow tape.
    • Use tweezers to safely unplug the small ribbon cable first and then the large ribbon cable.
    • To remove the cables there is a small black lock that needs to be in the up position as indicated in picture two.
    询问修复机器人
    添加评论
  9. Palm Treo Pro Display Glass Replacement: 步骤 9 中的图像 1,3 Palm Treo Pro Display Glass Replacement: 步骤 9 中的图像 2,3 Palm Treo Pro Display Glass Replacement: 步骤 9 中的图像 3,3
    • Use a plastic opening tool to lift the motherboard up and out of the phone case
    • There is a black cable under the motherboard that must be disconnected while the motherboard is still in the phone
    • It can easily be disconnected with your fingers
    • Note: During this process the mute and power buttons may fall out of the phone. Do not panic this is completely normal. Set them aside in a safe place until reassembly.
    • The motherboard has now been completely removed
    询问修复机器人
    添加评论
  10. Palm Treo Pro Display Glass Replacement, Display Glass: 步骤 10 中的图像 1,2 Palm Treo Pro Display Glass Replacement, Display Glass: 步骤 10 中的图像 2,2
    • Use the plastic opening tool to pry the side of the display glass up so you can easily remove it with your hand.
    • Note: The display glass is the metallic rectangle with a orange ribbon cable attached to it.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Kyle Gilbert
于04/17/13注册
1 声望
创作了2篇指南
团队
Cal Poly, Team 8-59, Johann Spring 2013 Cal Poly, Team 8-59, Johann Spring 2013 的会员
CPSU-JOHANN-S13S8G59
4 名成员
创作了19篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 22
总计 581
