跳转到主内容
加入维修社区 - 创建账户
Palm Treo 680 screen replacement
你所需要的
  1. Palm Treo 680 screen replacement, Battery: 步骤 1 中的图像 1,2 Palm Treo 680 screen replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the battery cover by pressing on the small rectangular button located on the back of the phone.
    添加评论
  2. Palm Treo 680 screen replacement: 步骤 2 中的图像 1,1
    • Remove the battery by pulling it out towards you.
    询问修复机器人
    添加评论
  3. Palm Treo 680 screen replacement, Back Panel: 步骤 3 中的图像 1,2 Palm Treo 680 screen replacement, Back Panel: 步骤 3 中的图像 2,2
    • Remove the stylus in order to access the screw.
    • Remove the 27mm top-left screw using a T6 Torx screwdriver.
    添加评论
  4. Palm Treo 680 screen replacement: 步骤 4 中的图像 1,2 Palm Treo 680 screen replacement: 步骤 4 中的图像 2,2
    • Using the spudger, remove the rubber rectangular cover located in the upper rear, right-hand corner.
    • Remove the 27mm screw using the T6 Torx screwdriver.
    • If there is a red Palm sticker covering this screw, puncture it to access the screw.
    询问修复机器人
    添加评论
  5. Palm Treo 680 screen replacement: 步骤 5 中的图像 1,1
    • Remove the remaining two 27mm screws from the bottom using the T6 screwdriver.
    询问修复机器人
    添加评论
  6. Palm Treo 680 screen replacement: 步骤 6 中的图像 1,3 Palm Treo 680 screen replacement: 步骤 6 中的图像 2,3 Palm Treo 680 screen replacement: 步骤 6 中的图像 3,3
    • Turn the phone so the screen is facing the right side.
    • Use a spudger to carefully separate the back panel from the front panel to access components inside the phone.
    • Separate the covers from the left side of the device as indicated in the picture.
    • The right side contains orange ribbons that are easily damaged.
    询问修复机器人
    添加评论
  7. Palm Treo 680 screen replacement, LCD Screen and Touch Screen: 步骤 7 中的图像 1,3 Palm Treo 680 screen replacement, LCD Screen and Touch Screen: 步骤 7 中的图像 2,3 Palm Treo 680 screen replacement, LCD Screen and Touch Screen: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    • Use a pair of tweezers, to carefully peel off the silver tape from the screen.
    • Push the screen out of the back of the front panel to remove it.
    询问修复机器人
    添加评论
  8. Palm Treo 680 screen replacement: 步骤 8 中的图像 1,2 Palm Treo 680 screen replacement: 步骤 8 中的图像 2,2
    • Use a small spudger to flip up both of the locking flaps that hold the orange ribbon cables in place.
    询问修复机器人
    添加评论
  9. Palm Treo 680 screen replacement: 步骤 9 中的图像 1,3 Palm Treo 680 screen replacement: 步骤 9 中的图像 2,3 Palm Treo 680 screen replacement: 步骤 9 中的图像 3,3
    • Flip the screen over 180 degrees and remove the metal piece that cushions the screen.
    • Flip the screen over again.
    • In the following step, you will only slightly pull the screens apart. Do not fully separate them yet.
    • Carefully begin to pull apart the touch screen and LCD screen.
    询问修复机器人
    添加评论
  10. Palm Treo 680 screen replacement: 步骤 10 中的图像 1,3 Palm Treo 680 screen replacement: 步骤 10 中的图像 2,3 Palm Treo 680 screen replacement: 步骤 10 中的图像 3,3
    • Move your thumbs diagonally to the opposite corner of the screen and slightly pull apart the touch screen from the LCD screen.
    • Carefully peel the touch screen away from the LCD screen.
    • The touch screen and LCD screen should now be completely separated.
    询问修复机器人
    添加评论
结论
To reassemble your device, follow these instructions in reverse order, but ensure you use the new screen. Take your e-waste to an R2 or e-Stewards certified recycler.
取消:我没有完成这个指南。
2等其他人完成本指南。
Maiya123
于10/22/09注册
84 声望
创作了6篇指南
团队
Cal Poly, Team 6-4, Maness Fall 2009 Cal Poly, Team 6-4, Maness Fall 2009 的会员
CPSU-MANESS-F09S6G4
4 名成员
创作了15篇指南
2指南评论
where can i get the new touch scree, actually my mobile has fallen down and broken the touch scree. i am a resident in India, Andhra Pradesh, Hyderabad........at Ramkote.... please give me message at chinthala.prasad@yahoo.com please
chinthalaprasad - 回复 分享
These are very nice instructions. They are clear and detailed for anyone to follow. Thanks for putting together the steps and sharing it.
I have not tried all steps completely yet. But will do so. I will left with probably a question what to do with touch screen. My phone has
never fallen down nor damaged. It worked perfectly well and one fine day, touch screen stopped working. In any case, I will try.
RJ
Ravi Joshi - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 15
过去 30 天: 48
总计 6,941
