跳转到主内容
加入维修社区 - 创建账户
Palm IIIc Battery Replacement
你所需要的
  1. Palm IIIc Battery Replacement, Removing broken LCD screen: 步骤 1 中的图像 1,1
    • Keep track of all pieces removed from the device.
    • Gently pull off the device cover. The cover snaps on and off easily where the cover attaches to the Palm IIIc device
    询问修复机器人
    添加评论
  2. Palm IIIc Battery Replacement: 步骤 2 中的图像 1,1
    • Using a Phillips head screwdriver, take out the four screws on the back of the device. You may have to pull them out with your hands once they are unscrewed.
    • There will be two long screws and two short screws. The long screws come from the top of the device, and the short screws come from the bottom of the device.
    询问修复机器人
    添加评论
  3. Palm IIIc Battery Replacement, Remove the Front Cover: 步骤 3 中的图像 1,1
    • Lay Palm IIIc face-up and remove the front cover.
    • Do this firmly but not with too much force so as to not break or disturb anything you're not supposed to.
    询问修复机器人
    添加评论
  4. Palm IIIc Battery Replacement, Battery: 步骤 4 中的图像 1,1
    • Carefully pop out the battery, without disturbing the surroundings.
    • Prying tool will facilitate this step.
    询问修复机器人
    添加评论
  5. Palm IIIc Battery Replacement: 步骤 5 中的图像 1,1
    • Detach the wire connecting the battery to the motherboard.
    询问修复机器人
    添加评论
  6. Palm IIIc Battery Replacement: 步骤 6 中的图像 1,1
    • Attach the new battery by connecting it to the motherboard via the red wire.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
Cal Poly, Team 20-69, Walters Spring 2011 Cal Poly, Team 20-69, Walters Spring 2011 的会员
CPSU-WALTERS-S11S20G69
5 名成员
创作了16篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 16
过去 30 天: 56
总计 4,876
